Self Diagnostics - JeepForum.com
post #1 of 9 Old 10-25-2010, 01:01 PM Thread Starter
msasbill
2005 WK
Self Diagnostics
Hello all! I'm new to the forum, and had a quick question. I've had a 2005 WK with the 4.7, QTII, and 55K miles for a little while now, and the Service 4WD System light flashed up. I've read through several threads on the topic, and plan on taking it to the dealer if necessary.
My question however is whether or not the WKs have a self diagnostic mode where they will put the codes up on the display on the dash. I did a search and couldn't find anything. A friend of mine had a Cougar back in the day with a similar type display and with a certain sequence it would "boot up" in diagnostic mode showing engine rpms, DTCs, etc. I was wondering if my Jeep had this or if I would need to take it to an auto parts store or the dealer to see if it is throwing any DTCs.
The vehicle runs fine, but has intermittently started throwing up the Service 4WD System at random times, and I want to know if it is throwing a DTC or not so I can explore the flash option per the TSB.
Any information would be most helpful!
msasbill is offline
post #2 of 9 Old 10-25-2010, 01:42 PM
AJeepZJ
2006 WK
it MIGHT actually need service then, because i believe scheduled maintenance for the 4x4 system is every 75k miles.
All Gear, No Skill.
AJeepZJ is offline
post #3 of 9 Old 10-25-2010, 04:45 PM Thread Starter
msasbill
2005 WK
Anyone else want to weigh in on this?
msasbill is offline
post #4 of 9 Old 10-25-2010, 04:57 PM
stanton3
2007 WK
Autozone or some place like that should be able to pull any codes for you... but you can pull then up by yourself on the evic by going from Off-On-Off-On-Off-On with the key. Takes a while but you'll get it.
This is for a commander but its the same thing:
YouTube - Getting DTC codes in Jeep Commander
2007 WK 4x4 | OME HD 3" Lift | OME Shocks front + rear | 265/70/17 BFG All Terrains | 1.25" Wheel Spacers on stock wheels | Saguaro4xcomponents 5/8" Front recovery shackles | Aries Taillight Guards | PIAA 510 fogs in stock location | Midland 1001z Cb | Mopar Rear recovery hook | Rola Roof Rack |2 Hella 500ffs mounted behind grill | Firestick 3' Antenna | Saguaro Antenna Mount | Front Bumper Cut/Fender Trim | OEM Front suspension skid | 4xguard Front skid | Rusty's .5" Front Spacer | Lots more to come
Want to buy: 4xguard Rear Guard
stanton3 is offline
post #5 of 9 Old 10-25-2010, 05:47 PM
Walt
2008 WK
Codes are listed here: Jeep Grand Cherokee WK - Diagnostic Trouble Codes if you get any on the key trick. The top level codes are the ones that will display. Chrysler system has multiple trouble code levels and not all display in the EVIC.
The major ones do and that will get you started. If the MIL light is steady, it's OK to drive and should be looked soon. Flashing MIL is more urgent. Generally, 3 good "trips" and the MIL will reset, but trouble codes remain in memory.
One interesting common phenomenon lately is the '05 WK OEM batteries failing and throwing out wierd codes like this. If you go to Auto Zone, Advance Auto, or Sears, they can do a free battery capacity test to see if your battery is on the way out (presuming it is original). If you know that the battery is good or replaced recently, disregard.
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #6 of 9 Old 10-25-2010, 09:09 PM Thread Starter
msasbill
2005 WK
That is exactly what I was looking for thanks.
No DTCs, and the MIL was never on before, I just thought it was possible that the S4WDS message came up and stored a code without flashing the MIL.
I will definitely get the battery checked.
Outside of getting the battery checked, with no DTCs does it sound like it probably just needs to be flashed?
msasbill is offline
post #7 of 9 Old 10-26-2010, 08:50 AM
aliens8443
2008 WK
Does anyone know whether I can pull codes using the key method on a 04 WJ?
2004 Grand Cherokee Special Edition - Black, 4.0L I6
2010 Patriot - Silver, 2.4L I4, FD1
Ex - 2002 Liberty Limited - Blue, 3.7L V6
Ex - 2008 Grand Cherokee Limited - Black, 5.7L HEMI, QD2 (HEMI Club Member #50 Black WK Club Member #14)
aliens8443 is offline
post #8 of 9 Old 10-27-2010, 11:23 AM
Dreezy
1990 FSJ Wagoneer
There is a software update to get rid of the service 4wd light. I got mine done at a small town dealership for $40. I've had other shops want to charge over $100.
Dreezy is offline
post #9 of 9 Old 10-27-2010, 02:03 PM
stanton3
2007 WK
I think there is a similar way to do it in the wj's...search on their forum or start a thread over there. I think ive heard there is a way to do it, just dont remember it.
stanton3 is offline
diagnostic , service information
Anti-theft / alarm diagnostics 95ZJ-tilshedies ZJ Grand Cherokee Forum 1 02-11-2008 10:47 AM
Air Con / Heating Diagnostics kopite77 ZJ Grand Cherokee Forum 4 02-01-2007 04:49 PM
air bag diagnostics Tooms1121 ZJ Grand Cherokee Forum 0 10-07-2006 04:04 PM
Broken On Board Diagnostics (OBD) (1996 GC) Help! MacAllah ZJ Grand Cherokee Forum 1 09-16-2006 05:51 PM
On Board Diagnostics For Other Vehicles? Briandl ZJ Grand Cherokee Forum 1 06-07-2005 07:20 PM
