Schwo's WK Build - Page 4 - JeepForum.com
post #46 of 153 Old 06-05-2012, 12:03 AM Thread Starter
Schwo
2005 WK
Originally Posted by azredneck View Post
Keep me updated, I asked a question about the same tuner and have yet to receive any response whatsoever. Thanks everybody else...
I'll post my thoughts as I get familiar with it, but yea, everything I read seemed positive as well. It seems like Superchips is really focusing on the Jeep market and not just the speed racers.
SCHWO
Black '05 WK Hemi & '76 CJ5 AMC 304 V8
WK Build Thread:
Schwo is offline
post #47 of 153 Old 06-05-2012, 12:09 AM Thread Starter
Schwo
2005 WK
Also, I found a tb spacer that actually gave substantial differences in mileage...
At some point I'm gonna run the dyno withand without just to see if there are any measureable differences, but did you see any actual gains with the airraid spacer other than sound?
Are you working with the Hemi? I don't think they make a TB spacer for it...
As for the Airaid, I can't honestly say I've noticed an improvement in performance. I installed the CAI almost immediately after buying my Jeep in 2005, so not much to compare the 'before' and 'after' with. As for mpg, I think my right foot is most of my problem Sure sounds sweet though.
SCHWO
WK Build Thread:
Schwo is offline
post #48 of 153 Old 06-05-2012, 01:37 AM
snoblade80
2008 WK
Using the mileage tune on long trips I have seen +2 or so mpg. I have seen no real gain in mpg using the performance tunes but more power and better response with the skinny pedal. Most of my driving is short trips and lots of on and off the gas.
2008 WK 4.7L Rocky Mountain | STOCK
snoblade80 is offline
post #49 of 153 Old 06-05-2012, 02:38 AM
viperman96
2005 WK
Nice build so far. I really wanted a black WK when I bought mine a few months ago. But, living on a gravel road isn't very condusive to having a clean vehicle for very long.
2005 WK Limited Hemi-Rough Country 2" BB,Spidertrax 1.5" spacers,Moabs w/ BFG Mud terrains 255/75/17,Mopar cai,Diablosport Predator tune,Taylor shortie wires,Monroe LL shocks,Monroe Reflex struts,Flowmaster Super 44 muffler w/ rolled tip(no res.)
viperman96 is offline
post #50 of 153 Old 06-05-2012, 07:25 AM
azredneck
It's the Taylor Helix throttle body, and I'm fairly positive they make a hemi application, but'm actually outta town for another day, but when I get back, I'll talk to my buddy at the speed shop I found it at.
My lil bro tossed the airraid on his 07 mustang and he likes it, but he's really heavy-footed.
Taylor is a 3/4" (1"?) spacer, thicker than most, and a different method of changing the air flow.
azredneck is offline
post #51 of 153 Old 06-05-2012, 11:54 AM
azredneck
Yes, they do have applications for the 5.7 and 6.1 hemis, though the 5.7 is for other mopar apps, but if it's the same throttle body...
post #52 of 153 Old 06-18-2012, 09:17 PM Thread Starter
Schwo
2005 WK
So this past weekend my buddy and I installed my OME HD package. Well almost all of it. 3 of the 4 corners done. The right, front bolt that holds the strut fork to the lower control arm was seized. We banged, heated, cooled and repeated to no avail. Wish I had a blunt impact chisel... My other buddy who owns a shop is now doing the final corner, which blows b/c I'll have to pay him. Oh...and my camera broke. Pics to follow. I love the amount of new clearance...in 3 corners at least
SCHWO
WK Build Thread:
Schwo is offline
post #53 of 153 Old 06-18-2012, 09:46 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Haha! Three corners, nice! That does suck but at least it will be finished soon
Omelet is offline
post #54 of 153 Old 06-18-2012, 10:10 PM Thread Starter
Schwo
2005 WK
Has anyone noticed whether your rear OME springs are the same exact height? I installed mine this weekend and noticed one about 1/2" taller than the other. Both have the same model number and I cross checked them with the OME manufacturer's application list to make sure they were the correct ones for the WK, but one has an 'A' on the sticker and the other a 'B' so I wasn't sure if they were a right and left. I installed the taller one on the driver side in case it's meant to compensate for the driver's weight...I'll have to let them settle to see if they even out. I wasn't sure if I have a slight taller spring due to manufacturing error or if they are meant to be that way...
Ok, so I just found this online at ARB (I guess I made the logically correct choice):
"A/B Fitment
As a general rule, the A springs have a higher free height than the B coils. This is to allow the fitter to compensate for driver weight, aftermarket accessories, vehicle weight distribution, and chassis twist. We suggest taking measurements at each corner before fitting the new suspension components. This will allow for more accurate A/B fitment.
In vehicles with front and rear A/B springs, most of these vehicles will be happiest with an A coil fitted to the front, driver corner and the opposite rear, passenger corner. In vehicles with only rear A/B springs, most will end up with the A spring on the rear, driver corner.
It must be understood that due to the A/B variation, the first spring selection may result in the vehicle to be unlevel. If this is the case, swapping spring locations is necessary before trying other trimming methods."
SCHWO
WK Build Thread:
Schwo is offline
post #55 of 153 Old 06-18-2012, 10:17 PM
kllshadow
2006 WK
Possibly because the gas tank is on the drivers side on wks. That's just a guess though.
Sent from my EVO using JeepForum
Black WK Club Member #61
kllshadow is offline
post #56 of 153 Old 06-18-2012, 10:39 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Yep you did it correctly! A = Driver B = Passenger
Omelet is offline
post #57 of 153 Old 06-19-2012, 12:37 PM Thread Starter
Schwo
2005 WK
talked to my mechanic. he couldnt get the bolt out either so he just removed the entire LCA with the strut fork still connected.
SCHWO
WK Build Thread:
Schwo is offline
post #58 of 153 Old 06-19-2012, 01:43 PM
06WKHEMI
2006 WK
If i were you I'd just keep soaking it with Pb blaster every day for like 2 weeks and try and get it out just so you can put some anti seize on it to make it easier for future work.
2006 Black wk overland HEMI QDII. OME HD bilstein struts with 58643 monroe load levelers RRO uca, afe cold air intake,hella 500FF behind grille, RC 1.5 wheel spacers s4xc cb antenna mount with 5ft firestik and midland 1001wx CB,265/70-17 falken rockymountain ats, pinch weld mod, door lock mod, Rola basket with 2 Hella 500 FF`s.
06WKHEMI is offline
post #59 of 153 Old 06-19-2012, 06:50 PM Thread Starter
Schwo
2005 WK
i do plan working it free. maybe i'll get it out when its time for a Superlift...
SCHWO
WK Build Thread:
Schwo is offline
post #60 of 153 Old 06-23-2012, 10:33 PM Thread Starter
Schwo
2005 WK
Picked my baby up last night. Love the gain in clearance. Now I need some new rubber. I'll stick with 265/70R17s just need to figure out which ones. Thankfully the wheels and tires thread exists.
My special edition OMEs:
SCHWO
WK Build Thread:
Schwo is offline
Bumper Build Project For my 95 ZJ: Build Time- 1 Month TMNT2210 ZJ Grand Cherokee Forum 43 09-10-2015 12:57 PM
ZJ Build WVU-ZJ ZJ Grand Cherokee Forum 12 12-21-2011 07:24 PM
96 ZJ Build Cody96ZJ ZJ Grand Cherokee Forum 0 11-08-2011 04:25 PM
Fbi (offroad build inspeter) build 93zjFBI ZJ Grand Cherokee Forum 8 12-18-2010 11:43 PM
My '96 ZJ build brady1604 ZJ Grand Cherokee Forum 0 11-20-2010 11:15 AM
