Remove Rear View Mirror - JeepForum.com
post #1 of 4 Old 01-16-2008, 03:02 AM Thread Starter
groupsix
Have a 2006 Grand Cherokee
Can someone tell me how to remove pass side exterior rear view mirror (the whole thing)?
Thanks!
groupsix is offline
post #2 of 4 Old 01-16-2008, 07:33 AM
jeepgaffer
2006 WK
You have to pull the entire inner door trim panel off first. It is held on by three screws and eight plastic clips. Check out http://www.wkjeeps.com/interior_trim.htm for info on how to remove it. Once you get it off, there are three small nuts that you have to loosen/remove to take off the mirror. There is actually four nuts that you'll see on the inside of the door opposite of the mirror, but only three are for the mirror...I THINK it is the bottom two and the very top one, but don't hold me to that!
Hope this helps!
2006 Bright Silver Grand Cherokee Laredo
3.7L 4WD ("mostly" stock)
jeepgaffer is offline
post #3 of 4 Old 01-18-2008, 10:22 PM
group6
Outstanding! I had both panels off last summer, I think cause I was putting film on the front windows to match the factory tint. I even have some clips, but forget finding them. It's that simple- 3 screws and off it comes, eh?
Thanks for the info.
group6 is offline
post #4 of 4 Old 02-23-2008, 08:15 PM
group6
Finally got to the job. Very easy. Backing in to the garage, I caught the mirror on the door frame. The back of the unit, the black curved shell, busted/popped off. It was still intact, though there were a few immediately unrecognizable pieces of plastic on the ground. I thought it was a seperate part, but when I called the dealer, I was told it wasnt- "Oh no, you cant fix those, you have to replace the whole thing" for $150. Ah, f___ that.
I took it off and got it inside so it would warm up. On closer inspection, it was completely intact except for these pieces. I mated the pieces to where they were from (the uneven breaks on pieces and shell matched). They lined up close enough that a liquid instant super glue worked. Now I had two, square, upside down 'U' shaped structures on the inside of the shell. Around the edge of the shell, there were small indentations about 1"-2" apart and tiny male 'nubs' on the other side of the seam where the 2 halves meet. Since I couldnt see inside when I put the two halves together (believe me I tried-small gooseneck LEDs and dentists mirror) I didnt know exactly how everything lined up and met. So I needed a glue that wasnt water thin like the super glue, something thick that would bridge any small gaps. On the dry run I realized the 'U's were the 'female' side of a hook assembly that partially held the two halves together at the outboard vertical edge of the mirror. I used JB Weld, just dabbed a tiny bit at each of the indentations. It all lined up perfectly. I wrapped 3 huge rubber band around the whole thing and drove around without a passenger side mirror...
...24 hours later- like new, impossible to tell it ever happened. Put that $150 to better use.
group6 is offline
Rear view mirror Hi/Med/Lo not4sho ZJ Grand Cherokee Forum 8 03-05-2010 09:01 PM
can I swap out my rear view mirror and install the mirror with smartbeam uconnect? Jbripps WK Grand Cherokee & XK Commander Forum 12 03-11-2009 05:06 PM
auto dim rear view mirror mdjst5 ZJ Grand Cherokee Forum 3 08-08-2008 04:22 PM
Rear View Mirror blackrubi ZJ Grand Cherokee Forum 3 01-22-2006 01:13 PM
'06 Rear View Mirror Pinouts krybka ZJ Grand Cherokee Forum 5 01-02-2006 09:15 AM
