SES - Fail Code Reader - JeepForum.com
post #1 of 15 Old 06-22-2007, 12:00 PM Thread Starter
2007GC Overland
2007 WK
Hi Guys
the Jeep has only 2500 miles and my second SES light - last time it was the Gas Cap (it was on tight - oh well). The jeep has not been filled up for almost a week - 1/4 tank is left, so I don't think it is the gas cap but could be wrong. Here is my question - I have AUTOTAP for OBD II, can I read the Fail Codes on this Jeep with that unit? I will try to reset the SES light because that may cause problems. I don't want to waste a half day at the dealer if it is the Gas cap again. The system reset the light after a couple run cycles.
thanks
Bill
2007GC Overland is offline
post #2 of 15 Old 06-22-2007, 12:13 PM
drewman141
Gas Guzzler
drewman141's Avatar
1994 ZJ
You can get the code by cycling the key on, off, on, off, on with the door open and it will display in the dash. If you keep getting this code then it may be more than your gas cap.
[SIZE="1"]2008 WK Overland HEMI - Modern Blue Pearlcoat
Fully loaded with slush mats of course.
MUST GO! 1994 Limited ZJ 5.2L V8 - Light Driftwood Satin Glow
It's a 94 5.2L Limited - trxus 33's on 15x7 steelies, 4.56s w/ front OX and rear trutrac, NP242 swap, novak shift kit, Kevin's ultimate 4.5" lift + ACOS, ARB front bumper w/warn M8000, rear tomkin machine bumper w/ tire carrier, kevin's hardore railz, kevin's ultimate tc skid, kevin's trackbar conversion, rusty's gas skid, flexalite efan, Kolak's performance ignition and brake upgrades. ViAir OBA, custom storage/sub box and I'm sure there's a bunch of other things I'm missing. Everything is a little over 3 years old with less than 10K miles. Looking to get around $4k.
drewman141 is offline
post #3 of 15 Old 06-22-2007, 12:36 PM Thread Starter
2007GC Overland
2007 WK
Totally agree with you - the gas cap did not make sense the last ime they told me. I found it hard to believe but that is what the code said.
post #4 of 15 Old 06-23-2007, 11:27 AM Thread Starter
2007GC Overland
2007 WK
Hi Foks
It is a P0456 - small leak -could be the gas cap but I doubt it. This is the second time within month - back to the dealer, now I know it has to be something more than a gas cap.
thanks
Bill
PS: still would like to know if the older Autotap will work on my 2007
post #5 of 15 Old 07-22-2007, 01:55 PM
HurriJeff
2013 WK
I had a "Check Gas Cap" message when I bought my 05 Hemi. Dealer convinced me that it was a warranty issue and they would fix it. And they did.. No questions asked. It took two visits to correct the problem but I'm satisfied. It was NOT the gas cap. And it was not a leaking fuel tank as some had suggested. There is a small air pump designed to test the integrity of the fuel system. It is supposed to run on stat up for a few seconds to pressurize the tank and fuel system to .2 to .5 psi. Its a pass or fail test. That pump was suspected as well but it was good also. Turns out that the plastic cover on the HEMI tends to push and pull on hoses and fittings when its removed and installed. There was a hose pulled out of a rubber fitting. That was the cause of my problem. Also turns out that when I got the car back the tech at the dealer had left a different fitting disconnected which I fixed myself. Its a pretty fragile system under that cover. Pay very close attention when removing and replacing that cover because its really hard to see disconnected stuff once the cover is in place.
If you find and fix the problem yourself, the system should "pass" its self test and your fault message should stop displaying. Someone will have to clear the fault code from memory manually though. I dont know how that is done other than at the dealership.
05 Grand Cherokee Limited 5.7 Hemi 265/65/17 Revos, K&N
HEMI CLUB MEMBER #10
Previous Jeeps:
1998 ZJ Special Edition 2wd- Traded
1991 XJ 2.8 2wd Sold
HurriJeff is offline
post #6 of 15 Old 07-30-2007, 03:46 PM
hophead
2005 WK
Very interesting. I have the same problem. I just took a peek under the cover, but found nothing disconnected.
It's done with an OBDII code reader. I'm not sure if they all have the ability to clear codes, but all the ones that I've seen (including mine) do.
hophead is offline
post #7 of 15 Old 07-30-2007, 04:09 PM
merlinTec
merlinTec's Avatar
Hi
Found this TSB and the info in it is good to understand why you get this code. http://www.wkjeeps.com/tsb/tsb_wk_1400106.pdf
merlinTec is offline
post #8 of 15 Old 07-31-2007, 12:31 PM Thread Starter
2007GC Overland
2007 WK
Originally Posted by merlinTec
Hi
Hi Folks
thanks - I read the TSB - GOOD INFORMATION but mine was a small leak - did not get the Check Gas Cap - they linked to the car cap. Anyway .090" is big hole - that is almost 3/32 of an inch - I have to believe the gas cap should seat better than they do. I think they have a poor design if this problem surfaces.
Bill
post #9 of 15 Old 08-03-2007, 09:34 PM
HurriJeff
2013 WK
So Overland... are you fixed ?? You said yours was a small leak.. Where ??
Previous Jeeps:
post #10 of 15 Old 08-04-2007, 07:06 AM Thread Starter
2007GC Overland
2007 WK
Hi HurriJeff
appears to be working no fail codes - they did replace the gas cap. I also bought a CAN scan tool to reset it if it happens again. 3500 miles on the Jeep.
thanks
Bill
post #11 of 15 Old 08-04-2007, 07:23 AM
HurriJeff
2013 WK
Thanks Bill...
Previous Jeeps:
post #12 of 15 Old 08-04-2007, 09:01 AM
T-Rated
T-Rated's Avatar
How does one go about buying a CAN scan tool? What all does it do? Do you have a link?
Jeep: 2006 Midnight Blue Grand Cherokee Limited 4.7L Bells Whistles
Mods: Tow Hooks Mopar & 4xGuard Skid Plates & Rock Rails Flowmaster 70 255/65R17 REVO's
T-Rated is offline
post #13 of 15 Old 08-04-2007, 09:55 AM Thread Starter
2007GC Overland
2007 WK
Hi T-Rated
you are going to love this - have all the software tools for my Camaros and AutoTap for pre "CAN". I was going to buy the Autotap for CAN but one day I went to Habor Freight Tools and pickup a tool that can read and reset the fail codes - work great to my surprise. see the info below - here is the secret - PRINT THE PAGE WITH THE $39.99 PRICE (go to HFT sites) AND TAKE IT TO HFT AND THEY WILL HONOR IT OR ORDER ON-LINE. A couple of my friend bought the tool and is keeping in their cars. Can not go wrong for $40 :-)
ITEM 94169-3VGA
$79.99
SALE: $39.99
Thanks
Bill
post #14 of 15 Old 08-04-2007, 12:54 PM
T-Rated
T-Rated's Avatar
Cool. I printed the ad. I suppose it'll work on my wife's G6 as well.
T-Rated is offline
post #15 of 15 Old 08-04-2007, 07:25 PM Thread Starter
2007GC Overland
2007 WK
It will work on any CAN or Non-CAN OBD II.
P1281 - Different code on the reader than the book! Flyusaf2002 ZJ Grand Cherokee Forum 8 11-25-2010 09:00 AM
code reader/ check engine zjzach ZJ Grand Cherokee Forum 1 07-14-2009 01:08 AM
Buying a code reader 7tiger7 ZJ Grand Cherokee Forum 1 06-04-2009 12:00 PM
engine dies, jeep will not connect with code reader??? JackAysJake ZJ Grand Cherokee Forum 3 08-05-2008 10:47 PM
built in code reader/scantool? tednelson83 WK Grand Cherokee & XK Commander Forum 8 05-22-2007 08:38 PM
