Remove rear seat headrest - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Remove rear seat headrest
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Solution to Radius Arm Bind - Meet Lock-N-LoadFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-13-2009, 08:13 AM   #1
phaeton2000
2006 WK
I'm trying to get two forward facing child car seats in a 2006 Grand Cherokee. The problem I'm running into is the headrests on the back seat. They angle forward which hits the top of the car seat and causes it to lean forward also. I'd like to remove the headrests which looks like I need to remove the seat upholstery to get the brackets out of the seat. Has anyone done this before? Is removing the upholstery something that is simple to do or am I asking for trouble?
phaeton2000 is offline   Reply With Quote Quick reply to this message
Unread 07-13-2009, 01:27 PM   #2
DirtyFrank
2007 WK
http://www.jeepforum.com/forum/showt...light=headrest
GET DIRTY!!
2007 Overland - Volant CAI, Firestone Destination A/T 245/70/17
HEMI CLUB MEMBER #18
DirtyFrank is offline   Reply With Quote Quick reply to this message
Unread 07-04-2013, 05:27 PM   #3
PReinie
1989 XJ Cherokee
Here's a site which shows what to do. http://www.justanswer.com/jeep/3wiuy...-cherokee.html
The 80B6F0A7 drawing on that site is looking at the passenger-side rear of the seat, looking forward. (It looks like the front part of the seat/head rest.)
The place where Mark is showing the small flat blade being inserted, on my 2000 Grand Cherokee Laredo is a lower piece/section of the "ring". I can press it inward with a finger if I also press down on the padding/fabric.
Maybe because mine is a Laredo there is also a rather large wide knob on the lower side of the rear part of the head rest. It has triangle on it "pointing" up. If I move it up the top of the head rest will tip forward allowing the head rest to remain on the seat back and clear the tipped forward seat portion so the seat back lays flat.
PReinie is offline   Reply With Quote Quick reply to this message
Unread 07-04-2013, 09:43 PM   #4
Scottso699
2006 WK
It has to be the dumbest design ever. I had to move my daughter to the middle when she graduated to a front facing seat! By the time my son came along we now have a different "family" car.
Scott
2006 WK Overland
2014 WK2 Limited
Scottso699 is offline   Reply With Quote Quick reply to this message
Unread 07-04-2013, 09:44 PM   #5
Scottso699
2006 WK
This is only for a WJ though - we need one for a WK.
Scott
2006 WK Overland
2014 WK2 Limited
Unread 07-05-2013, 03:25 AM   #6
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
I thought I had some pics, but I can't find them right now.
However, if you look at the rear of the headrest where it is connected to the seat, you will see two discs. There is a small vertical slit in each disc that you can stick a standard screwdriver into and hit a detent. Apply a little pressure and pull up on the headrest. Do that to each and the headrests will come off. I hope that makes sence?!
I'll keep looking for those pics...
See How It Was Made
Omelet is offline   Reply With Quote Quick reply to this message
Unread 07-05-2013, 03:32 AM   #7
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Oh I found one!!!
See How It Was Made
Unread Yesterday, 12:22 PM   #8
PReinie
1989 XJ Cherokee
I found out that on my 2000GC the knob is moved a bit and it allows the headrest to tilt forward getting it enough out of the way to tilt the backrest forward and it slides past the seat when raised against the back of the front seats. It isn't obvious until you've done it once.
