Remove 2007 Commander Rear Brake Rotor - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Remove 2007 Commander Rear Brake Rotor
Rear Disc Brake Conversion Kit- TJ,YJ,XJSWAG 50 Cal Ammo Can Mount With M2A1 Can~Artec JK 1 TON SWAP~
Unread 07-07-2014, 01:08 PM   #1
stevehendo34
2007 XK Commander
[SOLBVED}Is there a trick to getting it off?
It has a little silver cap/plug the size off an old dollar coin in the middle. Or do you just bang on it until it comes loose with a hammer like other cars?
It dose not want to come loose. I have the caliper off already.
Yes I took the O ring off.
I just hammered harder thanks all!
stevehendo34 is offline   Reply With Quote
Unread 07-07-2014, 01:13 PM   #2
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Make sure the parking brake is off.
Sounds stupid simple but is easy to overlook.
Ask me how I know.......;-)
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is offline   Reply With Quote
Unread 07-07-2014, 02:22 PM   #3
colinzj
2006 WK
No cap, but there may be a black rubber o-ring if the rotors haven't been replaced before.
If it's there, pull it and toss it in the trash can.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline   Reply With Quote
Unread 07-08-2014, 06:06 AM   #4
jbarrett
Always wondered about those o-rings. First time I changed my rotors, the o-rings got lost, so they were never replaced. What purpose exactly do they serve, and should they have been replaced? Sounds like colinzj thinks not!
jbarrett is offline   Reply With Quote
Unread 07-08-2014, 06:11 AM   #5
tom19511
2006 WK
They're on there to keep the rotors in place at the factory on the assembly line. You don't need them
Tom19511
tchristopher1@wowway.com
2006 Grand Cherokee Laredo 3.7
2007 Liberty Sport 3.7
tom19511 is offline   Reply With Quote
Unread 07-08-2014, 06:14 AM   #6
jbarrett
Interesting. Didn't know that. Thanks. Fortunately, my wheels & calipers do a pretty good job of holding the rotors on!
Unread 07-08-2014, 08:04 AM   #7
colinzj
2006 WK
I'm just following the good book. The FSM says throw it away, I throw it away.
Unread 07-08-2014, 08:42 AM   #8
kevsjeep
2006 WK
Anyone else reading this having trouble removing their brake discs. I had the same issue at the weekend and no end of hitting them would get them off. In the end i sprayed plusgas around the hole of the discs where the wheel nut studs come out, left it for a moment to soak and they came off with a slight tap of the hammer.
Kev
2006 Black WK Overland
#140 Black WK Club.
kevsjeep is offline   Reply With Quote
