Recommended Mods for Beginners WK - JeepForum.com
post #1 of 14 Old 04-15-2013, 04:02 PM Thread Starter
calebmitchell
2007 WK
Hi all, it's my first time posting on the forums, but I've frequented them many times int he past couple years. I've had an '07 3.7L Grand Cherokee 4x4 Laredo for a couple years now, and I've recently become very interesting in upgrading some aspects on my vehicle. I've honestly spent a couple hours scouring the forums looking for past threads and posts addressing my questions, but nothing that definitively gave me the specific advice I was looking for. So thanks for being patient with me guys.
I've made a vague list of things I want to do to it, but before I even get started, I need to comprehend just how feasible it actually would to upgrade a "pedestrian" 3.7L. I live near the beach and would love to begin driving my Jeep out on the section where vehicles are allowed. Maybe you guys can help educate me and point me in the right direction. Also, I apologize if my knowledge-base regarding all of this seems "pedestrian" as well.
I was thinking about a 4-inch lift eventually, but wondering A) What kind of kit would give me everything I needed (best manu's etc.) as well as if it would even be a good idea with my 30-inch tires. I have Nitto Terra-Grapplers and while I love the tire, I'm wondering if it's not gonna be enough out on the beach sand or mild mud environments, especially at 30 inches. I would love bigger tires, but I unfortunately only have 10k miles on these TG's.
I also was thinking about a front skid plate (4xGuard.com looks to have some very nice plating) as well as a CAI eventually, maybe even a flowmaster for the ladies (joking), maybe even some new headlights and taillights, grill guard, and any other performance upgrades you guys can tell me about.
I'm looking for this to increase my vehicle's abilities off-road, as well as to get myself into the modding world a little. I have a lot to learn.
Thanks for all the info and time guys, cheers.
EDIT: Found this guy "Oducks" on the forums. He has an '05 that he modded up and put a detailed thread on how he modded his here and it looks great in my opinion. That's about where I want mine to end up. Besides the steep expenses, the main roadblock I see is my tire size and his. I've got 245's and he has 265's. But I'm looking for something similar to that.
calebmitchell is offline
post #2 of 14 Old 04-15-2013, 04:10 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Put some recovery points on the front and rear - air down the tires and hit the beach as it sits. Then decide more specifically what you want to be able to do with it.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is online now
post #3 of 14 Old 04-15-2013, 04:16 PM
Rob 99TJ
I would suggest spending another couple hours. Pretty much everything you're asking about has been addressed many times. I don't know why you say that you can't find 'specific advice'.
Just remember that the bigger tires you put on your Jeep the more they will drag the V6 power down. And if I was you I'd take it out on the beach the way it is. Good luck. Oh, and welcome to the forum.
99' TJ Gunmetal Blue Sport /w D30 No-Slip/D44 Trac-Loc, 5spd, 2" susp./1" body, 33"MT/R's/AR767's, Durabak, Currie, Warn
07' WK Silver 5.7 QD2, Bilsteins & front strut plates.
Rob 99TJ is offline
post #4 of 14 Old 04-15-2013, 04:20 PM
ca07wk
2007 WK
With the 4" super lift, you can run a 285 tire (33.5). May want a few performance mods to help push that size with the 3.7. You could go with the OME HD lift which is 2.5"-3" lift and run a 265/285 tire (32.5-33.5). For recovery points: 4xguard makes a brush guard that has d-ring mounts, aspen creek make d-ring mounts that replace the stock tow hooks. 4xguard, and steel armadillo make a few different skid plate options and rock rails.
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #5 of 14 Old 04-15-2013, 04:29 PM Thread Starter
calebmitchell
2007 WK
Good point, my buddies and I were thinking about at least just doing this as a starting point. Thanks for the help.
When I say specific advice, I mean that my limited knowledge of the subject matter, along with a few other factors having to do with my search criteria result in me finding information that is either above my head or not exactly what I was looking for. I will continue to search through the forums, but at some point I think a new thread is okay. And yeah I didn't want to go any bigger than 265 for that very reason (as well as mpg). Thanks for the welcome!
Thank you! I will definitely check those out, probably order whatever I pick in a week or two. Should be a fairly easy install. Also, found this when looking up the OEM lift, it's 2.25 inches it looks to be a little too cheap doesn't it? The kit with adjustable shocks is $380 and the optional front strut shocks are $160.
post #6 of 14 Old 04-15-2013, 04:37 PM
ca07wk
2007 WK
That's the rocky road budget boost kit, OME comes with struts, shocks, & front and rear springs. They have it on their site you just have to look for it. But its in the mid $700 range
ca07wk is offline
post #7 of 14 Old 04-15-2013, 05:45 PM
Mainsail
2005 WK
You don't need a lift to drive on the beach. Get the biggest tires that'll fit at the stock height and go with the recommendation to add recovery points. By bigger tire, think taller and wider, not just taller- you'll nee the floatation.
My jeep has 265/65-17s at stock height. The Pintlers push the wheels outboard about an inch on each side to clear the UCA bolt. As you can see, they fill the wheel-wells and don't stick out past the fenders.
EDIT to add: Make sure you hose out the undercarriage and wheel-wells thoroughly with clean water after a run on the beach. You'll want to pay attention to areas where sand can accumulate like the inner lip of the fenders. The salty sand will ruin your jeep in short order.
Poor grammar is something up with which I shall not put.
Mainsail is offline
post #8 of 14 Old 04-15-2013, 05:48 PM
volcy
2005 WK
Welcome! I recently put a RRO budget lift on mine along with some 265/70 tire and man what a difference. I put the before and after measurements in my post if you wanted to know what that combination yields.
http://www.jeepforum.com/forum/f67/r...tires-1506263/
volcy is offline
post #9 of 14 Old 04-15-2013, 08:02 PM Thread Starter
calebmitchell
2007 WK
Mainsail: You just had to put pictures up of your black WK (which resembles mine without the add-ons) to make me even more anxious to get this started didn't you? haha All kidding aside, your WK looks great man. I grew up on the beach and have had my fair share of "belly duty" growing up, preventing rust and the like, so I will most definitely be keeping track of that, thanks for the heads up. And believe it or not, yours is one of the few WK's like mine that I've seen with 265s and not something higher. And from the looks of yours, they seem to be exactly what I'm going for. Your advice was most helpful.
volcy: THANK YOU for the info. Also, I see you're in Wilmy. I'll be in Carolina Beach all summer lifeguarding at Fort Fisher. Maybe I'll see you out on the North End sometime and take a look at your 5.7, it looks great by the way.
post #10 of 14 Old 04-15-2013, 08:10 PM
AJeepZJ
2006 WK
Hey Caleb, i'll be in Ft Bragg in the Fall.. so if you need any help with those installs. Just shoot me a PM!
All Gear, No Skill.
AJeepZJ is offline
post #11 of 14 Old 04-16-2013, 04:51 AM
volcy
2005 WK
I have my season pass so I will be out there quite a bit. I took it out stock with just some crappy all season tires and it did great so you should be fine if want to take it out stock. I know we have different 4x4 systems but I know plenty of QTI people who have done some crazy stuff.
volcy is offline
post #12 of 14 Old 04-16-2013, 07:01 AM Thread Starter
calebmitchell
2007 WK
It's much more comforting to hear that from someone who's actually been out to the North End and knows what it's like. I will say though, I spent all weekend out there and the tide is much more invasive this year it seems... They've got those dredging pipes out there and around marker 16, high tide goes all the way up to the pipe at the dune wall, so unless you want a bunch of rust in about a year and a half you can't even go all the way out to the point.
But anyways, I've been looking up some research on QT1 and QT2 swaps, you know anything about those? I see it can almost be a plug and play swap... But my QT1 model has absolutely no 4x4 controls in the cabin. It's all automated and I'm curious if the new transfer case requires them. And if it's even worth it to do the swap.
post #13 of 14 Old 04-16-2013, 07:26 AM
volcy
2005 WK
Yeah that has always been a choke point but last year I remember that at high tide there was only about a car width of room to pass through. I was out a few weeks ago and saw they were dredging in front of marker 16, and it was low tide so I have no idea how far it would come up at high tide.
As far as a QT swap I haven't got a clue...sorry man. If you see me out at all feel free to stop by and say hey.
volcy is offline
post #14 of 14 Old 04-16-2013, 08:36 AM
ca07wk
2007 WK
There has yet to be a successful transfer case swap. You'd have to find a salvaged 3.7l with QT-2 and use the PCM and t-case module.
ca07wk is offline
