Rock light - JeepForum.com
post #1 of 10 Old 07-05-2013, 01:55 PM Thread Starter
Tbonfire
2006 WK
Rock light
I have everything to install my rock lights but I don't know how to wire the switch. I've looked all over on here and I haven't seen anyone with a 4 post spdt switch. Any help?
Tbonfire is offline
post #2 of 10 Old 07-06-2013, 04:17 PM Thread Starter
Tbonfire
2006 WK
Anyone?
Tbonfire is offline
post #3 of 10 Old 07-06-2013, 07:37 PM
giulio17
Is it a momentary or a on off. And does it illuminate
giulio17 is offline
post #4 of 10 Old 07-06-2013, 08:07 PM Thread Starter
Tbonfire
2006 WK
It is not momentary it is on off auto and it is illuminated
Tbonfire is offline
post #5 of 10 Old 07-06-2013, 08:47 PM
Anon155
2005 WK
I used all SPST switches for my lights from Otrattw. If I remember right this should be the correct diagram for it:
05 Jeep Grand Cherokee: ORT 4X4; Khaki #55
Too many mod's to list...
Anon155 is offline
post #6 of 10 Old 07-07-2013, 07:37 PM
giulio17
Usually u the ones on the ends are what u put power threw and the center would be ground. If your running a relay I would run ground threw the switch and power to the center for illumination. And let the ground be the switch for the relay. If u have a multimeter and use ohms it would make things alot more simple.
giulio17 is offline
post #7 of 10 Old 07-09-2013, 04:25 AM
Budasac
2005 WK
Are you sure that's a single pole double throw switch. It looks like an illuminated single throw. According to that diagram the bottom two terminals are the switch and the other two are to illuminate the switch.
Budasac is online now
post #8 of 10 Old 07-09-2013, 07:57 AM Thread Starter
Tbonfire
2006 WK
It's suppose to be spdt. That's what i ordered. Ill have to give them a call today
Tbonfire is offline
post #9 of 10 Old 07-10-2013, 08:44 AM
Anon155
2005 WK
Yeah those are definetly not the spdt. Im pretty sure the spdt have at least 5 terminals. Most come with the double illumination option as well. I would make sure they didn't mix them up your order by mistake.
Anon155 is offline
post #10 of 10 Old 08-05-2013, 12:00 PM Thread Starter
Tbonfire
2006 WK
So I finally figured out that my switches ARE SPDT: 7 common ground
1 interior ground feed ( to the foot light)
2 from relay (86)
3 body ground
Now to just get it done lol
Tbonfire is offline
