Replace Leaking Injector Seal Step by Step - CRD - JeepForum.com
 13Likes
post #1 of 27 Old 09-14-2017, 07:34 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
So... I noticed a new noise today that has probably been going on for a week or two without my notice. The wife complained about the heavy oily smell and I just thought she was smelling my EHM fumes.
Today I was poking around and notice oil around the #1 injector and heard the swishing shound of what must be a small compression leak. Here is a video of the noise. What do you think?
** NOTE ** See post #15 to read the step by step guide to repair this problem
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is online now
post #2 of 27 Old 09-14-2017, 08:01 PM
caddydaddy
2007 WK
I'd say it's a bad injector seal. Good thing you noticed it early, I've heard they can make quite the mess if left to leak for too long!
At least the seal is cheap! 99 cents!
http://www.idparts.com/injector-seal...51-p-4277.html
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
200,000+ miles!
caddydaddy is offline
post #3 of 27 Old 09-14-2017, 09:13 PM
JasonCroasdale
ah the black death. you can fix this!. just be patient removing injector. i actually bought a bag of seals for if when it happens again.
JasonCroasdale is offline
post #4 of 27 Old 09-15-2017, 05:53 PM
nvrdone1
2007 WK
does sound like a seal leak. id consider replacing all the seals because you can bet if one is bad they will all fail fairly soon
nvrdone1 is offline
post #5 of 27 Old 09-15-2017, 06:13 PM
Hendrix9
2007 WK
I disagree. Based on everything I've read it's pretty much a crapshoot when and IF they even will ever fail. I'd only disturb as much as necessary IMO. Worked out good for me the past 180k miles.
2007 CRD QDII
2010 Jetta Sportwagen TDI 6MT - hoping it gets bought back!
2004 QD 4.7 GC
2009 Rav4 v6
Hendrix9 is offline
post #6 of 27 Old 09-16-2017, 04:56 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
My personal preference is to just fixed whats broken, in most cases. I take that approach to glow plugs for example. So I'll just deal with the one, and then fix the others as they go.
I called the dealer parts dept. and they had NO CLUE what I was talking about. After quite a while, they finally said that they could order the bolt and the seal ring for the bottom but had no listing for the other rubber o-ring that is needed for the return line.
So.... I ordered a set online and will have to wait for them to arrive.
Chirpz
post #7 of 27 Old 09-17-2017, 09:25 AM
moonvan
2008 WK
looking forward to another detailed How-to by Chirpz
Tetto and underscore like this.
2008.5 Grand Cherokee S-Limited CRD
moonvan is offline
post #8 of 27 Old 09-17-2017, 08:23 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
When the parts arrive, I will definitely write one up.
Chirpz
post #9 of 27 Old 09-19-2017, 07:05 PM
BAH101
2008 WK
Me too, was getting an oil smell and this morning discovered the black gunk on the #3 injector.
Guess I'll be ordering seals and bolts now.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #10 of 27 Old 09-19-2017, 10:42 PM
Tango.
2008 WK
The injector rubber o-ring is MB part A0000780580
One of mine I had to cut the base a little, someone on here loaned me their cutting tool.
For the copper o-ring there is also a Honda part that fits, it is a little thicker. Some of the sprinter guys have been using it.
Soak it over night with injector cleaner.. it comes out easier that way. They usually come out by hand.
Life is hard-John Wayne
Tango. is offline
post #11 of 27 Old 09-20-2017, 10:38 AM
GreenWK
Junior Member
2008 WK
I bought this kit to have on hand as several of these have gone out for me.
http://www.idparts.com/injector-inst...42-p-6433.html
2008 CRD Overland, GDE Eco
GreenWK is offline
post #12 of 27 Old 09-21-2017, 07:50 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
I pulled my injector today. It took me most of the day to pull it and clean up the mess, after a late start. It was caked really bad with the black death gunk. I'm ready to put it all back together but I just ran out of daylight and ran out of steam so I'll finish it tomorrow. I had a very hard time getting the injector out. I'll tell you how I did it in my write up. Hope to have it posted late tomorrow or Saturday for sure. I cheated for sure.
Chirpz
post #13 of 27 Old 09-21-2017, 07:54 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
YES!! I stumbled upon the same deal and purchased it too. They shipped it right away and it arrived sooner than I expected. Highly recommended.
On another note, I wanted to see what the dealer would charge for the necessary stuff. I called them up and they found the bolt and the washer but had neither in stock. They could not even find the o-ring for the return line and wanted to sell me the whole line. I don't remember the price of the washer, it was more than a dollar, but the bolt was $11.00. I hung up and ordered the above deal.
underscore likes this.
Chirpz
post #14 of 27 Old 09-22-2017, 04:47 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
I completed my repair today and will post the writeup soon. In the mean time you can take a look at the 17 second video of the repair and compare the sound that it makes now with the previous video of the faulty seal.
Repaired Seal
https://youtu.be/C7xFhjpDW3s
Faulty Seal
https://youtu.be/sCQS1rkFLyI
Chirpz
post #15 of 27 Old 09-23-2017, 11:47 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
Here is a Step by Step DIY to repair the injector seal....
http://www.chirpz.com/jeeps/injector...ectorseal.html
and in PDF format, click this link
http://www.chirpz.com/jeeps/injector...jectorseal.pdf
T1m, caddydaddy, Tetto and 1 others like this.
Chirpz
