service 4WD system ........... - JeepForum.com
post #1 of 7 Old 10-01-2006, 04:17 PM Thread Starter
karvr
hello, just bought an 06 grand cherokee with quadra trac 2, 4.7 V8, my wife and I were travelling with cruise on doing 110 km an hour when the chime went off and in the display was this message " service 4WD system " then it went out hasn't come back on since.Everything seems normal , near my house I went on some back roads and checked the low 4x4 mode, went in and out of low to high several times as per manuals instructions, works fine.....any ideas...thx in advance.
karvr is offline
post #2 of 7 Old 10-01-2006, 05:13 PM Thread Starter
karvr
fix found
see link...i guess i'll bring it in to service soon....
http://www.wkjeeps.com/tsb/tsb_wk_2101406.pdf
karvr is offline
post #3 of 7 Old 10-09-2006, 04:20 PM
k1llerkyle
There is a service bulletin on it. its a false reading. I got the same thing, they just have to flash the computer.
k1llerkyle is offline
post #4 of 7 Old 10-14-2006, 01:45 PM
Podedwards
Podedwards's Avatar
Service Four Wheel Drive System
It means that a sensor is bad (acting erratically) and needs to be replaced. Happened onmine-replaced no problem.
Podedwards is offline
post #5 of 7 Old 10-15-2006, 03:22 AM
GCT00427
It may never come back on. It happened to me last year after I got my Rocky Mountain (Sept 26) on one cold morning as I was going to church. When I got out, it had already reset itself and has never reappeared.
If it doesn't come back on, don'e worry about it. If it does, you can always take it to the dealer.
Regards,
Chuck
2005 WK Rocky Mountain Edition 4.7 (mine)
2006 XK Commander T Package 4.7 (wife's)
GCT00427 is offline
post #6 of 7 Old 10-15-2006, 05:07 PM Thread Starter
karvr
final drive control module flashed
Hello thx for the replies, I had the final drive control module flashed with updated software......as per the technical bulletin I found. What annoy's me about this whole situation is that as a consumer I had to go into the dealer and ask them to do the work...they only do the reflash (or any technical bulletin)if the costumer ask's for it, they won't do it even if they know of it and your in there for say an oil change, I realize it is warranty work and they can't upsell warranty work. Thats fine with me I bookmarked the site for tsb's and will be sure to visit them when and if I see one pertaining to my vehicle.
Technical Service Bulletins
http://www.wkjeeps.com/wk_tsb.htm
karvr is offline
post #7 of 7 Old 10-16-2006, 09:51 PM
cliff
2005 Cherokee Laredo
This past Friday, I bought a used 05 WK with the 3.7 and 4wd. with 20,000 miles. Got it off of eBay.
I am hearing a very slight growling sound coming from the front end when driving it. I have a 4wd 03 dodge pickup that does not have any noise at all from the front. However it is not full time like the 5Qdra Trac 1 system
This WK was a rental car, and apparently seems to be in good shape. It is still under factory warranty. I called the nearest jeep dealer today and spoke with the service dept. He said they would check it out.
Any of you folks ever noticed this kind of noise coming from the front end.
I am pleased with the jeep. I am getting about 22 mpg. I use it as a work car and drive it about 100 miles a day. Don't plan to do any serious off road driving with it at our ranch.
cliff is offline
Service 4wd system light I8AHUMR WK Grand Cherokee & XK Commander Forum 105 09-30-2017 08:09 PM
Service 4x4 System AND Service Electonic Brake System...? TatorTodd WK Grand Cherokee & XK Commander Forum 0 12-25-2009 08:49 PM
Service 4WD System Jojeep WK Grand Cherokee & XK Commander Forum 5 02-14-2008 08:10 PM
service 4WD system,..what does this entail? coyote runner WK Grand Cherokee & XK Commander Forum 3 08-18-2007 04:36 PM
Service four wheel system reynolds WK Grand Cherokee & XK Commander Forum 14 02-02-2007 09:40 PM
