Seriously...why 330 hp Jeep Hemi and 350hp Dodge and Chrysler Hemi??? - JeepForum.com
post #1 of 12 Old 11-01-2007, 05:53 PM Thread Starter
HurriJeff
2013 WK
C'mon.. Someone's gotta know the answer.. Why are the Ram trucks and Charger 5.7's rated 20hp more than same engine in my Jeep ??
I know dual exhaust on those others but is that really all there is to it ? Same ECM programing? <shrug>
05 Grand Cherokee Limited 5.7 Hemi 265/65/17 Revos, K&N
HEMI CLUB MEMBER #10
Previous Jeeps:
1998 ZJ Special Edition 2wd- Traded
1991 XJ 2.8 2wd Sold
HurriJeff is offline
post #2 of 12 Old 11-01-2007, 05:55 PM
ttusqrl
2005 WK
I don't care, just gimme the 20 extra
2005 WK 5.7 ORT | Mod SL (OME struts & 990s) | JBA UCAs & Discos | Saguaro Front Bumper | Warn Zeon 10s | 285/70/17 BFG TA KO | AIRAID CAI | Gibson 3" Exhaust | DiabloSport Intune | JL Stealthbox
ttusqrl is offline
post #3 of 12 Old 11-01-2007, 06:55 PM
gornoman
2006 WK
The duals could easily make that difference. Maybe better intake airflow also since those trucks don't deal with water fording as a design criteria.
'06 Grand Cherokee Laredo 4X4 (26E), Steel Blue Metallic. 3.7, QTII Trail Rated, Factory Skids, Tow Package, RRO Rock Rails, 245-65-17 Bridgestone REVOS
Ipod, CB, Leather Steering Wheel, Fog Lights. Black Bear Road Alumni, Elephant Hill Alumni.
Blue WK Club Member #15
My other passion -
gornoman is offline
post #4 of 12 Old 07-17-2011, 05:31 AM
mikeb33
I don't think it is the same ECM programming. I think the intake, exhaust and programming are the differences. This is good since these are easily changed.
If you change these 3 on a Charger, you may gain 20HP. If you change them on a WK Jeep, it may yield 40 HP! WIN!
mikeb33 is offline
post #5 of 12 Old 07-17-2011, 10:08 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
I am sure the exhaust manifold makes a difference too. Ours are terrible!
Omelet is offline
post #6 of 12 Old 07-17-2011, 12:58 PM
jas32
The difference is typically caused by inlet and exhaust restriction which changes for each vehicle application. Almost everything else is the same on either engine. Keep in mind that the rated HP is taken at max operating conditions (wide open throttle, near max operating RPM) which means that to the average customer, 99% of the time there should be no difference in power output between the Jeep and the Dodge Hemi engines.
jas32 is offline
post #7 of 12 Old 09-21-2012, 10:00 PM
phottomatt
2010 JK Wrangler
I know this is a year old thread but instead of starting a new one i thought I would hijack this one. Anywho the answer is ECU programming. Now, the new question is can we get the WK reprogrammed?
phottomatt is offline
post #8 of 12 Old 09-22-2012, 08:19 PM
90grandoneer
90grandoneer's Avatar
2006 WK
Here's one big difference that, I am sure, accounts for most of it. http://www.jeepforum.com/forum/f67/b...-7-wk-1174042/ Also, as said above, the duals may help a little, but can be adjusted for with a good low restriction, straight through 3 in. cat. back. I am guessing mine is putting about ~420 at the engine and ~370 at the wheels, the way I've got it set up. See my signature. Still have a few things I can do (heads, throttle body and UD pulley) to pull another 40-50 hp out of it. There are also about 3-4 different intake manifolds for the Hemi. Mopar Magazine did a test on all of them.
To answer your question, phottomatt, you'll have to get either a Diablosport or Superchips tuner to reprogram the PCM. If you're after economy the DS is a little better, if you want full control of the trans., the SC is better.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #9 of 12 Old 09-22-2012, 08:25 PM
tjkj2002
2002 KJ Liberty
Funny thing is there not even true duals,it's a single exhuast with dual tips.
tjkj2002 is offline
post #10 of 12 Old 09-22-2012, 10:10 PM
phottomatt
2010 JK Wrangler
Thanks 90grandoneer, haha, you answered the question I MEANT to ask. I knew there was a way I just was interested in the best options.
post #11 of 12 Old 09-23-2012, 12:49 PM
90grandoneer
2006 WK
Pm, I've got both of the most popular tuners for both my Hemi vehicles and, as I said, the DS is a little better for economy. I never use the SC tuner on my Magnum anymore, but do change back and forth on the Jeep. I had been running the SC for quite awhile, solely because of the cool Trans. App. that is an option with it. I do that mostly because of the lousy stock shift schedules and torque management setup for the 545RFE. The DS now offers limited (1st, 2nd, and 3rd only) so it is a little better now, in that regard. The Maggie has a NAG1 tranny with full autostick, and is 1000 times better than the Jeep, IMO.
Other differences, if you're thinking of picking one or the other up are, the SC has some adjustments that can be manipulated for the off-roaders, and the DS allows you to update to the latest CALID flash files (about $100-150 to have done at the dealer) for the PCM/TCM, and gives you the ability to have custom tunes made. This seems to be mostly for the high performance engines, but some have said it works good for mildly modified engines too. Even with my mods., I've never invested in one (~$200-300, I understand), and am happy with modifying the canned tunes. In addition to some of the tuning mods. also incorporated in the SC tuner, the DS tuner allows you to adjust WOT fuel mixture and timing, which is helpful if you do a little racing. Hope this helps a little for you.
post #12 of 12 Old 09-23-2012, 12:53 PM
Moto4x4
I would say these are your best bet why your have less HP.
On my STi going from 2.5" to 3.5" exhaust and changing headers can make another 60hp at the wheels
Moto4x4 is offline
5.7 Hemi vs 6.1 Hemi Plug Wires DougDunlap WK Grand Cherokee & XK Commander Forum 20 11-05-2011 10:50 AM
2009 hemi vs 2005-2008 hemi pauld WK Grand Cherokee & XK Commander Forum 11 01-29-2010 10:06 PM
hemi jeep with flowmasters usbrit ZJ Grand Cherokee Forum 5 04-09-2006 09:18 PM
Why only 330hp in the jeep hemi? hemi4fun WK Grand Cherokee & XK Commander Forum 3 03-13-2006 07:17 PM
Jeep, Can you say Hemi?? wolfepack215 ZJ Grand Cherokee Forum 15 01-25-2006 03:27 PM
