School me on load range E tires - JeepForum.com
post #1 of 27 Old 12-01-2011, 09:32 AM Thread Starter
SSF556
2008 WK
I really like General tires....looking at getting a set of Grabber AT2. Currently the load range E is the only range that is rated for severe snow. Being in the SC and making trips to MI I need a tire that goes in snow.
The tread patterns on the different loads look the same to me......
Also the E tires max tire pressure is higher//80psi...do I still run them at the manufacturers suggested psi?
Is the load range E overkill? Seems like it would be unless you are hauling lots of weight.
Thoughts/opinions.....http://http://www.tirerack.com/tires/tires.jsp?tireMake=General&tireModel=Grabber+AT+2& sidewall=Outlined%20White%20Letters&partnum=67SR7G RAT2OWLV2&tab=Sizes
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #2 of 27 Old 12-01-2011, 09:47 AM
JRLT
2010 WK
This might not be standard for every tire but I came across this when I was researching my Nittos:
Technical specs are subject to change without notice.
LT tires with a "C" load range have a 6-ply rating. LT tires with a "D" load range have an 8-ply rating.
LT Tires with an "E" load range have a 10-ply rating.
*Indicates Extra Load (XL)
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #3 of 27 Old 12-01-2011, 12:03 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
That's the same info I have found.
I would say a load range "E" would be overkill for the weight and towing capacity of a WK. I most often see load range "E" on bigger, heavier pickups with a big block diesel and/or snow plow set-up, bigger hauling/towing work trucks and the like. Not that you couldn't put them on your GC, but to give a point of reference, my uncle pulls his TJ on a 20ft trailer with a quad cab Chevy 3500 diesel that he runs 10ply load range E tires on. Obviously, this Chevy is a larger, heavier rig than a WK and the truck hauls/pulls much larger loads. I think on a WK these same tires would feel like they were made out of concrete.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #4 of 27 Old 12-01-2011, 12:07 PM
06WKHEMI
2006 WK
I know that my falken rocky mountains are load range e but ya they are totally overkill
2006 Black wk overland HEMI QDII. OME HD bilstein struts with 58643 monroe load levelers RRO uca, afe cold air intake,hella 500FF behind grille, RC 1.5 wheel spacers s4xc cb antenna mount with 5ft firestik and midland 1001wx CB,265/70-17 falken rockymountain ats, pinch weld mod, door lock mod, Rola basket with 2 Hella 500 FF`s.
06WKHEMI is offline
post #5 of 27 Old 12-01-2011, 12:24 PM Thread Starter
SSF556
2008 WK
OK...well the Grabber AT2 is not an option. Need to have tires that are snow approved.
2008 CRD QT2
SSF556 is offline
post #6 of 27 Old 12-01-2011, 12:27 PM
sk1er18
2007 XK Commander
Nothing wrong with running an E rated tire on a vehicle like this. Its only a problem when the owner grossly over inflates the tires because he thinks they're supposed to be run at max pressure.
Per the TRA load vs inflation charts, 35-40 psi is plenty for all of the common sizes we run on our vehicles here. Anything over 40 is overkill for daily driving.
I run mine at 36-38 and bump them up to 42ish for towing. For my tires (245/75/17) they can handle more than my rear GAWR at that PSI.. so if I'm not worried about overloading my axle, I'm not worried about the tires.
-Matt
sk1er18 is offline
post #7 of 27 Old 12-01-2011, 12:30 PM
JRLT
2010 WK
There are a lot of gravel roads where I live and almost every rancher & farmer that live off of a gravel road buy tires based on the number of plys, more the better; guess the gravel just beats up tires.
Everything else is secondary.
JRLT is offline
post #8 of 27 Old 12-01-2011, 01:05 PM
06WKHEMI
2006 WK
Take a look at the falken rocky mountains they are great tires and they are m+s as well and very reasonably priced
06WKHEMI is offline
post #9 of 27 Old 12-01-2011, 01:16 PM
LJS8510
LJS8510's Avatar
2015 WK
I road with E rated BFG's on old WJ. They are very tough tire, I got them after puncturing a few sidewalls offroading I never had that problem again. The downside is a rougher everyday ride.
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #10 of 27 Old 12-01-2011, 01:18 PM
yzjwk
2005 WK
I assume your lifted with spacers if your going to that size but You could just go 255/70/17 . Not going to be that much difference . i have the Gen at2 on my zj . best tires i've ever had .I have winter only tires on my Wk and the gens beat them hands down on snow and/or ice . now i wish i had bought them for the wk.
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #11 of 27 Old 12-01-2011, 04:11 PM
Drew
2007 WK
Pro: More heavy duty/durable for the trails or heavier vehicles, slightly better tread life.
Con: Heavier tire, slightly rougher ride, costs a bit more, have a tendency to get out of balance quicker
Drew is offline
post #12 of 27 Old 12-01-2011, 04:20 PM
Budasac
2005 WK
We run the "E" tires on our work vans. E-350 Super Duty's with 2 tons of crap in them. I would think if you wheel alot you may want to invest in the E's, they're tuff as hell. Like LJS stated, less chance of puncturing a sidewall. I would have gotten them for the WK but there was a big difference in price and I couldn't justify it. I wouldn't feel safe with anything less on the work truck but, I don't think they're needed for a Jeep.
They certainly couldn't hurt anything though.
Budasac is online now
post #13 of 27 Old 12-01-2011, 05:18 PM
SmallsWk
2007 WK
I have the "E" Falken Wildpeaks (rocky mountains, same thing) and have had them through a winter and working on my second. I also have done 2k+ road trips with these tires in snow and they went just fine.
In my opinion, this is a grossly under-rated tire for all the abuse I've put my through they look no worse for wear. I know of at least two other people in my jeep club that run them also and put them through the same abuse.
07 4.7WK: [RC BB][265/70 WildPeaks][Moabs][3 Ft. Firestick][S4xc Shackle Mounts and CB][Cobra 19][FlashPaq]
SmallsWk is offline
post #14 of 27 Old 12-01-2011, 06:08 PM
84foxgt
2007 WK
You have no need for a set of tires that can support 12000 lbs of weight when inflated to 80 psi. Goodyear Wrangler Silent Armor. An awesom A/T tire that also has the mountain snowflake rating. Which means that is some states where actual snow tires are required to be used on some roads, the silent armors are rated the same as those snow tires. You can run them all year long and they carry a 50k treadlife warranty. "E" load range tires ARE NOT bullet proof or puncture proof. For that matter, silent armors have a layer of kevlar in the tread to help absorb impacts over bumps and the sidewalls are constructed stiffer than your standard "P" series tire. Not to mention "E" tires are alot heavier which means it takes more to turn them, killing whatever fuel mileage you had left. Just remember, more is only better in sex and money.
84foxgt is offline
post #15 of 27 Old 12-01-2011, 06:19 PM
Budasac
2005 WK
Originally Posted by 84foxgt View Post
You have no need for a set of tires that can support 12000 lbs of weight ........ Just remember, more is only better in sex and money.
Well, there ya go.
Which load range tire to use. DYNOGUY WK Grand Cherokee & XK Commander Forum 2 09-15-2009 10:05 PM
Load range D or E tire people... gman1322 ZJ Grand Cherokee Forum 3 06-29-2009 08:24 PM
anybody run load range e tires on their jeep? 99grand4.0 ZJ Grand Cherokee Forum 17 10-25-2007 11:17 AM
Load Range "E" Tires. taterthedog ZJ Grand Cherokee Forum 11 05-26-2007 07:12 AM
what load range tire are you running? askoop ZJ Grand Cherokee Forum 3 07-08-2005 11:19 AM
