Rpm at 65 mph - JeepForum.com
post #1 of 11 Old 06-24-2013, 09:48 AM Thread Starter
jrv8984
Rpm at 65 mph
When you are cruising at 65 mph, what's your tachometer reading. I am around 2300 rpm. It seems high to me.
Thanks
07 GC CRD 4x4
jrv8984 is offline
post #2 of 11 Old 06-24-2013, 09:51 AM
twistedlizard72
2007 WK
My WK has a Superlift and 285/70's (speedo corrected) and turn about 1700 to 1800 RPM at 65.
Kevin K.
twistedlizard72 is offline
post #3 of 11 Old 06-24-2013, 10:21 AM
modernblueWK
1850-1900
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #4 of 11 Old 06-24-2013, 11:50 AM
NDSU_Bison
2014 WK
That's about right. My stock 2008 CRD is at 2,000 RPM at 55 MPH which is the speed limit for the freeways on my daily commute.
I'm looking forward to trying out the 8 speed tranny on the 2014 ecodiesel if they ever start building them for American dealers.
NDSU_Bison is offline
post #5 of 11 Old 06-24-2013, 01:00 PM
Zlartibartfast
2007 WK
jrv8984 you are reading it right - ~2.3K RPM @ 65 MPH. The stock rear gear ratio in the WK CRD is 3:73 which is great for towing. @ 85 MPH it will be over 3.5K RPM.
Zlartibartfast is offline
post #6 of 11 Old 06-24-2013, 10:19 PM
chevra
2008 WK
Ya mine is around the same as that. Would be nice if it was a bit lower to increase the fuel mileage but they are right the 3:73 ratio is great for towing. Anyone ever hear of anyone swapping to a different rear gear ratio in a WK? Just curious.
3.0L CRD OME HD
17" XD Addicts with 255/75/17 Dynapro ATMs
GDE Eco Tune and DPF Delete
chevra is offline
post #7 of 11 Old 06-25-2013, 08:43 AM
Jeepforthewin
2010 JK Wrangler
No one currently makes different gearing for us Wk guys People have said a couple companies are thinking about making better gearing but nothing official that i know of.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #8 of 11 Old 06-25-2013, 09:17 AM
Zlartibartfast
2007 WK
I believe fishinbama made a successful rear end swap to a 3:07 ratio
post #9 of 11 Old 06-25-2013, 11:10 AM
chevra
2008 WK
Is there a thread on that, be nice to see how it was done and what the results were.
3.0L CRD OME HD
chevra is offline
post #10 of 11 Old 06-25-2013, 11:59 AM
Jeepforthewin
2010 JK Wrangler
There is a thread on it. Once you read it though it may change your mind though. If you have a 4x4 you might as well forget about it but if you have a 2wd then you could possibly do the swap. Only bad part is if you read though his thread over the swap his computer flipped out and threw his Wk into limp mode because his transmission was throwing gear ratio codes. I'll look for the thread and post a link to it for you
post #11 of 11 Old 06-25-2013, 12:02 PM
Jeepforthewin
2010 JK Wrangler
Here's the thread! The bulk of the thread his him changing to 3:21 but at the end he swaps them out for the 3:07 http://www.jeepforum.com/forum/f67/c...leted-1127766/
