reseting codes - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > reseting codes
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFather's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPI
Unread 08-12-2009, 03:27 PM   #1
dk02wrangler
reseting codes
im writing this for my dad who just bought a new grand cherokee and he's not used to the forum (im part of the TJ side) Anyways just wondering if there is anyway to manually reseting codes or the "change oil" warning in the dash. btw im impressed with the cherokees 4wd compared to my lifted TJ!
thanks guys
dk02wrangler is offline   Reply With Quote
Unread 08-12-2009, 03:30 PM   #2
thewalrus
2005 WK
What year is the GC?
-Thanks
ASE Master Tech
thewalrus is offline   Reply With Quote
Unread 08-12-2009, 03:31 PM   #3
dk02wrangler
it's an 08
Unread 08-12-2009, 04:01 PM   #4
runbikeswim
2005 WK
Hold reset while it displays "change oil".
runbikeswim is offline   Reply With Quote
Unread 08-12-2009, 08:28 PM   #5
magneticred
2008 WK
To reset the oil change indicator
system (after performing the scheduled maintenance)
refer to the following procedure.
1. Turn the ignition switch to the ON position (Do not
start the engine).
2. Fully depress the accelerator pedal slowly three times
within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary repeat this procedure.
The engine oil change indicator system is duty cycle based,
which means the engine oil change interval may fluctuate
dependent upon your personal driving style.
Unless reset, this message will continue to display each
time you turn the ignition switch to the ON/RUN
position. To turn off the message temporarily, press and
release the MENU button.
magneticred is offline   Reply With Quote
