Service 4wd system light - Page 6 - JeepForum.com
post #76 of 104 Old 07-26-2013, 03:25 PM
Megs_Revenge
2005 WK
Yes, but isn't the computer causing the tcase issue? Perhaps I'm wrong?
2005 Silver WK 5.7L Hemi
Silver WK club #69
Oo|||||||oO
Megs_Revenge is offline
post #77 of 104 Old 07-26-2013, 07:12 PM
phottomatt
2010 JK Wrangler
Its not part of the recall, the recall is a software issue. I asked my dealership and they are not ready to do the recalls yet. I was hoping to get both done at the same time, Pooh well, at least i have a service plan that is covering this job.
2010 Flame Red Sahara, Rough Country stubby bumper/winch, Body Armor rock sliders, stiff spring mod and RC 2.5" series II spacer lift (~3.5" total lift), 33X12.5 Duratracs on 15" MB72s.
2007 Grand Cherokee Limited, Red Rock, 5.7L HEMI
phottomatt is offline
post #78 of 104 Old 08-06-2013, 10:10 AM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Originally Posted by kentman View Post
My money is on the front. It is harder to do. Therefore, Murphy's Law ensures that the hard one to do is the one that fails. That was the case for me. I have a spare solenoid on the shelf at home for the next time that the front one fails again.
yep, 14.1 on the rear, 1400 on the front.
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | Provent MBRP XP Exhaust | New Intake Tube & Seal + EHM | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | 200,000 Mile Club | Dogpiled Club | pre-N23 FDCM |
89 GW w/plow
wookiee is offline
post #79 of 104 Old 08-09-2013, 02:10 AM
kentman
kentman's Avatar
2006 XK Commander
Winner, winner, chicken dinner.
Vanna, what prize do we have for our lucky contestant today?
Have fun with the swap. I just did the differential fluids on the XK last weekend. I had the cover off the rear, but I just did the drain and fill on the front. I only mess with the front cover if the solenoid is bad.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
post #80 of 104 Old 09-29-2013, 10:02 PM
stipo
2010 WK
Mine won't start, after a wash yeaterday, the "Service 4 wd System " Warning Light is on. Waiting for a tow.
stipo is offline
post #81 of 104 Old 10-06-2013, 05:05 PM
stipo
2010 WK
I have spoken to Chrysler. The fdcm is faulty , my 2010 5.7 hemi overland is 3 months out of warranty. But we're trying to get $2600 cost covered by Chrysler. I am lucky the problem occured while I was home, instead of 350 km away for work. The cost of towing the vehicle would have been astronomical.
stipo is offline
post #82 of 104 Old 12-09-2013, 02:40 PM
2006jeepjeff
I just took my 2006 Grand Cherokee Overland in and they said the transfer case motor needed to be replaced. $550 for the part and with labor it ended up being like $945. They said the motor was backordered like a month and a half.
2006jeepjeff is offline
post #83 of 104 Old 12-09-2013, 04:58 PM
ASTMedic
Was this code after you tried to put it in 4low? Did you have the safety update done?
ASTMedic is offline
post #84 of 104 Old 12-13-2013, 04:17 PM
MikeJeep09
Funny you should ask this question. I had the recall done and had never tried to put in in 4 wheel low, so just for the heck of it now that there is snow I tried and it did not go in low and warning came on dash. Is there a reason you ask?
MikeJeep09 is offline
post #85 of 104 Old 12-13-2013, 05:48 PM
ducktail
2009 WK
I dare say that is BS. The code did not work in all likely hood so they want to put in an new part.
My is/was supposedly full of corrosion so they ordered a new part AFTER doing the re-programming. Why should a Jeep need a new part from corrosion? Seriously. The rest of it is just fine, or at least appears so.
Just why are all these transfer motors going bad now? Why are they on such a back order?
2009 GC Limited. 265 70 18 is the only change to date. Bought some Rubicon 17" wheels and put BFG M/T's on for hunting season OME HD Front, OME MD rear, winch to come, basket and lights bars first
ducktail is offline
post #86 of 104 Old 12-13-2013, 06:54 PM
ASTMedic
Look at the thread about N23 safety update. It's screwed up all out 4 low.
ASTMedic is offline
post #87 of 104 Old 12-14-2013, 06:44 AM
Huck
2008 WK
THE ACTUATOR MOTORS ARE NOT BAD.
We are loosing a tinny bit voltage at the actuator electrical connector.
Huck is offline
post #88 of 104 Old 12-14-2013, 07:40 AM
Blown7
Huh???
You serious?
What your argument?
Blown7 is offline
post #89 of 104 Old 12-14-2013, 07:49 AM
ASTMedic
THE ACTUATOR MOTORS ARE NOT BAD. We are loosing a tinny bit voltage at the actuator electrical connector.
As I commented on the other post about this. Are we supposed to solder the connection to prevent this? Then what when the actuator goes out?
However this is the most reasonable idea I've heard about this problem. It would explain why it's totally erratic and only a code clear is needed to fix it till the next time the FDCM sees a voltage drop.
ASTMedic is offline
post #90 of 104 Old 12-15-2013, 10:29 AM
MikeJeep09
Thanks, I am a newbie and joined after a search led me to this thread. I will search n23.
Service Electrical Brake System light? beeneeb WK Grand Cherokee & XK Commander Forum 14 06-23-2015 02:02 PM
Service 4x4 System AND Service Electonic Brake System...? TatorTodd WK Grand Cherokee & XK Commander Forum 0 12-25-2009 08:49 PM
05 WK "Service Electric Brake System" Light wktim WK Grand Cherokee & XK Commander Forum 3 11-28-2009 08:25 AM
Service 4WD System Jojeep WK Grand Cherokee & XK Commander Forum 5 02-14-2008 08:10 PM
service 4WD system ........... karvr WK Grand Cherokee & XK Commander Forum 6 10-16-2006 09:51 PM
