Recalls Blow. I need some help. GDE tune - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Recalls Blow. I need some help. GDE tune
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiFS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-25-2015, 11:55 AM   #1
boxboy5371
2007 WK
Ok so I just got a recall notice in the mail a couple days ago on the P73 final Drive control module. Yes i know there are a lot of threads on this. But my question is I have the GDE tune on the car now. Do i need to re-flash it to the factory tune? if i do how can i do it? with me switching from GDE to factory then back to GDE with anything mess up?
2007 WK CRD 95k
any input is great
thanks
boxboy5371 is offline   Reply With Quote Quick reply to this message
Unread 06-25-2015, 12:43 PM   #2
bersh
2008 WK
I've gone back and forth with mine a number of times and it's no big deal.
bersh is offline   Reply With Quote Quick reply to this message
Unread 06-25-2015, 01:33 PM   #3
TurboDiesel
2008 WK
it is if u have a dpf delete lol
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline   Reply With Quote Quick reply to this message
Unread 06-25-2015, 03:05 PM   #4
boxboy5371
2007 WK
No i just have the ECO tune. But do I have to go back to the factory flash for them to do the recall?
Unread 06-25-2015, 03:46 PM   #5
GDE
2005 KJ Liberty
They do not need to touch the engine ecm for the recall, but just in case it is always better to flash back to stock before a dealer visit. If they decide to do a random update on your ecm and the tune is installed it will render the flash tool a paperweight.
GDE is offline   Reply With Quote Quick reply to this message
Unread 06-25-2015, 08:38 PM   #6
crs524
2008 WK
P73 recall versus GDE
I just had mine done and P73 is a software update to correct N23 (service 4wd) and it reprogram Final Drive Control Module only.
Nothing to do with engine software.
Pierre
crs524 is offline   Reply With Quote Quick reply to this message
Unread 06-26-2015, 10:41 AM   #7
SSF556
2008 WK
Why do it....a lot cheaper and less headaches to just pull up the parking brake.
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 10:09 AM   #8
plunix
2008 WK
Can you explain why this is?
2008 Jeep Grand Cherokee CRD
GDE Hot Tune, DPF Delete, Turbo Res. Delete, Exhaust Res. Delete
plunix is offline   Reply With Quote Quick reply to this message
Unread Today, 11:45 AM   #9
crs524
2008 WK
The P73 is a software update for the Final Drive Control Module only. If they waste time ( which I doubt time is money) reprogramming the engine ECM then when you return home just use your flash tool to put in your GDE tune. et voila
Unread Today, 12:01 PM   #10
bersh
2008 WK
Considering it was GDE themselves that posted the message, I assume there's more to it than that.
I would think that worst case you'd just have to download the stock tune and send it to GDE and have them tweak it again.
Unread Today, 01:03 PM   #11
Zlartibartfast
2007 WK
My understanding is that the first time you run the flashscan to read your OEM tune, it locks the tool to your VIN. If the dealer reflashes your ECU to factory while your OEM tune is still inside the flashtool, you won't be able to load your GDE tune back into your ECU because the tool won't recognize your ECU anymore.
I may be wrong about this, but I know that my Hypertech tuner (which was mated to my old ZJ) became a paperweight when the ZJ was destroyed in a crash while the perf tune was still loaded in the ECU. Hypertech told me they could "recover" the programmer tool (set it back to "new" condition) for $200. I gave to a freidn who's JZ was still on the road, and let him pay the $200.
My advice:
do what GDE says. He IS Da Man. Never take your WK to a dealer with an aftermarket tune loaded in the ECU. (and if you have DPF deleted, never take it in NO MATTER WHAT!)
Fortunately for me, I found an independent shop with all the tools/scanners needed, and they totally dig my CRD with the hot tune loaded ;-}
Zlartibartfast is offline   Reply With Quote Quick reply to this message
Unread Today, 04:18 PM   #12
plunix
2008 WK
Couldn't I load the STOCK TUNE when I drop it off at the shop, and then load the HOT TUNE w/ DPF DELETE when I leave again?
I don't think enabling DPF regeneration, temporarily, will be a big deal if its removed. Might throw a code temporarily, but that's it, right?
