Rough Country Lift - JeepForum.com
post #1 of 6 Old 09-12-2013, 08:19 PM Thread Starter
B_Baity10
Rough Country Lift
I'm looking to put a 2" rough country lift on my 05 WK limited. Do I need a steering stabilizer and shocks with it?
B_Baity10 is offline
post #2 of 6 Old 09-12-2013, 08:37 PM
Kallen425
2006 WK
The wk has IFS and a steering stabilizer won't fit. With our steering setup there isn't a way to put one on, although I wish here was. As for shocks, unless they are near new, replace them when doing the lift.
In search of the next Jeep
Kallen425 is offline
post #3 of 6 Old 09-12-2013, 08:47 PM Thread Starter
B_Baity10
Ok thanks for the help!
post #4 of 6 Old 09-17-2013, 06:39 PM
oldsmoke
2009 WK
I have investigated the Rough Country lift. They claim it levels the Jeep so I am assuming that the back lift spacers will be "shorter" than the front. This may or may not be desirable but otherwise I think it is a good lift at a great price.
oldsmoke is offline
post #5 of 6 Old 09-18-2013, 12:18 AM
ca07wk
2007 WK
To get mine to sit level with the RC spacers, I stacked 2 coil isolators on top and bottom of the rear coils.
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #6 of 6 Old 09-19-2013, 05:16 PM
oldsmoke
2009 WK
I ended up getting the Terra Flex 2" lift kit which maintains the stock "rake" of the vehicle. It was a bit more money but the vehicle will sit level when towing or loaded with gear for an off road adventure/road trip. Another consideration however is that the lift moves the rear axle in a downward/forward arc because of the single link or "trac bar" which locates the rear axle. The rear wheels are moved slightly forward because of this and I may need to lengthen the locating link but we'll see what it looks like when I get it all installed. The Terra Flex 1.5" spacers were also a bit more money but have a very nice anodized finish that should resist corrosion and are hub centric. Now hopefully I can cram the Bridgestone Duellers ( 255 70 18,s ) into the wheel wells without rubbing issues. I will post up some photos of my build on the appropriate thread when I get it all together.
oldsmoke is offline
