Replacing CRD Serpentine Belt Step by Step - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Replacing CRD Serpentine Belt Step by Step
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Rough Country Jeep Suspension Deals at Rockridge 4WD!Looking to re-gear?! CRAZY DEALS ON YUKON GEARS right here
Unread 03-16-2014, 07:41 PM   #1
Chirpz
Chirpz's Avatar
2007 WK
I had to replace my belt the other day so I decided to write up a procedure. Thanks to others who have posted similar procedures.
To view online in your browser click this link
http://www.chirpz.com/jeeps/belt/belt.html
To download as a printable PDF file click this link
http://www.chirpz.com/jeeps/belt.pdf
Chirpz
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is offline   Reply With Quote
Unread 03-16-2014, 07:53 PM   #2
Chirpz
Chirpz's Avatar
2007 WK
Oh! For the curious, I priced a belt at the dealer and it was $92.00. Napa had one for $84.
I ordered this Gatorback on Amazon for around $36.00.
I cannot complain about the Mopar original belt at all. It never squealed and lasted 90,000. I don't know why I let it go so long. I guess I just never gave it a second thought. I consider myself fortunate.
Chirpz
Unread 03-16-2014, 07:59 PM   #3
BAH101
2008 WK
Nice write up (as always). If you notice on slide nine, right where your ratchet extension crosses the fan shroud, there are some plastic extrusion parts sticking out. These love to grab onto your arm flesh and tear it nicely. I filed mine down after I worked in there the first time.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is online now   Reply With Quote
Unread 03-16-2014, 08:10 PM   #4
jediknight
2008 WK
I have the same belt since last august with + 17,000km on it. Nothing to report yet...so far so good. However since not OEM I like to check, once in a while, how it does.
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline   Reply With Quote
Unread 03-16-2014, 09:19 PM   #5
suzieque
2008 WK
Nice work chirpz, wish i could buy you a beer, i was planning to do my serpentine belt this summer. The 2008 resonater is different than your 2007 so I will add some pics to this thread when I change mine.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline   Reply With Quote
Unread 03-17-2014, 12:03 AM   #6
Chirpz
Chirpz's Avatar
2007 WK
[QUOTE=jediknight;21302769]I have the same belt since last august with + 17,000km on it. Nothing to report yet...so far so good. However since not OEM I like to check, once in a while, how it does.[/QUOTE
Well I think I bought this belt because of your comments elsewhere. Also did some reading. We'll see how it goes.
Chirpz
Unread 03-17-2014, 12:05 AM   #7
Chirpz
Chirpz's Avatar
2007 WK
Yea! I see'um. Good idea to file them down.
Chirpz
Unread 03-27-2014, 08:12 AM   #8
Hendrix9
2007 WK
Fantastic write up! I changed mine yesterday with your PDF printed out as my guide, as it's been long overdue with 105k miles on the stock one. I manged to do both turbo resonator bolts from above, but the resonator I had to pull out from the bottom. It would be alot easier with the swaybar out of the way to remove it, but I managed. Definitely the hardest part of the job is just getting the turbo resonator off and out of the way. Thanks for taking the time to do this!
2007 Jeep Grand Cherokee CRD
4XGuard Matrix
GDE Eco Tune
Hendrix9 is offline   Reply With Quote
