Stock rims on my limited s are 18. I am considering a ome md lift. I want to change the rims to have the right offset so I don't have to run spacers. Does anybody know the correct offset? Do I have to stick with the 18 or can I drop to the 17? It is a hemi with the tow package and the QD
Stock is around 50mm offset I think. My new wheels are 35mm offset and they just about line up with the fender.
My stock wheels have winter tires on them and are 17".
The ones in the pic are 18".
So stock offset is 50mm that means if I order a set of rims at 18mm offset I would not have to run the 1.25" wheel spacers to clear the 265/70/17. Tires that I am considering are the cooper at3. I have ran them before on other vehicles and have good luck and mileage.
I run ATX Dune 17" x 8.5" with +30 offset & 265/70/17 tires (no spacers) with a 2" lift. I do get rubbing on the rear when it articulates (rubs on the outer fender) I figure +35 with this size tire would be a better fit.
this is how they sit
Commander rims with +44 offset & 265/70/17 tires don't rub on the rear but do touch the sway bar on full lock on the front (slight rub on inner guard also).
I had the same questions when putting on my lift. Went from 18 inch stock on my Overland to 17X8 wheels and 265/70 Duratrac with OME HD lift. My wheels are Procomp 7005 with 0mm offset and 4.5 backspace (no spacers). They do stick out about 1-1/2 inch but that's what I was going for. There was slight rubbing at full lock but after the pinch weld no issues. Ill get pics up here soon.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
