Recall (Dealer PCM/TCM Flashes) and Tuners - JeepForum.com
post #1 of 9 Old 08-08-2013, 06:34 AM Thread Starter
90grandoneer
90grandoneer's Avatar
2006 WK
Just thought I'd throw this out for those that run etiher a Superchips or Diablosport Tuner, who are not aware. If you take your vehicle into the dealer and they flash your PCM/TCM, for any reason, with your tune still installed, your tuner will not work when you get it back. It'll cost around $100 to get it reset by the tuner maker. YOU MUST RETURN YOUR TUNE TO STOCK BEFORE YOU TAKE IT IN FOR THE FLASH.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #2 of 9 Old 08-08-2013, 06:55 AM
Umbrella
2006 XK Commander
I've seen this question on a couple of the recall threads, glad someone finally answered it.
2006 XK 4.7 Limited
1995 XJ 4.0 Sport
Umbrella is offline
post #3 of 9 Old 08-08-2013, 07:18 AM
Hendrix9
2007 WK
After it gets flashed by the dealer (for the recall)will you have to send your new stock file back to your tuner to be adjusted again? Meaning if I flash back to my tuned file will it remove the corrected recall fix?
2007 CRD QDII
2010 Jetta Sportwagen TDI 6MT - hoping it gets bought back!
2004 QD 4.7 GC
2009 Rav4 v6
Hendrix9 is offline
post #4 of 9 Old 08-08-2013, 07:58 AM
GDE
2005 KJ Liberty
Always recommended to flash back to stock prior to a dealer visit. If they update the ecm code with the tune in, the flash tool will be locked. If you had it back to stock and the dealer updates the code, you can erase the flash tool with pc and perform a new 'stock' read of the ecm and email in for the new tune. GDE
GDE is offline
post #5 of 9 Old 08-08-2013, 09:16 AM
zc911
oh crap
zc911 is offline
post #6 of 9 Old 08-08-2013, 11:48 AM
Dusty280
2008 WK
What happens if you have the DPF delete option? If you reverse back to factory will the computer try and send oil to the DPF that isn't there any more?
Dusty280 is offline
post #7 of 9 Old 08-08-2013, 11:57 AM
zc911
Well after the latest flash, final drive or whatever update I was able to still load GDE. Tunes, Feeeeewww
But the Dpf is a good question!
zc911 is offline
post #8 of 9 Old 08-08-2013, 12:30 PM
Dusty280
2008 WK
You got the flash fix for the remote start so it doesn't shift into neutral when you activate the remote start? If so, when did you get it done?
Dusty280 is offline
post #9 of 9 Old 08-08-2013, 01:06 PM
zc911
yesterday
zc911 is offline
