Replacing a Oil Presure sending unit on a 06 5.7 Hemi GC - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Replacing a Oil Presure sending unit on a 06 5.7 Hemi GC
The Cure for your Tie Rod Roll!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineOffset Tie Rod Kit From RuffStuff!
Unread 04-04-2015, 08:23 AM   #1
cobra259
2006 WK
Just had a CEL and a oil pressure light on. P0520 was the code. I bought a Jeep ops part # 5149062AA. List price from a dealer is $38.70, I got it for $27.00 (used to work there). It's on the right side bottom, of the engine block, right behind the alternator. I removed the front skid plate, 13MM bolt's (4). I didn't have a 1-1/16 deep well socket, A 27mm did the trick. You will need a swivel extension. You will lose some oil when you pull the OPS. Not much about 1/4 to 1/3 of a quart. Lights are off, I'm happy!!
Hope this helps someone in the future..........
2006 GC Limited 5.7 Hemi Stone White BT c/can Mopar cold air
1995 Cobra Mustang Procharged
cobra259 is offline   Reply With Quote Quick reply to this message
