Replacing CRD Fuel Filter step by step - JeepForum.com
post #1 of 18 Old 02-25-2014, 10:37 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
I replaced my fuel filter for the 2nd time yesterday and decided to post a step by step procedure.
You can view my procedure as a web page here:
http://www.chirpz.com/jeeps/fuelfilter/Fuel_Filter.html
or you can download the PDF file here:
http://www.chirpz.com/jeeps/Fuel_Filter.pdf
Chirpz
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is offline
post #2 of 18 Old 02-26-2014, 09:16 AM
caddydaddy
2007 WK
Awesome write up as always!
You mention to prime the new filter with fuel from the old filter. My only concern would be possibly contaminating the new filter with any dirt or water that was in the old filter. Thoughts?
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
194,000+ miles!
caddydaddy is offline
post #3 of 18 Old 02-26-2014, 10:48 AM
pawwright
kudos to you, again, Chirpz - I always appreciate your write-ups, very easy to read and follow.
pawwright is offline
post #4 of 18 Old 02-26-2014, 11:15 AM
BAH101
2008 WK
For the OEM clamps, I found that a small, 1/8" flat screwdriver inserted under the clamp where it overlaps, then give it a twist, will pop the clamp. A pair of bent needle noble pliers installed them.
I just ended up buying the proper pliers, made by Clikx, if not mistaken. They were $25CDN from Mac tools.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #5 of 18 Old 02-26-2014, 11:47 AM
Radcrd
2007 WK
I fill mine with Powerservice or any other diesel additive that I have on hand.
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #6 of 18 Old 02-26-2014, 04:14 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
Yea! That is better. I mentioned that idea because a person may be caught with nothing else around and it is an option.
Chirpz
Chirpz is offline
post #7 of 18 Old 02-26-2014, 04:56 PM
fordt
2008 WK
What a timely write up, I'm about 1500 away from a combined fuel/oil filter change! Thanks Chirpz! Along these same lines, where's everybody getting these two filters these days.....???? I DID notice the NAPA filter and number in there...that helps! (and I was told napa stood for "no auto parts available")
2008 Grand Cherokee CRD Overland 2WD, GDE Eco tune with DPF delete, MBRP DPF back exhaust system
fordt is offline
post #8 of 18 Old 02-26-2014, 09:38 PM
Valpacer
2007 WK
Great writeup!
Only thing i would add is - The bleed valve on the top is also used to prime the filter - after installing the filter, put a long hose on it and into a container. Turn the key to on and the intank pump will start up. Undo the screw housing around the tube and leave it open until clean and bubble free diesel comes out, then turn closed. Engine will start near on first crank.
2007 WH Grand Cherokee CRD (Yup, RHD Australia)- 3" Exhaust, GDE Flash Tune, CRDSTU/SL Hybrid Lift & bash Plates, 4xGuard Rock Rails, Saguaro F & R Bars, RCV's, Warn 9.5cti-s, AEV Saverge Rims, Nitto Mud Grapplers, Snorkel, Custom Rear Drawers, On Board Air, BullyDog Monitor, Dual Batteries -
Valpacer is offline
post #9 of 18 Old 02-27-2014, 11:43 AM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
Ha Ha!! I have had no trouble getting stuff at Napa. They had what I needed in stock and we live in a small town. So far I have purchased, fuel filter, oil filter, glow plug, battery, and air filter from them. They also have the serpentine belt but I don't like their belts.
Chirpz
Chirpz is offline
post #10 of 18 Old 02-27-2014, 11:44 AM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
Originally Posted by Valpacer View Post
Great writeup!
Thanks for mentioning this. Very good point. Maybe I'll add it to my write up when I get the chance.
Chirpz
Chirpz is offline
post #11 of 18 Old 02-28-2014, 09:20 AM
fordt
2008 WK
Yup, small town, I hear ya (2200-but we've got a NAPA!) in addition to the 3934 fuel, do you use the OEM (Mann) oil or the NAPA Gold brand? Is your K&N the air box replacement cone or standard filter back in the box? Thanks again for the write up, and thanks for your shade tree DPF delete write up, I didn't replace mine with a pipe, just roto hammered the media out, but your picts and tips were great.
fordt is offline
post #12 of 18 Old 03-01-2014, 07:16 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
I use the Napa Gold oil filter... The K&N that I use is the one that fits in the standard airbox replacing the standard paper filter. So far I have cleaned it twice. It is pretty easy to clean and you can get the cleaning kit from Napa.
Before you switch to a K&N, read this report.
http://www.nicoclub.com/archives/kn-vs-oem-filter.html
Chirpz
Chirpz is offline
post #13 of 18 Old 04-11-2014, 07:34 AM
jediknight
2008 WK
...I just reviewed this as I'll be going through this in the next few days. What about the air getting into the fuel hose between the high pressure pump and the fuel filter ? Is there a way to bleed that (that would involve bleeding from the HP pump)... Or is the amount of air is not significant enough to care of ?
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #14 of 18 Old 04-11-2014, 10:20 AM
BAH101
2008 WK
Its a self bleeding system.
BAH101 is offline
post #15 of 18 Old 04-11-2014, 09:12 PM
Tango.
2008 WK
those are not oem hose clamps... for the oem you need the $8 hose clamp tool. just FYI
good write up.
Tango. is offline
