Rusted Diesel Tank - Lots of Pics - Page 4 - JeepForum.com
post #46 of 65 Old 08-14-2014, 09:52 AM
SSF556
2008 WK
My 2008 CRD has a steel fuel tank...verified with a magnet
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #47 of 65 Old 08-14-2014, 11:29 AM
Radcrd
2007 WK
I believe they are ALL steel. The guys claiming theirs are plastic may be thinking they are due to the rubberized coating applied to the tank making it feel like plastic. I have been hearing more and more stories of the rusted out fuel tanks. Seems like they may be all doomed eventually....
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #48 of 65 Old 08-14-2014, 01:09 PM Thread Starter
ryann04
2008 WK
I've helped two people locally with the same issue so far. So it seems to be common
2008 - Jeep Grand Cherokee - 3.0L CRD - Quadra Drive II - GDE Hot-Tune - OME HD Lift Kit - OEM Full Steel Skids
Blue WK Club Member #42 // DIESEL FTW !!!! -Ryan
ryann04 is offline
post #49 of 65 Old 08-14-2014, 01:35 PM
tnadanzig
tnadanzig's Avatar
2007 WK
They are all steel. I pulled mine a month ago or so and it didn't look to bad. The skid had small amount of dirt in it, but overall pretty good shape. Its easy to see how they can go bad pretty quick once enough salt and junk gets in between the tank and the skid.
CB Engineering
CB-engineer.com
2014 WK2 EcoDiesel - CBE Parts
2008 3.0L CRD WK LTD - GDE Tune 3.07 gears
2007 3.0L CRD WK LTD - Go Fast Parts
2005 KJ CRD - GDE Tune
tnadanzig is offline
post #50 of 65 Old 08-14-2014, 02:47 PM
BAH101
2008 WK
So, when are you going to be building replacement tanks?
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #51 of 65 Old 08-14-2014, 03:56 PM Thread Starter
ryann04
2008 WK
My thoughts exactly.
I wish someone would make a urethane version of them.
ryann04 is offline
post #52 of 65 Old 08-14-2014, 07:20 PM
Tango.
2008 WK
I think either some por-15 or that bedliner stuff on the bottom before it rusts would help alot. tanks are not cheep.
Tango. is offline
post #53 of 65 Old 08-14-2014, 08:13 PM
caddydaddy
2007 WK
That's what I plan to do to my tank before Winter gets here!
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
198,000+ miles!
caddydaddy is offline
post #54 of 65 Old 08-15-2014, 09:38 AM
tnadanzig
tnadanzig's Avatar
2007 WK
Well, I have a design for a new tank, but it goes in place of the spare tire for my 4 link kit.
If a mold wasn't so expensive, I would entertain a rotational molded tank. I worked as an intern for two years in college at a rotational molding company and still have some connections there. I should see how much it would cost for a mold. My guess it would be close to 10K as they are made from cast aluminum.
CB Engineering
CB-engineer.com
post #55 of 65 Old 08-15-2014, 10:41 AM Thread Starter
ryann04
2008 WK
What's the damage on the tank that goes in the wheel well? Sounds interesting.
ryann04 is offline
post #56 of 65 Old 08-15-2014, 01:02 PM
tnadanzig
tnadanzig's Avatar
2007 WK
At the moment, I have no idea. I have it drawn up in CAD and a rough BOM for it. That's about it.
CB Engineering
CB-engineer.com
post #57 of 65 Old 08-15-2014, 03:39 PM
Tango.
2008 WK
I'm very interesed in a 2nd tank as secondary aux. tank that can re-fuel the primary for more range.
Tango. is offline
post #58 of 65 Old 08-20-2014, 03:47 PM
oldsmoke
2009 WK
Shame on Jeep for not giving us a plastic fuel tank. A plastic tank protected by the steel skid would have been the proper way to do it. This is really shoddy engineering.
Diesel Ecotune-DPF, 32" tires, 2" lift. 4xGuard bib, tow hooks
oldsmoke is offline
post #59 of 65 Old 08-20-2014, 08:07 PM
tnadanzig
tnadanzig's Avatar
2007 WK
It could be used as a secondary tank, it was going to be designed as a primary tank for those who want to get rid of the stock tank. I am slowly going to build my Jeep to make more rear travel than the stock control arms can handle and want a wider axle so I will need to put in a four link. I will build the tank to fit in between the stock rear cradle. I can easily make it possible to put in a transfer pump to allow you to fill the stock tank. I will probably make me a one off as I have built a new rear cradle that is quite a bit different than stock and allow me to run a larger tank. I really want about a 35-36 gallon tank so I can go 800 miles or so on one tank.
Jeep should of built a plastic tank, but with I am sure like everything it came down to cost and it just wasn't going to happen. The cost of plastic tank to have a low level of permeability to fuel evaporation is high compared to a steel tank. This issue was starting to get more talk when I used to work in the industry.
CB Engineering
CB-engineer.com
post #60 of 65 Old 08-23-2014, 08:47 PM
Xmind
2007 WK
Since my Jeep is around the same age and has obviously seen a lot of salt by all the rust underneath the vehicle, I decided to drop my tank and POR-15 it...and the rest of my under body.
I've barely started, but just a heads up for anyone else attempting this, you'll likely need one hell of an impact gun. My cordless wouldn't budge the 18mm (closest socket that fit) bolts that hold the straps in place. I had to bust out the Ingersoll Rand Titanium 1/2 inch impact gun to get them to move...but they did move unlike the skid plate bolts that snapped off last year.
Also, unless someone has some tricks that I couldn't think of, it would appear you have to disconnect at least one side of the rear prop shaft to access the front most bolt.
The fuel lines are easy to disconnect. Only one had an additional locking red tab that needed to be pulled out, all others just have a press in button to release the connections.
'07 GC CRD QDII, EHM, GDE ECO, DPF & intake rez delete, Paramount Perf Valve Body, Roof drain mod
Xmind is offline
