Saguaro hidden winch mount and Talon 9.5 - Page 2 - JeepForum.com
post #16 of 21 Old 06-16-2013, 07:31 PM Thread Starter
Pac Man
Pac Man's Avatar
2007 WK
Thank you
The engagement lever is easily accessible. I was worried about that too, so I emailed superwinch and they told me this winch could be powered out all day long with no adverse affects. You can see the whole winch and lever if you just look up in the bottom grille (Where the factory tow hooks would be).
I have a tree saver and snatch block on the way. I really want to see how powerful this winch is... I'm curious if it will drag my jeep across pavement if I stand on the brakes.
2007 Black Grand Cherokee
Hemi - QDII - OME - S4XC Hidden Winch Mount -Talon 9.5SR - Full Matrix - 265/70/17 Duratrac's - Pintlers- Superchips - Magnaflow - Airaid - 5000k HIDs - Lightforce HID's - 4xG Front Guard - 4XG Diff Cover
Pac Man is offline
post #17 of 21 Old 10-08-2013, 11:15 PM
94jeepman
2005 WK
I was just talking about doing something like this whith my friend but didn't know if the front brace could be cut out and now I know
94jeepman is offline
post #18 of 21 Old 11-17-2013, 06:18 PM Thread Starter
Pac Man
Pac Man's Avatar
2007 WK
I used a 3/8 spot weld cutter from harbor freight. It worked great to cut out the 30 or so spot welds that hold the front crossmember on. On a side note now that the matrix mounts to this new 1/4" steel crossmember I feel that the front end of the jeep and matrix are significantly stronger than they were.
Pac Man is offline
post #19 of 21 Old 11-17-2013, 08:41 PM
94jeepman
2005 WK
Probably 200 times stronger
post #20 of 21 Old 11-18-2013, 11:35 AM
Red_liner740
Will this winch mount work with the CRD? The CRD has the intercooler sticking out infront of the rad...
Red_liner740 is offline
post #21 of 21 Old 11-18-2013, 11:38 AM
BAH101
2008 WK
Nope. There is not enough clearance unfortunately. I asked a while back and took measurements.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
