Removing plastic covers from 18" x 7.5" Aluminum Chrome Clad Wheels - Page 2 - JeepForum.com
post #16 of 41 Old 01-27-2009, 09:46 AM
Jeep Brian
PLus the chrome is stronger and easier to apply to plastic.
Mine: 07 GC Limited Hemi stock for now.
Hers: 14 Dodge Durango Citadel Hemi
68 Firebird 350 4 spd #'s matching
Jeep Brian is offline
post #17 of 41 Old 01-27-2009, 03:51 PM
Marcus86GLHS
and mopar is using this manufacturing method on practically all their chrome-style wheels on all Chrysler/Dodge models, not just the Jeep brand. i prefer these to real chrome-over-steel alloy, and much better than polished/clear coated aluminum.
2008 Hemi Grand Cherokee Limited 4 x 4, original owner, 29,000 miles
Marcus86GLHS is offline
post #18 of 41 Old 01-27-2009, 04:47 PM
GasMas
2008 WK
They may be easy to make and easy to clean
but they still scream cheesy.
Kudos to Chrysler on the matching full size spare.
What do I have to do to get the spare tire pressure monitor to work?
or will it just magically take care of itself?
Once I get to 25 posts, I'll be putting up a bunch of pics,
cheesy wheel scratches included.
Kevin
GasMas is offline
post #19 of 41 Old 03-23-2009, 11:54 AM
sdrouins
I want your wheels
Hi guys, If you dont like your 18" x 7.5" Aluminum Chrome Clad Wheels, I would like to buy it!
let me know if you're interested!
sdrouins is offline
post #20 of 41 Old 03-23-2009, 12:20 PM
suzieque
2008 WK
Originally Posted by usernametaken View Post
I almost didn't buy ours when I got to the dealer and saw the chrome cladding... aka cheapo plastic junk.
Yup, the Overland had these wheels, I walked away when I saw these! I actually came back the next day and knelt down to see that the wheel is aluminum and not steel! I just assumed the Overland had plastic chrome hubcaps!
suzieque is offline
post #21 of 41 Old 03-24-2009, 07:50 AM
Jeep Brian
Kevin
You have to do nothing...if the spare is low it will show on the dash!
post #22 of 41 Old 03-23-2011, 06:57 PM
jeeperss
answer to chrome clad wheels jeep GC 2005/06/07
there is speculation as to chrome clad fury,bonding,rattling,plastics,reving repairing[pulling your hair out,lol
lets start with basics facts from begining,[not to not bore others who have their own 'fix',
First,there is an actual dull-[like flat primer paint] spoke wheel that the tire is mounted on,it even has a JEEP logo in center,but the clad hubcap doesnt,I'll get to that later.....[,yes I took mine off with NO tools-off or on] DONT DO THIS IN FREEZING TEMPS-will only result in breaking them!
Second,the lugnuts do NOT hold the hucap on-not-not
Third,they are/not bonded[silicone maybe?] and CAN be removedps,if they ever were 'bonded' they wouldnt be clacking,you know that noise!
Fourth,there are plastic 'tabs or 'lip''made into the hubcap,on each side of the of the 'spoke part' of the CAP about halfway up on the BACKside it 'snaps' over the metal spoke of the actual WHEEL..envision a plastic box that the lid lip snaps closed to the bottom half,as it is molded that way--same here,anyway,that your hands one on each side of any given spoke,GENTLY pull outward on these two tabs/lip edges an slightly towards you,not to far-just till you will feel it move/release,too hard and you will break the tabs off,go all around the wheel cap ONE by ONE repeating this,if you did this correctly when you get the last spoke the hubcap will drop off in your hands,hurray!
,now the style of cap design varies,so this info relates to most jeep models 05-06-07,][mine is 2007 GC laredo]
Fifth,you have it off-now what?If you like what you see,and some will,your done.,but before you toss it,turn it over and read the lettering on backside molded into it MADE IN TAIWAN-1MP-314X 17 thats right!@#$thats not an OEM part number
You CANT buy factory replacements[without buying a complete new wheel=345.00]because there not 'factory made',jeep cannot supply them individually, ,and they clack because the tab lips are broken from tire work or the bonding has worn down,ugh!
But today I replaced all 4 of mine,20 minutes/less,and they ROCK like brand new!And guess what-they are IDENTICAL to the factory covers,tab'lips,right down to the letters-literally!When you replace them-aagain-GENTLY pushing each spoke down evenly-one-by-one then once more around and you will hear and feel the lip/tabs snap into place-and no more noise!!
ps>NO I dont sell these or have any part/input whatsoever-Im just a 2 jeep owner/mechanic/perfectionista
They are called chrome clad SKINS,I researched and found 1000s of them online,I personally chose hubcapsplus.com 79.99 for set{4} includes shipping ,
PLEASE NOTE ,I bought mine from their ebay store for 52.72 set{4}free ship eBay Stores > THAT HUBCAP AND WHEEL COVER PLACE here the auction number 360308320136
I too been search,reading,even here for an answer,and I found mine,I hope this helps someone else have a quiet ride:0)
jeeperss is offline
post #23 of 41 Old 03-26-2011, 08:10 PM
jas32
All manufacturers (not just Chrysler) have converted over to (plastic) chrome clad wheels specifically because of warranty issues and a lot of customer complaints. For a few years manufacturers actually used real chrome plating directly on the aluminum wheel. This typically lasted only a few years depending on where you lived. In the North where road crews use salt during the winter, it takes only a year or two before the chrome starts flaking off and/or corrosion starts. Eventually irregardless on where you live and how religiously you care for your wheels, the flaking and corrosion will happen, ending up with crappy looking wheels.
For some reason, chrome wheels are quite popular particularly on high end models and is a good money maker for the manufacturers. No amount of clearcoat protection can prevent the flaking and corrosion from happening and the only solution is to the problem is to use plastic. In reality, in most cases, if you do not tap the wheel, you can never tell if it is plastic or metal.
The plastic piece is actually bonded in certain areas to the aluminum part of the wheel (I guess to make sure it does not separate). It is not designed to be taken apart.
jas32 is offline
post #24 of 41 Old 03-27-2011, 04:06 AM
Marcus86GLHS
JEEPERSS that is a very interesting write up, i wish you included pix. what year and style wheel are you refering to? i checked the chrome-clad wheels on my 2008 and i cannot see the tabs you refer to, maybe they are there but i cannot locate any.
post #25 of 41 Old 03-27-2011, 11:31 AM
Marcus86GLHS
"......it even has a JEEP logo in center,but the clad hubcap doesnt,......."
i have a 2008 and the chrome clad "hubcap" does have the "Jeep" name on the centers. i also re-checked and confirmed there are no tabs that hold the cover to the wheel, it has to be bonded to the wheel as previously mentioned.
post #26 of 41 Old 03-27-2011, 11:52 AM
Budasac
2005 WK
Jeeperrss is refering to aftermarket "skins". They are not the same as what you guys are discussing. And they suck. They loosen up and they ruin the paint on your wheels after a while.
If you have the chrome clad and don't like them, I would suggest a CL listing for a trade. Lot's of guys out there would love to "upgrade" to the chrome wheels.
Budasac is online now
post #27 of 41 Old 03-27-2011, 12:26 PM
Marcus86GLHS
"......Jeeperrss is refering to aftermarket "skins................"
that makes sense, thanx. is the pix above aftermarket?
post #28 of 41 Old 03-27-2011, 12:29 PM
Budasac
2005 WK
Yes. That is a "skin". They look all right. But like I said, they ruin you're wheels. They wear small grooves into the paint on each side of the spokes. If your wheels are shot and you want a cheap fix, this is the way to go. I ended up painting my rims.
post #29 of 41 Old 03-27-2011, 07:35 PM
BAD68GTO
2006 WK
Buy my 06 WK Limited 17" rims and tires for $500 cash, rims are very nice and tires are okay. The TPS are removed. Southern NJ near Philly and I will not seperate them. PM me if interested and they are straight and I will not take less $ fellow Jeepers as $500 is a very good deal. I had the crome clad wheels on my 08 and they were HORRIBLE even falling off from wheeling.
06 WK Limited, Hemi, QD II, 4" Superlift on 33"s, fully Armored with 4XGuard, M8000 on Cradle, Superchips
08 WK 4.7, QTII, OME HD, Full Armor, BURNED TO THE GROUND
2005 Viper, Vert, DLM SE #27/50, Paxton (w/intercooler) 946 RWHP
2000 Viper GTS, 10 LB Roe+GG heads/intake+Solid Roller, near 800 RWHP on pump gas+WM
1968 GTO 467 CID Fully Ported, Roller, 5-speed
2000 E350 Van with a ZILLION miles
2009 Votes thanks to ACORN
If a conservative is down-and-out, they think about how to better their situation.
A liberal wonders who is going to take care of them.
BAD68GTO is offline
post #30 of 41 Old 03-27-2011, 08:12 PM
cherrybomb05
2010 JK Wrangler
Too bad you're not closer gary, did you ever wheel with that set of wheels/tires?
07 WK
10 JKUR
11 JKR
cherrybomb05 is offline
Chrome Clad Wheels and Balancing BlueSteelJP WK Grand Cherokee & XK Commander Forum 9 07-26-2010 10:28 PM
05 17" factory chrome wheels are half plastic!!! slyedog WK Grand Cherokee & XK Commander Forum 5 12-15-2008 04:55 AM
18-inch Summit chrome-clad cast aluminum wheels - WINTER TIME zedtechus WK Grand Cherokee & XK Commander Forum 5 11-17-2008 08:05 AM
Chrome clad aluminum wheels fatfreddy WK Grand Cherokee & XK Commander Forum 15 02-16-2008 11:18 PM
Chrome "Clad" Wheels Sarge ZJ Grand Cherokee Forum 0 04-16-2005 01:08 PM
