Rust Hole by fuel door. - JeepForum.com
post #1 of 7 Old 10-12-2017, 12:55 PM Thread Starter
JEEPMAN123
2010 WK
Hello, I have a 2010 Jeep GC Laredo 3.7L . I wash my Jeep regularly, wax it etc. I live in New England but take care of my Jeep. I have owned it for 5 years. Well, one day I noticed some bubbling in the paint below the fuel door. A small patch probably the size of a half dollar.
Well, I had the genius idea of taking my dremel and sanding down the oxidized paint and what little surface rust there was. Well, bad idea! I used the dremel with slight pressure to grind the paint down, then it sunk right into the panel. The sheet metal was as thick as wet paper. It was completely rusted. I ended up creating a huge hole. I filled it with bondo, painted it etc. The sheet metal will need to be cut and replaced.
Has anyone else had this issue on their WK? My father has a 06 WK and his is rusted completely though in the same spot. He just paints the rust white to match his jeep.
JEEPMAN123 is offline
post #2 of 7 Old 10-12-2017, 06:13 PM
JackB1
2008 WK
It sounds like salt slush is being thrown by the tires up into that area. If so you are going to have to wash that area out carefully. Same for the wheel well lips.
JackB1 is offline
post #3 of 7 Old 10-13-2017, 04:31 PM Thread Starter
JEEPMAN123
2010 WK
I know its odd, I wasn't sure if any other NE Jeep owners have the same problem. I also have the Jeep mud flaps installed.
post #4 of 7 Old 10-16-2017, 05:12 AM
caulk04
2008 WK
I saw this posted a while back, someone found the same problem with theirs. I forget exactly what was catching debris and causing the corrosion there, but it seemed to be a bit of a fluke.
My best recommendation is to always get your vehicles coated yearly with Fluid Film or another WELL KNOWN rust preventive. Not rubberized undercoating! The earlier you start the better.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #5 of 7 Old 10-16-2017, 05:15 AM
caulk04
2008 WK
http://www.jeepforum.com/forum/f67/2...arter-2816258/
caulk04 is offline
post #6 of 7 Old Today, 04:49 PM Thread Starter
JEEPMAN123
2010 WK
Thank you for posting that. It explains a lot. That same foam is applied to the challengers in the rocker panels as well. I know Challenger owners have had problems with the foam getting wet and rotting from the inside out. Looks like Jeep made a ticking time bomb unless caught in time. My Jeep was never garaged until recently, so the foam just soaked wet from December until May.
post #7 of 7 Old Today, 07:11 PM
SteveROntario
The Dodge Rams of those years had the same foam up above the rear wheel arches. None of the Dodge trucks around here have rear fenders as a result. Better than a rotten GMC frame or a blown PowerStroke but still very annoying.
Steve
SteveROntario is offline
