recall 2005 to 2010 Grand Cherokees, 2006 to 2010 Commanders - Page 8 - JeepForum.com
post #106 of 301 Old 08-21-2013, 09:04 AM
R32R1
2006 WK
Originally Posted by jjarvis0007 View Post
I just talked to a shop foremen from a local Jeep dealer and he said it was a knucklehead not following the protocol on how to flash the system. He ended up being the foremen of the shop where I took my Jeep too.
Question is, if the flash was done, can they still start from the 1st step and do it over again? Or are they limited to just clearing DTCs at that point...
R32R1 is offline
post #107 of 301 Old 08-21-2013, 03:17 PM
longboy
2006 WK
Just picked up my WK from the dealer. Flash was done and no DTCs or "Service 4wd System" messages. I tested Low range before and after the service just to be sure, all is good.
2006 5.7l WK
longboy is offline
post #108 of 301 Old 08-22-2013, 01:49 PM
RockinR
2006 XK Commander
Originally Posted by blue3 View Post
I am glad I checked this thread before I headed in for the recall!
Is there a need to periodically run in 4Lo, other than to verify function before you might need to use it? Also, don't understand why you roll backwards.
There is no need to periodically run 4Lo, in fact it could be harmful if done on a dry surface for an extended period. I just do it for my own satisfaction, to make parts move, and I only roll a few yards. Why backwards, is just because I do this as I am leaving the driveway.
RockinR is offline
post #109 of 301 Old 08-22-2013, 02:29 PM
R32R1
2006 WK
Yes, for smoother engagement you should be rolling about 1/2mph. This should also only be done on dirt or slippery conditions. You will load up the drivetrain if you engage 4lo and drive around on dry pavement. End result would be a louder clunk when going back to 4hi- no bueno.
R32R1 is offline
post #110 of 301 Old 08-23-2013, 04:32 PM
Walt
2008 WK
Had the N23 recall FDCM flash performed this morning. Another item checked off the list.
I checked 4Lo operation before and they checked its operation afterwards. [Dealer also did the free 23-point safety inspection while it was in.]
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #111 of 301 Old 08-23-2013, 07:01 PM
R32R1
2006 WK
Okay so I went back today, brought the recall checklist, and now have 4lo. Apparently, they didn't follow it to a 'T'
R32R1 is offline
post #112 of 301 Old 08-24-2013, 10:30 PM
ChrisWK
2005 WK
Man if the dealership does not know how to flash it right and screw something up and want charge you for the stupid **** I think I will not do this recall I use my ebrake all the time.
Limited HEMI Dark Khaki Pearl SRT8 Full Body Kit, Roof Rails,SRT8 Engine Strut Bar, Lund Rear Spoiler, MYGIG INSTALLED with LOCKPICK, Kenwood Sub,AFE Intake, Taylor Spark Plug Wires,G2 Silver Painted Brake Calipers, Billet Tech Catch Can, Addco Sway Bars Front and Rear, Eibach Lowering Springs,Xenon Volt HID Lows 6k,Chrome SRT Reps
ChrisWK is offline
post #113 of 301 Old 08-24-2013, 10:40 PM
Bounty Hunter
Had mine done. It took a few extra minutes for them to clear the 'Service 4wd System' trouble code but it cleared fine. No problems since, 4lo works as it should.
You should get it done. If you have any doubts, print the PDF and take it in. Point out the section about the possibility of a trouble code and how to clear it. Easy peasy.
'95 YJ 2.5L
Bounty Hunter is offline
post #114 of 301 Old 08-25-2013, 08:03 AM
R32R1
2006 WK
Yea any doubt, show them 4lo works and make them notate that in the service order. If it wasnt for this forum,it might have been an oversight
R32R1 is offline
post #115 of 301 Old 08-25-2013, 09:47 AM
Walt
2008 WK
Originally Posted by R32R1 View Post
Yea any doubt, show them 4lo works and make them notate that in the service order....
That's exactly what I did. Had them test it afterward also.
Walt is offline
post #116 of 301 Old 08-25-2013, 10:47 AM
ecollins7
2006 WK
I had the code and yesterday they told me they screwed up and didn't follow the recall properly. It now works as it should.
ecollins7 is offline
post #117 of 301 Old 08-25-2013, 05:33 PM
GregK340
2007 WK
At least they were honest about it.
GregK340 is offline
post #118 of 301 Old 08-25-2013, 05:55 PM
ecollins7
2006 WK
Yeah, I wasn't a big fan of this dealership in the first place and didn't feel like driving 45 minutes to the next one. Their honesty helped their rep with me.
post #119 of 301 Old 08-25-2013, 07:50 PM
RockinR
2006 XK Commander
After having mine done twice now, I checked out the 4Lo system yesterday. I got the "Service 4WD System" message again with no T-case movement. It was working last week. I guess it will be another trip to the dealer this week. I wish I had never done the recall.
RockinR is offline
post #120 of 301 Old 08-26-2013, 08:53 AM
R32R1
2006 WK
Download the PDF with the step-by-step instructions on it. If they don't follow them exactly, it will not work. Most guys plug the tool in and hit update, as usual...its not the same.
R32R1 is offline
