Replacing front/rear differential gaskets - JeepForum.com
post #1 of 7 Old 02-07-2014, 10:39 AM Thread Starter
DirtAddsHP
2007 WK
Hello all,
I am getting ready to do a differential fluid change, i have called the dealership about procuring new gaskets. But they state there are no paper gaskets for differentials. They suggest i use Orange Axel RTV sealer.
Is this correct?
I have a 2007 Jeep Grand Cherokee CRD 4x4
DirtAddsHP is offline
post #2 of 7 Old 02-07-2014, 10:40 AM
Jeepforthewin
2010 JK Wrangler
Yes, Run a line of sealer around the diff cover and completely around every bolt hole.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #3 of 7 Old 02-07-2014, 10:48 AM Thread Starter
DirtAddsHP
2007 WK
Ah okay great, also what size allen wrenches will i need if i decide not to take off the plate and only drain and refill?
post #4 of 7 Old 02-08-2014, 06:02 PM
JKM
2005 WK
on the rear diff there is no drain plug so you have to take off the cover.
On the front diff, the drain plug is 14mm
JKM is offline
post #5 of 7 Old 02-08-2014, 06:19 PM
modernblueWK
Make sure you clean the old rtv off before you put more on.
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #6 of 7 Old 02-08-2014, 07:32 PM
johnniebravo
2008 WK
Also make sure on the front you can remove the fill plug before draining the diff.
2008 CRD GC
johnniebravo is offline
post #7 of 7 Old 02-09-2014, 02:00 AM
Jvenrick
2007 WK
Also for a greater peace of mind I recommend an 8.25 lube locker gasket for the rear.
2007 Grand Cherokee Rocky Mountain Edition: 4.7L V8- QTII- Green
The build:
Jvenrick is offline
