Replacing interior lighting to LED's? - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Replacing interior lighting to LED's?
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 01-06-2013, 12:14 AM   #61
terrasmak
2007 WK
I need some dome light LEDs , the ones I got from superbrightLED just keep burning out. Anyone have a link to a better suggestion.
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline   Reply With Quote Quick reply to this message
Unread 06-18-2013, 09:31 AM   #62
BaselMagdoub
2010 WK
I installed them today the light is amazing !!
But I have a problem that the rear lights and the cargo light stay Dimly it`s don`t give a full light only little light !!
what is the problem and how i can solve it ?! it stay like that even if the Jeep is locked and the lights is off !
BaselMagdoub is offline   Reply With Quote Quick reply to this message
Unread 06-18-2013, 09:36 AM   #63
JRLT
2010 WK
Try turning your bulbs around.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline   Reply With Quote Quick reply to this message
Unread 06-18-2013, 09:55 AM   #64
BaselMagdoub
2010 WK
it may fix the problem !?
Unread 06-19-2013, 09:43 AM   #65
justinmiller930
2005 WK
I purchased mine from Ebay. I don't remember the company, but there are lot of kits out there. I recommend switching to LED. They are way more efficient, and they look a lot better. The kits make it really easy to pop the old lights out and install the new ones.
justinmiller930 is offline   Reply With Quote Quick reply to this message
Unread 06-19-2013, 09:49 AM   #66
justinmiller930
2005 WK
Here is the kit that I purchased.
http://www.ebay.com/itm/HID-WHITE-LE...item3a800054ff
Unread 09-29-2013, 10:07 PM   #67
94jeepman
2005 WK
Originally Posted by Hemiwk05 View Post
Yeah they are really bright.
do all the limiteds have the steering wheel cover I just noticed it looks exactly like mine
94jeepman is offline   Reply With Quote Quick reply to this message
Unread 08-13-2015, 09:33 AM   #68
garth285
2007 WK
I installed the ebay kit lights on my 07 Jeep Grand Cherokee the other day, the one confusing thing is that they gave me 4 of each style of the lights. so 4 of the long tube looking lights and 4 of the wedges, when I asked them about it they just said the kit is universal for 05-10 jeep GC's (contradicting statement) and they didnt offer to fix the issue. So anyways I installed the 2 tube looking LED's into the MAP lights and then the 4 wedges went for the floor lights and the rear seat. But the license plate lights are not the same as the MAP lights so now I have 2 spares.
Anyways the lights are a great upgrade and pretty damn bright! Its still cheaper to buy this kit then each bulb individually.
Now I'm just trying to find a really bright trunk light that will fit in that housing. Thinking about trying this bulbs as it has 260lumens but not sure if it will fit:
http://www.superbrightleds.com/more...ofit-car/1563/
garth285 is offline   Reply With Quote Quick reply to this message
Unread 08-13-2015, 11:49 AM   #69
Fink132
2008 WK
I think that's the one I ordered for the trunk light... will let you know when it gets here if it fits... here's hoping
2008 3.0CRD Overland WK
SOLD:2002 Overland...2" BB with Bilsteins
Fink132 is offline   Reply With Quote Quick reply to this message
Unread 08-14-2015, 07:49 AM   #70
garth285
2007 WK
Oh nice, keep us updated please!!!!
Unread 08-15-2015, 10:05 AM   #71
sheepdog918
sheepdog918's Avatar
2007 WK
If you run LEDs all the way around in the interior you will have either the dome, or map lights glow due to the lack of resitance in the current. That's why I left my cargo light alone
There are the wolves, there are the sheep, but then, there are the Sheepdog's
sheepdog918 is offline   Reply With Quote Quick reply to this message
Unread 08-17-2015, 10:23 AM   #72
garth285
2007 WK
You might be able to get away with running a resistor in the system somewhere.
Fink let us know what you find!
Unread 08-17-2015, 09:07 PM   #73
sheepdog918
2007 WK
Some people do but I just found it to be easier to leave the stock bulb in to be the resistor and do the "cargo led strip mod"
Unread 08-17-2015, 09:32 PM   #74
Fink132
2008 WK
I love the LED glow with the ignition on... perfect for late night *ahem* rendezvous with *ahem* uh yea...they're mood lights
Still awaiting my LEDs in the mail
Unread 08-18-2015, 10:55 PM   #75
Fink132
2008 WK
Ok Gents, I have an answer regarding the Cargo light in the liftgate... The one I ordered DOES fit.
I ordered from superbrightleds.com and got the following which does ALL interior lights:
2 x 921-CW12: Cool White (footwell lights)
3 x WLED-WHP5: Cool White (one of these is for the liftgate cargo lamp, the other for the rear passenger assist handles)
2 x 4410-CW9: Cool White (Map lights)
Replacing the liftgate cargo lamp is a PITA. You first pop off the clear cover and then there is a black mounting plate that will be loose inside the liftgate door trim. If you look at that mounting/backing plate (the one that the lightbulb is mounted inside) you will notice it can be compressed to be removed through the liftgate trim. Compress this and remove it a bit in order to be able to support it enough to get the new bulb in. TEST IT BEFORE YOU PUT IT BACK TOGETHER. Once you verify the lamp works, align the clips on the mounting plate with those on the clear cover, lock them in place and then proceed to put the mounting plate back in its home. It will compress as you push it back through the trim
