Service 4wd system???? - JeepForum.com
post #1 of 2 Old 09-21-2013, 04:08 PM Thread Starter
revpayne1
Hey, to all those more knowledgeable than me...I have a 2006 Commander 4.7 liter and I keep getting a service 4wd drive message on my dash. The dealership told me it was my 4wd actuator that needed to be replaced, so I found a used parts dealer that I could get one for $70 dollars as compared to almost $500 new from the dealer. I've put two different used actuators on, just in case the first one was bad, and still when I try to shift it into 4 low I get the service 4wd system error message. Don't know where to go from here...would appreciate any insight from you guys. Thanks for your time!!!!
revpayne1 is offline
post #2 of 2 Old 09-22-2013, 12:10 PM
yzjwk
2005 WK
did you happen to get the latest recall done ?the dealer may have done it while you had it in for the initial problem . if so read this http://www.jeepforum.com/forum/f67/n...4-low-1561787/
If that's not it , your going to have to read the codes that are bringing up the service 4wd system message .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
