seltbelt chime disable - JeepForum.com
post #1 of 34 Old 01-29-2008, 04:39 PM Thread Starter
styven
I know that other manufactures have a way of disabling the seltbelt minder chime. anybody know the way? I looked, but not in handbook.
thanks! I have '07 GC 5.7HEMI
styven is offline
post #2 of 34 Old 01-30-2008, 01:08 AM
jeep_on
Iím not sure if you can do it in Jeeps or not, but you can do it in the Dodge RAM. I will have to look it up. A cheap fix is to put a jumper on the seat belt wiring connection at the base of the seat.
2006 Dodge RAM Laramie w/ 5.9L I6
2010 Volkswagen Jetta w/ TDI 2.0L I4
Waiting on a 2013 RHD JK Unlimited
Originally Posted by PM Thor View Post
Wait, you can't cross creeks up there? What the Hell is up with these Canadians?
jeep_on is offline
post #3 of 34 Old 01-30-2008, 09:42 AM
07WKLtd
2007 WK
To remove seatbelt chime
1. Turn the ignition switch to the OFF position, and fasten the drivers seatbelt.
2. Start engine, and wait for Seat Belt warning light to turn OFF.
3. Within 60 seconds of starting engine, unbuckle and then re-buckle driver's seat belt at least 3 times, ending with belt buckled.
4. Turn off the engine. A single chime will sound to signify that your life is in your own hands.
07WKLtd is offline
post #4 of 34 Old 01-30-2008, 09:47 AM
Texas WJ
Texas WJ's Avatar
2005 WK
Excellent, thanks 07WKLtd. This will make driving around the ranch far less annoying.
Texas WJ is offline
post #5 of 34 Old 01-30-2008, 01:09 PM
stickline
2008 WK
Has anyone tested this with a 2008 WK? Just curious...
stickline is offline
post #6 of 34 Old 01-30-2008, 01:46 PM
merlinTec
merlinTec's Avatar
Hi
This is from the 2008 service manual
CUSTOMER PROGRAMMING SEQUENCE
NOTE: The following sequence of events must occur within 60 seconds of the ignition switch being placed in the ON position in order for the programming to be completed successfully. Even if the vehicle is equipped with both driver and passenger side front seat belt switches, this programming sequence MUST be performed using the driver side front seat belt. The passenger side front seat belt switch has no programming functionality.
1. With all doors closed and the ignition switch in any position except ON or START, buckle the driver side front seat belt.
2. Turn the ignition switch to the ON position and wait for the seatbelt indicator reminder function to conclude (about six seconds).
3. Unbuckle and buckle the driver side front seat belt three or more times, ending with the belt buckled.
4. Turn the ignition switch to any position except ON or START to toggle the BELTMINDER feature from its current setting (from active to inactive, or from inactive to active). A single chime tone will provide an audible confirmation that the programming sequence has been successfully completed.
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #7 of 34 Old 09-07-2008, 02:38 AM
Greggk300C
Location: Fort Carson Colorado Home of the 4th Infantry Division
so does this work permanently, or is this a proceedure that needs to be done everytime?
Greggk300C is offline
post #8 of 34 Old 09-07-2008, 02:47 AM
merlinTec
merlinTec's Avatar
Hi
Not permanently but turns it off until you do the procedure again to turn it back on.
Regards,
Merlin
post #9 of 34 Old 02-01-2009, 12:54 AM
jimwww
jimwww's Avatar
Freaking Excellent.. I will do this tomorrow morning
1999 Jeep GC Limited ( WJ ) V8
jimwww is offline
post #10 of 34 Old 02-01-2009, 02:24 PM
jeepinbowhunter
2014 JK Wrangler
This also will work on a 2006 Commander.
1993 Wrangler SE (Sold)
1994 Sahara (Died via Black Ice)
1999 XJ (Sold)
2006 XK Commander (Daily Driver)
2014 JK Unlimited Sahara (On Order)
jeepinbowhunter is offline
post #11 of 34 Old 02-01-2009, 04:35 PM
jimwww
jimwww's Avatar
I tried it on mine.. I guess I will know weather or not it worked after I get in My Jeep again and not put on my seatbelt.
jimwww is offline
post #12 of 34 Old 02-01-2009, 04:41 PM
CanadianCowboy
2007 WK
Hey Texas,
i have the same problem on my ranch.... so i just buckle the seatbelt then throw the shoulder strap behind the back of the seat.... make a nice rifle holder in the back!
CanadianCowboy is offline
post #13 of 34 Old 02-01-2009, 09:20 PM
Texas WJ
Texas WJ's Avatar
2005 WK
Originally Posted by CanadianCowboy View Post
Hey Texas,
Heh. Good idea.
I would buckle it, but got tired of the buckle/latch jabbing my side.
Texas WJ is offline
post #14 of 34 Old 02-02-2009, 08:40 PM
Natemare13
2007 WK
Is this also supposed to turn off the Beeps when you first start the car? or does it just stop the seatbelt chimer from chiming when driving?
Natemare13 is offline
post #15 of 34 Old 02-03-2009, 02:09 PM
jimwww
jimwww's Avatar
Well I did it on mine.. used it the next day and the chime still comes on when driving without the belt on.. so I'd say this doesn't work as a permanent sol'n - prob works only for that time that you do it.
jimwww is offline
how disable door chime kiesha WK Grand Cherokee & XK Commander Forum 23 04-21-2015 02:45 PM
Need some ZJ owners to chime in jdearmitt ZJ Grand Cherokee Forum 5 01-25-2010 01:30 AM
Vehicle overspeed chime... WTF!?!? can I disable? kookoo102 ZJ Grand Cherokee Forum 7 10-12-2009 06:13 AM
Seatbelt Chime Chimp Cherokee WK Grand Cherokee & XK Commander Forum 18 10-02-2006 06:33 AM
ZJ Chime in XJ Islandroaddie96 ZJ Grand Cherokee Forum 2 10-26-2004 08:59 PM
