REJ replacement - JeepForum.com
post #1 of 12 Old 08-21-2017, 03:57 AM Thread Starter
mronseth
2005 WK
REJ replacement
Hi,
I have a 2005 Grand Cherokee (WH) and just the other day the factory REJ lcd screen died on me. Searching the forum I can see I am not the first to experience this.
So, I can either live with a black lcd, repair it, buy a new or get a non Alpine unit. Repairing means getting hold of a replacement PCB and doing all the fiddly bits to get it working again. Buying a new unit is totally out of the question.
Replacing seems to me to be the cheapest and easiest way out. Have been looking around a bit and came across this:
http://www.ebay.com/itm/CHRYSLER-JEE...Grand+Cherokee
Does anybody have any experience installing a non Alpine unit? Is it hard, easy, will the new unit work properly?
I don't have an entertainment system installed, nor do I have Boston or Sirius in my car.
Cheers,
-Morten
mronseth is offline
post #2 of 12 Old 08-21-2017, 04:06 AM
kryton
There's a place in the uk that repairs them from £300. Used ones go for £400. You could buy the later version for extra features but make sure you buy a European head unit as the American ones won't work. Aftermarket are easy to install but if you want to retain steering wheel controls & it to work the factory amp (if you have one), you will need the correct harness & din plates which will come to about £100 but you can then fit any double din unit
Edit: are you 100% sure you don't have Boston? I thought all export models (wh) with nav came with Boston amp & speakers? I know there are a few odd spec ones out there but certainly worth double checking. There's 2 harness options, one for Boston with amp & one for non-amp so you will need to get the right one. Install for like-for-like is a 5 minute job, aftermarket is a couple of hours maximum
Edit again:
Bits you need for aftermarket are (if you have factory amp!):
Axxess CHTO-01 - Amplifier Interface Harness for Select 2005-2009 Chrysler/Dodge/Jeep Vehicles
Metra 99-6510 - Single DIN / Double DIN Installation Kit for Select 2005-2007 Chrysler/Dodge/Jeep Vehicles
Metra 40-CR10 - Antenna to Radio Adapter Cable for Select 2002-up Chrysler, Dodge, Ford, and Jeep Vehicles
Axxess ASWC-1 - Steering Wheel Control Adapter - Universal Steering Wheel Control Interface, Works with Nearly All Popular Aftermarket Receivers
Ensure you buy the correct harness. Ours being export are built in Austria. If you buy one of the other brands of harness, it is quite common for them to change the evic into German. Even if you change language back, it will revert to German again within a few seconds
kryton is offline
post #3 of 12 Old 08-21-2017, 04:28 AM Thread Starter
mronseth
2005 WK
Hi,
Thanks for info!
To be honest, I just assumed I don't have Boston as it doesn't say so anywhere. How can I tell?
Cheers,
-Morten
mronseth is offline
post #4 of 12 Old 08-21-2017, 04:28 AM
kryton
Here's the uk company
http://www.mapleaudio.co.uk
Might also be worth disconnecting the battery for 15 minutes to reset it. If it does come back on, you will need the radio code which should be in the front of your service book
kryton is offline
post #5 of 12 Old 08-21-2017, 04:30 AM Thread Starter
mronseth
2005 WK
Hmmm - won't resetting it wipe all channel-settings...?
mronseth is offline
post #6 of 12 Old 08-21-2017, 05:59 AM
kryton
Yep, will wipe everything. You could check your build sheet on the jeep website using your vin number but it's not 100% accurate or remove the r/n/s 1/4 panel in the boot to see if it's behind there
kryton is offline
post #7 of 12 Old 08-21-2017, 06:25 AM Thread Starter
mronseth
2005 WK
Just got build sheet from US help desk - seems I do have Boston audio :-)
mronseth is offline
post #8 of 12 Old 08-21-2017, 07:48 AM
kryton
Bonus. I thought you must have had. At least now if you go aftermarket, you have the correct shopping list above
kryton is offline
post #9 of 12 Old 08-21-2017, 08:13 AM Thread Starter
mronseth
2005 WK
Yes, thanks a bunch!
One small thing, though...the steering wheel control adapter has a mini-jack extension cable - what is it for? Is it needed in my case? Just curious.
Cheers,
-Morten
mronseth is offline
post #10 of 12 Old 08-21-2017, 09:31 AM
kryton
No worries, happy to help. Mini jack normally goes to the back of the aftermarket head unit iirc
kryton is offline
post #11 of 12 Old 09-21-2017, 01:51 AM Thread Starter
mronseth
2005 WK
Would a unit like the JVC KW-V235DBT fit the bill? it has a built in amplifier, is that a problem?
Thanks!
mronseth is offline
post #12 of 12 Old 09-21-2017, 08:21 AM
kryton
Built in amp shouldn't cause a problem but you will still need to correct harness to run through the factory amp. I have an old jvc in mine & it integrates well (avx820)
kryton is offline
