Shifting Issues in 4x4 Low - JeepForum.com
post #1 of 6 Old 07-13-2012, 12:26 AM Thread Starter
FireMedic493
2006 XK Commander
So I used the 4x4 low for the first time in about 3 1/2 weeks earlier. Had no problems dropping it into low, but when I started driving, it didn't seem to want to shift out of 1st until rpm's hit around 4,000-4,500. It did this consistantly for about 5 mins. I then tried using the stick in manual mode with the same result. I was barely using the gas, maybe 1/5-1/4 throttle. This isn't normal for my Jeep. I have had no issues with shifting between gears in 4x4 high, so I don't think it's the transmission hesitating. Both differentials and the transfer case have been serviced regularly, and it's only been aprox. 1,100 miles since I last serviced them. All fluid levels are normal. Could this problem be from me not using the 4 low enough, or is it a sign of bad things to come? I'm hoping it's nothing serious, but since it's a new problem to me, I thought I'd throw it out there to see if anyone has some knowledge on it or has the same issue.
Any insight would be appreciated
2006 Jeep Commander Limited, 4.7L, QDII, Stock height, Stock skid plates, Custom Off-Road light setup, Custom front/rear recovery points, aftermarket tow hitch, K&N cold air intake, Stock size Goodyear Wrangler Silent Armor A/T tires, Enough flashy blue lights to send you into epileptic seizures
FireMedic493 is offline
post #2 of 6 Old 07-13-2012, 07:37 AM
yzjwk
2005 WK
Sounds like it's operating normal to me . when you shift to 4 low , your transfercase shifts to 2.72:1 ratio , which basically means your engine has to rev 2.72 x higher for the same speed output . 4-low is ONLY for crawling , no faster then 25mi/hr. it uses the 2.72 plus first gear transmission ratio as a gearing power adder .by shifting into 2nd , you loose all the advantages of having it in 4 low because now your trans is in a higher gear .IMO If you can drive fast enough in 4 low to get the trans to shift then you shouldn't be in 4 low to begin with .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #3 of 6 Old 07-13-2012, 08:50 AM
trax95008
2006 XK Commander
So you think you should never leave 1st gear in 4 low?
trax95008 is offline
post #4 of 6 Old 07-13-2012, 09:35 AM
yzjwk
2005 WK
no ,I just don't see much point in it .the gear ratios for the 545 are 3.0:1 - 1st and 1.67:1 in 2nd .so if your in second gear , you've just lost most of the mechanical advantage that you got by shifting to 4 low in the first place and greatly increase the risk of overspeeding your transfercase or binding up and breakingsomething . the only other advantage to shifting to 4 low is to lock the front and rear together which the QT11 and QD11 will selectively do on their own in 4 hi if needed .
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
post #5 of 6 Old 07-13-2012, 11:55 AM
colinzj
2006 WK
Sounds normal to me too. Shift patterns are stretched out in low range for good reasons.
In addition to what yzjwk already mentioned, the power band on newer engines is also at higher engine speeds. For the 4.7, maximum torque is at 3600 rpm and maximum horsepower's at 4500 rpm. If the TCM is shifting before that, it's giving up the grunt that's going to move you through the tough stuff.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #6 of 6 Old 07-13-2012, 01:16 PM Thread Starter
FireMedic493
2006 XK Commander
Thanks for the responses. Only reason i was concerned was that this is the first time it's happened. It normally shifts around 2,500 when I'm feathering the throttle. And no, I was not going over 15 mph. I was just inbetween obstacles on the way to a fishing spot and didn't feel like shifting out of low. Everything worked fine, was just not use tot he higher shift point with MY Jeep.
Thanks for all the help.
Shifting Issues - 06 WK SgtJensen WK Grand Cherokee & XK Commander Forum 12 03-29-2012 02:23 PM
shifting issues acrrr ZJ Grand Cherokee Forum 0 03-25-2012 09:05 AM
Shifting issues alphazulu29 ZJ Grand Cherokee Forum 19 09-11-2011 12:30 AM
Shifting issues The_Scout ZJ Grand Cherokee Forum 1 04-18-2010 07:33 AM
shifting issues coonash ZJ Grand Cherokee Forum 10 09-13-2005 07:37 AM
