Remove rear wiper arm on '05 Grand Cherokee? - JeepForum.com
post #1 of 13 Old 03-12-2009, 03:01 PM Thread Starter
benrm
2005 WK
Ok, I thought this would be easy. Bought the new wiper arm but cannot figure out how to remove my old one. Removed the nut and that's as far as I got. I contacted the place who sold me the arm, but they said I should buy their wiper arm removal tool for $10. There must be another way?? Thanks for your help.
Ben
benrm is offline
post #2 of 13 Old 03-12-2009, 04:39 PM
kiesha
2006 WK
Hi, it will not come of easy, i removed front arms and wasn't easy, what i did i used hummer slightly hit it from all sides and after it come off!
Watch you window.
Hope this helped!
regards
WK 4.7 V8
kiesha is offline
post #3 of 13 Old 03-12-2009, 04:54 PM
Briandl
Just get the removal tool, AutoZone may be able to loan you one with a refundable deposit.
It's a lot better than accidentally scratching your Jeep when you try some other method.
2002 Jeep Grand Cherokee Limited 4.7L H.O. V8
Briandl is offline
post #4 of 13 Old 03-12-2009, 05:05 PM
merlinTec
merlinTec's Avatar
Hi
Leave the nut on just bit so the arm doesn't go flying and give the arm a good wiggle.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #5 of 13 Old 03-12-2009, 05:07 PM
kiesha
2006 WK
No point of buying a tool, you may need it just once in a year.
I would lost it in that time period
regards
WK 4.7 V8
kiesha is offline
post #6 of 13 Old 06-12-2009, 01:57 PM
rainbowcarwash
The easiest way to get it off is to leave the nut on part way and use a small 2 or 3 prong hub puller. Put the puller on and tighten it up and it will pop right off.
rainbowcarwash is offline
post #7 of 13 Old 06-12-2009, 03:50 PM
TaosBob
2007 WK
When I took my front one off, I was just about to give up and pulled as hard as I could and it came off. Just make sure you don't fall on your *** when it breaks loose!
Traded in on 2012 Hyundai Azera: 2007 Grand Cherokee Laredo, Rocky Mountain Edition, Bright Silver, 4.7L V-8, factory hitch and tow hooks, Mopar rock rails, Mopar skid plates, Rusty's 2-inch BB with shocks, cabin air filtration. Firestone Destination AT tires 255/70/R17, 4xGuard skids--front, rear, and belly, BDS rear diff guard, OME rear shocks.
TaosBob is offline
post #8 of 13 Old 07-09-2009, 05:59 PM
Texas WJ
Texas WJ's Avatar
2005 WK
Finally got mine replaced.
I bought and removed a good one off a wrecked Jeep easy enough, but couldn't get the broken one off my Jeep no matter what. I tried everything I could think of over the course of two days finally giving up and buying a wiper arm puller from AutoZone ($13). Took about 5 minutes and the old arm was off. Thank God, it was getting very frustrating.
Texas WJ is offline
post #9 of 13 Old 07-21-2011, 03:42 PM
Bullzy5488
Don't waste money on a tool. Trick: one zip-tie under the cap, one more on either side of the first (3 zip ties total), back of a hammer, elbow grease, voila. Nothing get scuffed, pops right off bc of even weight distribution.
Bullzy5488 is offline
post #10 of 13 Old 07-21-2011, 06:38 PM
2005GRANDONE
2005 WK
The way I always remove wiper arms is take the nut loose leaving 75 percent on the threads and hit the nut with a hammer while pulling on the arm, usually pops right off
05 laredo, 4.7 V8, H.O. cams, fastman t.b. OME hd 3", Rustys .5 spacers, bilstein 5150 rear, yukon spider & side gears, superchips flashpaq, 33x12.50x17 nitto mud grapplers on black moabs, 1.5 spidertrax wheel spacers, flowmaster 40 series, K&N cai, Mopar gas tank, T.C & engine skid plates, riddler diff cover, removed sway bar on front.
Jks quicker disconnects for sale pm me
2005GRANDONE is offline
post #11 of 13 Old 07-21-2011, 06:44 PM
Briandl
Yeah I don't want to swing hammers and rig all kinds of crap on my vehicle, especially around my windshield, or back window, or any glass for that matter.
I'd rather spend the ten bucks on a puller and do it the right way.
Right tool for the right job.
Briandl is offline
post #12 of 13 Old 07-22-2011, 12:13 AM
Bullzy5488
The hammer is only for leverage. No swinging. And the zip ties are soft plastic. It's the Mcgiver'd version of the $10 waste of a tool. Up to you though! Good luck
post #13 of 13 Old 07-22-2011, 01:02 AM
Briandl
Briandl is offline
2001 Grand Cherokee Limited rear wiper issues sna77 ZJ Grand Cherokee Forum 5 10-25-2011 02:09 AM
Replacing rear wiper arm on 2000 Grand Cherokee edfiero ZJ Grand Cherokee Forum 2 01-02-2008 07:34 AM
99 Grand Cherokee rear wiper info Jim Guarino ZJ Grand Cherokee Forum 0 11-20-2006 07:31 PM
Remove rear Bumper Grand Cherokee 1999 HELP Gromits ZJ Grand Cherokee Forum 16 06-11-2005 09:41 PM
How to remove/replace rear wiper arm? RX-7Guy ZJ Grand Cherokee Forum 1 09-19-2004 12:02 AM
