Seals and Leaks - JeepForum.com
post #1 of 13 Old 01-12-2013, 04:00 PM Thread Starter
Indian
2008 WK
Seals and Leaks
Hi,
I have a 2008 Jeep GC 4x4; took it for an oil change the other day and was told there were a couple of leaks; two to be exact:
1. Transfer Case Output Seal
2. Rear Pinion Seal
The dealer wanted about $240 each; parts and labor to do the job.
I was going to get a buddy of mine to do the job.
Has anyone had experience withe these repairs and have any thoughts on level of complexity etc......
Indian is offline
post #2 of 13 Old 01-13-2013, 06:51 AM Thread Starter
Indian
2008 WK
Bump.
Just wanted to check in with you guys to see if you could give me some words of advice before i get into it and regret not just going with the dealer.
I saw two youTube video's and it looked pretty straight forward; of course, everything looks easy when someone else does it.
Indian is offline
post #3 of 13 Old 01-13-2013, 10:54 AM Thread Starter
Indian
2008 WK
Bump Again.
After reading about this more i am now a little worried that my Rear Pinion Bearing may be worn and my have resulted in both the seals going bad.
Does anyone know of a Good Jeep Repair Shop for the seals and possibly the Rear Pinion Bearing in Northern Virginia Area.
Thank You in advance for any input.
Indian is offline
post #4 of 13 Old 01-13-2013, 01:01 PM
modernblueWK
Honestly i would say $240 is not too bad for those items. The trouble is you wont get out of there for less than $1240 most likely.
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #5 of 13 Old 01-13-2013, 07:41 PM
Walt
2008 WK
Originally Posted by Indian View Post
Hi,
2. Rear Pinion Seal
Both of my seals failed as yours did. Came from failing U-joints in rear drive shaft. All fixed under lifetime powertrain warranty.
Drive shaft is ~$1,100 if you buy it. U-joints are apparently not rebuildable on OEM shaft, so you must buy entire sub-assemly. Unable to address aftermarket drive shafts.
Recommend you have the rear drive shaft U-joints checked before seals are replaced and fail again (i.e., curing the symptom, not the problem).
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #6 of 13 Old 08-03-2013, 04:41 AM
jgc2006
2006 WK
Maybe the same problem here OR am I seeing some cracks in the pics ?
jgc2006 is offline
post #7 of 13 Old 08-03-2013, 06:17 AM
tom19511
2014 WK
I would say leak...
Tom
tom19511 is offline
post #8 of 13 Old 08-03-2013, 03:50 PM
Walt
2008 WK
input.
When the rear drive shaft is out to replace the rear pinion seal either you (or a mechanic) should check the U-joints. (Match mark the drive shaft and flange for later installation in the same balance orientation.) My rear drive shaft had no noticeable symptoms of failing, but the U-joints were getting loose after 5 years of routine service (no off-road).
If you just replace the 2 seals and the U-joints are failing, the seals will likely fail again. Not trying to scare you; just recommending inspection while the shaft is already out. BTW: It took about a week for the dealer to get my rear drive shaft delivered. You may wish to check availability in advance as they were on back-order about 1 year ago.
Walt is offline
post #9 of 13 Old 08-20-2013, 09:33 AM
jgc2006
2006 WK
Originally Posted by tom19511 View Post
I would say leak...
Pinion seal (#52070339AB) changed and no more leaks. 2 hours DIY job and the part was "only" 15 euros which was the total cost for the whole project
jgc2006 is offline
post #10 of 13 Old 08-20-2013, 11:20 AM
XK1982
2006 XK Commander
My rear pinion seal also leaks...has been for probably 2 years now. I'm sure with 112,000 I'm due for a new rear driveshaft. Doesn't leak enough to be worth replacing yet, fluid is never low.
2006 XK Commander, 4.7L V8, Quadra-Trac II, 6.25" Modified Superlift, Jeepin by Al's front UCA's, Rusty's Adjustable rear LCA's; 35x12.5R17 TOYO Open Country MT's; Method NV305 17x8.5 wheels
XK1982 is offline
post #11 of 13 Old 10-20-2015, 10:32 AM
BAH101
2008 WK
What size socket is required for the pinion nut?
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #12 of 13 Old 10-20-2015, 11:54 AM
Nejeep
I used 1-1/4" since I dont have any metric sockets that big. Worked fine for me.
Here are a couple of more tips. I had to use some heat to loosen up the red lock-tite on the pinion nut. Small propane torch for about 1 minute is all it took, dont over do it. You may need a puller to get the yoke off the pinion shaft too.
One more caution is be sure you have the correct seal for your diff. Jeep used 3 different differentials with different seals, Chrysler 8.25, Dana 35 and Dana 44. (Dont ask how I know)
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #13 of 13 Old 10-20-2015, 01:45 PM
BAH101
2008 WK
Thanks much for the socket size.
When I purchased the seal, the notes at the parts store said it was for the C213RE which is the QD2 rear.
BAH101 is offline
