RRO to OME ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > RRO to OME ?
Genright at JeepHutMemorial Day Weekend Sale Starts Friday-Tuesday 10% off + New DEAL OF THE WEEK at ROCKRIDGE 4WD!
Unread 02-13-2010, 06:37 AM   #1
Mickey63
2006 WK
RRO to OME ?
Made a few searches and read back through a good few posts but couldn’t find anything..
Has anybody swapped from a RRO lift to OME ? If so do you mind answering a few questions ?
Did you notice a difference in lift height, higher, lower or the same.
what do you think of the ride compared to the RRO lift ?
Also would someone with an OME lift be kind enough to measure from the bottom of the wheel arch to the centre of the wheel and supply me with the figures. (fender to spindle)
Thanks
Mickey63 is offline   Reply With Quote
Unread 02-13-2010, 04:05 PM   #2
ctate
2007 WK
I went from a Revtek lift to OME and the ride is wayyyy better. The height is a bit higher. Probably like a .25 in. Ill check the measurements for you when I get a chance.
07 Silver 3.0 CRD, Clifford matrix 50.5x remort start/turbo timer, 265/70R17 Goodyear DURATRACS, XD Series Spy wheels, OME Lift Kit, Kenwood navigation system with reverse camera, Inmotion tuned, Amsoil air filter, Fitch fuel catalyst, Air Lift suspension air bags with air compressor, P3 brake controller, MBRP Exhaust, Accu Pro Calibrator, Addco front/rear anti sway bar, Husky Liner floor mats, upgraded air intake tube, Quick Oil Drain Valve.
ctate is offline   Reply With Quote
Unread 02-13-2010, 05:28 PM   #3
Mickey63
2006 WK
Thanks ctate, I would appreciate that...
Unread 02-14-2010, 01:30 PM   #4
ctate
2007 WK
The front is 22in and the rear is 21in.
Unread 02-14-2010, 03:19 PM   #5
Mickey63
2006 WK
ctate, thanks for the measurements, looks like the OME might give me a little more lift it's not much of a difference but it's there..
Your OME 22 front, 21 rear, My RRO 21-3/8 front, 20-5/8 rear.
Unread 02-15-2010, 06:38 AM   #6
BonesWK
2006 WK
you could just swap out the back end for OME... the only weak part about RRO is the rear spacers, from what I hear. Im running RR lift with no problems yet, but if I do encounter problems I will swap out the spacers for OME coils (I already have the shocks on)
edit: unless you already have the money to buy the OME lift, that is... im poor.
Ryan
2006 Black WK Limited 4.7 4x4 QD II -- RR 2.25" Lift - JK Moabs - 32" BFG M/T - Rear OME Shocks - AFE Stage 2 Intake - Saguaro 4x Front Shackles - 1-1/2" Wheel Spacers - Tail Light Guards - CB - 4' Firestik - Rola Roof Rack - Exhaust
If you want to achieve greatness, stop asking for permission
Chive On
BonesWK is offline   Reply With Quote
Unread 02-15-2010, 09:19 AM   #7
Mickey63
2006 WK
I'm poor as well
Changing only the back end out is a good Idea, unfortunately I've just been given an advise notice during my yearly ministry of transport inspection (MOT), the front passenger shock/strut has just started to weep fluid so will need changing out at some time (gotta do both at the same time), I thought rather than replace with originals or bilstiens, I'd find a bit extra cash some-where and go OME.
Just wanted to know if the ride & height were different.
