Rust Removal on the Hitch Reciever - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Rust Removal on the Hitch Reciever
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! The Ruffstuff 9" Disc Brake brackets!Even Better Heim Pricing! From Ruffstuff
Unread 05-17-2015, 09:36 PM   #1
JeepHemi4x4
This is my first time posting so any help is appreciated! I have been trying to get rid of the rust in the Receiver and around it. Anyone have a good way of grinding it all off and painting it? Whats the best way to make it look best and to rust the least?
Thanks for the help guys!
JeepHemi4x4 is offline   Reply With Quote Quick reply to this message
Unread 05-21-2015, 10:42 AM   #2
ryankokesh
I've heard good things about Loctite rust remover. But I just used a wire brush attached to a drill on it and then rattle canned it with rustoleum. So far so good.
ryankokesh is offline   Reply With Quote Quick reply to this message
Unread 05-21-2015, 02:22 PM   #3
JackB1
2008 WK
After removing all loose rust you can use rust converter followed by Rustoleum. I then stuck a couple squares of Velcro inside the tube to stop rattling as well as chipping.
JackB1 is offline   Reply With Quote Quick reply to this message
Unread 05-21-2015, 09:56 PM   #4
JeepHemi4x4
Alright. Thanks guys!
Unread 05-22-2015, 06:28 AM   #5
T1m
2006 WK
I used POR-15 to restore a motorcycle gas tank that was thoroughly rusted.
Before:
After:
T1m is offline   Reply With Quote Quick reply to this message
Unread 05-22-2015, 06:50 AM   #6
ggrassmid
2008 WK
That's the inside of the tank? is POR15 about to be direct contact with gasoline? I don't know if I would put that inside my tank. There are specialy tank sealant products for use on the inside of fuel tanks for aircraft and such, I would use that before using an external frame type sealer inside a fuel tank. JMO
Black 2008 Limited CRD
GDE Eco, EHM, 2014 Rubicon take-offs
JF Black WK Club #168
ggrassmid is offline   Reply With Quote Quick reply to this message
Unread 05-22-2015, 07:59 AM   #7
brentwoodkris
2005 WK
POR15 is pretty much the benchmark for use in motorcycle fuel tanks, and fuel tanks in general.
brentwoodkris is offline   Reply With Quote Quick reply to this message
Unread 05-23-2015, 12:45 PM   #8
T1m
2006 WK
Thank you, I did a lot of research and this was the best option for my usage and it worked just as advertised.
Keep in mind that I did not have any pin-hole leaks or structural degradation of the tank. Otherwise I would've gone with a bladder type solution or would've purchased a new tank. The bladder stuff is iffy at best, so if the POR-15 didn't work I would probably have bought a new tank.
OP - Keep in mind that using POR-15 is a multi-step process and may not be the easiest option for use on a hitch, although it would work. If you can wire-wheel the rust away and then paint, I would go for that. Easy Peasy...
