Replacement Front Coil Isolators - JeepForum.com
post #1 of 8 Old 06-11-2013, 09:04 AM Thread Starter
carvinbassplyr
2007 XK Commander
I'm getting ready to replace the worn out factory struts/shocks on my 07 XK and looking to get new isolators for the front strut assembly. Does anyone make poly replacement isolators that don't raise the vehicle? If so, where do I get them? If not, what brand do you guys recommend and where do I get them?
carvinbassplyr is offline
post #2 of 8 Old 06-11-2013, 09:40 AM
ca07wk
2007 WK
I havent seen a poly isolator, however, I replaced mine with the crown automotive ones and they look like a great quality product.
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #3 of 8 Old 06-11-2013, 10:16 AM Thread Starter
carvinbassplyr
2007 XK Commander
Have you ordered from them since they sorted out their "bad batch" situation? I've heard they got the problem solved, but you can never be too sure.
post #4 of 8 Old 06-11-2013, 10:18 AM
paroxysym
2007 WK
order from rockauto... and what do you mean "raise" the vehicle? once theyre broken in and settled the "raise" will go away.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #5 of 8 Old 06-11-2013, 10:22 AM Thread Starter
carvinbassplyr
2007 XK Commander
I've seen "lift kits" that use thicker spring isolators (basically spacers) to the lift the front and rear of the vehicle. I already plan on using the RR front leveling plate to take the nose dive out of the front end, but I don't want any other lift besides that.
post #6 of 8 Old 06-11-2013, 10:50 AM
dmsfun
2006 WK
I just replaced mine when I put on the FSD's, and also put on new OEM coils. I bought the OEM coils and OEM isiolators from an online Mopar discounter for both front lowers and the 4 rears. These are the lowest prices of any I found, including aftermarket ones from Rockauto. Front uppers come with new strut mounts, and I used Monroes.
2006 Overland QDII 5.7 BT catch can, Diablosport Intune, CMR tune by Hemifever tuning, Modern Muscle ported 85mm TB, Apexi super voltage regulator, SRT8 front and rear sway bars, Koni FSD shocks/struts, Cooper discoverer AT3's, Amsoil fluids.
dmsfun is offline
post #7 of 8 Old 06-11-2013, 11:23 AM Thread Starter
carvinbassplyr
2007 XK Commander
This may sound dumb, but are there different material compositions from OEM to aftermarket? Meaning, are the OEM ones a softer rubber to achieve a soft ride and aftermarkets ones harder rubber for more durability?
post #8 of 8 Old 06-11-2013, 11:57 AM
ca07wk
2007 WK
I haven't, I bought mine mid last year.
ca07wk is offline
