Scootr29 Build Up - 2008 CRD QT2 - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Scootr29 Build Up - 2008 CRD QT2
Rubicon Express Suspensions from CCOR 706-207-4140Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955XHD Heavy-Duty Hood Latches for JK and TJ available at Oco
Unread 01-19-2012, 01:03 PM   #16
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Originally Posted by scootr29 View Post
Got these from UPS last night from JBA...also what a pleasant surprise to get a video about Jesus...
Those JBA UCA's look much beefier than the stock arms. I'm guessing they can really take a beating and will last forever.
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is offline   Reply With Quote
Unread 01-19-2012, 02:13 PM   #17
scootr29
scootr29's Avatar
2008 WK
I agree on the thickness...trying to do as much as possible to make this Jeep last for a long time.
Also ordered a set of these....greaseable tie rod ends...they look stronger than OEM. I am trying to upgrade as much as possible and just get one alignment. Other than replacing bushings and the lower control arm....anything other wearable item I should look at replacing. I was thinking about the bushings for the sway bar, but I can do that after an alignment.
Silver WK Club Member #1
2008 CRD QT2
scootr29 is offline   Reply With Quote
Unread 01-19-2012, 02:57 PM   #18
JeepN4KC
JeepN4KC's Avatar
Well your rotors will eventually wear out. Your axle half shafts will too. And your swaybar and your sway links and your steering rack and .....
~Mike~
My Build Thread WK
~RED WK CLUB #7~
Unread 01-19-2012, 04:43 PM   #19
scootr29
scootr29's Avatar
2008 WK
Yea I know that...but just thinking of things to do since I will have everything torn down...I do have new rotors.
2008 CRD QT2
Unread 01-19-2012, 04:51 PM   #20
JeepN4KC
JeepN4KC's Avatar
The rotors are really the only thing I could think of. You'll have all the wheels off anyway and alot of the suspension disassembled so if you have the $'s you might as well smack the current one's off and put some newer aftermarket rotors. Only thing is, are your current rotors in bad shape? Are the new rotors you're talking about already on the rig?
~Mike~
My Build Thread WK
~RED WK CLUB #7~
Unread 01-19-2012, 04:55 PM   #21
scootr29
scootr29's Avatar
2008 WK
I got new fr/rear Stillen drilled rotors and pads waiting to go....
2008 CRD QT2
Unread 01-19-2012, 04:58 PM   #22
JeepN4KC
JeepN4KC's Avatar
Dude, it sounds like the only thing left is to put this badboy together once everything is delivered.
~Mike~
My Build Thread WK
~RED WK CLUB #7~
Unread 01-19-2012, 05:04 PM   #23
scootr29
scootr29's Avatar
2008 WK
Maybe I should get drunk and post something bad about Kolak and yell at him for not hand delivering my OME lift....
j/k
Yea I have been saving up for a while.....and now is the time to just do it all at one time.
2008 CRD QT2
Unread 01-20-2012, 09:32 AM   #24
BAH101
2008 WK
My lift came in 4 boxes, unfortunately, I only got 3 in the first delivery. I live in northern Ontario and have the items delivered to a border store, so that made two trips. Unfortunately, Kolak could not provide the shipping numbers, as they are shipped from different area. But, I'd did find out how to get them from a partial shipment (UPS anyways) there is a reference number on the UPS tag, so you can type that into their website and it will bring up all the items for that shipping lot. Just in case you were wondering. But it did save me unnecessary trip cross the border.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline   Reply With Quote
Unread 01-23-2012, 01:48 PM   #25
scootr29
scootr29's Avatar
2008 WK
More stuff from the big brown truck....
Greaseable tie rod ends....
5 Duratracs....they are better in person and set of OME springs....
2008 CRD QT2
Unread 01-23-2012, 06:25 PM   #26
TangoTango
2008 WK
Which OME lift did you get (in inches) ?
I have an 08 and my fog lights are white... you fogs look yellow, are the yellow or is that just the camera?
TangoTango is offline   Reply With Quote
Unread 01-23-2012, 06:36 PM   #27
scootr29
scootr29's Avatar
2008 WK
I went with the OME HD....I think it is listed as 2.5"
And my fogs are yellow...I bought yellow bulbs and yellow vinyl...they are ok...more cosmetic than anything.
http://www.lamin-x.com/Jeep-Grand-Ch...ers-p/j105.htm
2008 CRD QT2
Unread 01-23-2012, 06:40 PM   #28
AJeepZJ
2006 WK
Those Duratrac's sure look mighty tasty. What size you get those fat meats in?
edit: nvm - I read you got 265/70/17's... I can't wait to see how this turns out...
Have you already done your pinchweld and fender trim mods??
All Gear, No Skill.
AJeepZJ is offline   Reply With Quote
Unread 01-23-2012, 06:42 PM   #29
scootr29
scootr29's Avatar
2008 WK
265/70/17....they are awesome looking and cant wait to get everything put on......
2008 CRD QT2
Unread 01-27-2012, 05:32 PM   #30
scootr29
scootr29's Avatar
2008 WK
Got the Duratracs mounted this afternoon....still waiting on the OME struts and shocks...Kolak is going to drive me to drinking.
Also got me 2 new smittybuilt front shackles, a fumoto quick drain valve for the oil pan, some new black lugnuts, and a new oil-less aFe panel filter that was a mofo tight fit.....also installed a new cabin filter and some new windshield wipers.
That is all for now...oil change, pinch weld and fender trim this weekend....hopefully lift in next weekend...
2008 CRD QT2
