"Service 4WD System" - message - JeepForum.com
post #1 of 15 Old 10-30-2009, 07:11 AM Thread Starter
88mudder
The "service 4wd system" message came on this morning. (2006 Grand 4x4 4.7L) I just changed all the fluids front to back 2 days ago. Have driven about 45 miles since the change. Any ideas what it might be. I put Mobile 1 Synthetic 75-140 in the differentials and the mopar transfer case fluid NV245/247/249 in the t case. Thanks for any advice!!
88mudder is offline
post #2 of 15 Old 10-30-2009, 08:04 AM Thread Starter
88mudder
The battery was dead this morning also so I had to boost it. Now after a second trip the message is gone. Maybe something with the dead battery could have caused the meassage????
88mudder is offline
post #3 of 15 Old 10-30-2009, 10:33 AM
N4x4M
2009 WK
I think this is a gremlin in our Jeeps. If you do a search it seems others have had the same issue. My 06 does it about once every two weeks. Seems to come and go. I do believe some have found a fix.....again search and I think you can learn a bit more.
Regards
Mike
N4x4M is offline
post #4 of 15 Old 10-30-2009, 12:21 PM
LJS8510
LJS8510's Avatar
2015 WK
I had the 4 wd warning message once after doing some offroad. I Finished the little bit left of the trail then it shut down & restarted, it was fine ever since, even had dealer check it out they found nothing!
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #5 of 15 Old 10-31-2009, 01:07 PM
rockwvu
2005 WK
i had the same message after a dead battery about 2 months ago. Went away on the next startup as you described. I haven't had any problems/messages since.
rockwvu is offline
post #6 of 15 Old 11-05-2009, 09:04 AM
madmarchhare
Im not sure of the #, but theres a TSB for that
madmarchhare is offline
post #7 of 15 Old 11-05-2009, 10:01 AM
Rwebber77
2005 WK
Mine comes on only when I don't hit the remote start right. Goes off every time though.
5.7 Hemi, OME HD, 1.25" spacers, 265/70/17 Revo 2's, Volant CAI, Gibson Catback, SCT engine management, Superchips piggy back with trans app, 3/4" front shackles
Rwebber77 is offline
post #8 of 15 Old 11-11-2009, 04:09 AM
Rs4ockies
Right after I got mine back from the dealer for it's routine oil change...had the same message for a couple days. Hasn't happened again though?!? Very odd at the least...
Rs4ockies is offline
post #9 of 15 Old 11-12-2009, 12:57 AM
kentman
kentman's Avatar
2006 XK Commander
I used the exact same fluids for both the diffs (plus friction modifier additive) and TC on the XK, and the same warning message came on not long after that for me, too. I wonder if the ELSD solenoids do not like the Mobil 1 synthetic. I may try non-synthetic fluids on the next swap.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
post #10 of 15 Old 11-12-2009, 05:42 PM
bob123
2006 XK Commander
bob123 is offline
post #11 of 15 Old 11-13-2009, 12:26 AM
kentman
kentman's Avatar
2006 XK Commander
Originally Posted by bob123 View Post
Here is the TSB for it.
Already paid to have that TSB done. It did not help me.
kentman is offline
post #12 of 15 Old 11-13-2009, 05:58 AM
LTrainGC
2005 WK
I had the same message, pulled code "C141D" with my superchips - I ended up replacing the solenoid for the ELSD in the rear axle along with the wire harness and the message is gone now.
Parts were around $40 from the dealer and I changed it out when I replaced my diff fluid.
The service 4WD message could be a number of things though - try and get the code pulled from somewhere.
-Frank the Tank-
-2005 Jeep Grand Cherokee Limited-
- 5.7L HEMI/QDII/Superchips/AEM Brute Force/MBRP/RRO/Bilsteins/32s -
LTrainGC is offline
post #13 of 15 Old 11-14-2009, 04:29 AM
kentman
kentman's Avatar
2006 XK Commander
I was going to start with the rear ELSD solenoid, since that one looks easiest to do. I have already purchased solenoids for both the front and rear for a total of $47 shipped for both. I have them sitting in the attic waiting for the next fluid swap interval.
If the rear one does not do it, then I will do the front one. If those do not solve the problem, then I will take it in for diagnosis. I suspect that wiring would be the next issue in line.
kentman is offline
post #14 of 15 Old 11-16-2009, 10:04 AM
HemiGrand57
2006 WK
Amsoil Synthetic in Everything
I have Amsoil in everything and have never had the Service 4wd light on. I get about 17-19mpg with the 5.7 on the highway at 70mph.
HemiGrand57 is offline
post #15 of 15 Old 11-16-2009, 10:29 AM
LTrainGC
2005 WK
I don't think my warning message has anything to do with the fact that I use Mobil 1, because the solenoid in the front diff is still functioning just fine with M1 fluid. I actually think I could have just replaced the wire harness and not the solenoid itself, but figured I might as well do the whole she-bang just for piece of mind.
-Frank the Tank-
LTrainGC is offline
"Service 4WD Switch" Message 95JGC ZJ Grand Cherokee Forum 5 12-24-2013 03:58 PM
05 WK "Service Electric Brake System" Light wktim WK Grand Cherokee & XK Commander Forum 3 11-28-2009 08:25 AM
Tpms "service Tire Pressure System" JOHNRAMBO WK Grand Cherokee & XK Commander Forum 3 01-14-2009 06:06 PM
"Service 4WD System" message rwmorrisonjr WK Grand Cherokee & XK Commander Forum 7 04-05-2007 01:55 PM
"Service 4x4 switch" message roadfrog ZJ Grand Cherokee Forum 6 03-11-2004 08:34 AM
