recall 2005 to 2010 Grand Cherokees, 2006 to 2010 Commanders - Page 6 - JeepForum.com
post #76 of 301 Old 08-19-2013, 09:49 AM
R32R1
2006 WK
Originally Posted by LJS8510 View Post
R32R1
You could not go into 4-low after the recall fix?
Correct. I'm not the only one on here. I'm having the code read this afternoon and I'll post what they say. Apparently resetting it helped one user, but I'm skeptical.
R32R1 is offline
post #77 of 301 Old 08-19-2013, 09:50 AM
longboy
2006 WK
I have my appointment setup for Wednesday morning. I figure I'd rather have this recall done now before winter hits and I might need 4LO (if I have the same issue as R32R1).
2006 5.7l WK
longboy is offline
post #78 of 301 Old 08-19-2013, 10:53 AM Thread Starter
LJS8510
LJS8510's Avatar
2015 WK
Keep us posted
Thanks
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #79 of 301 Old 08-19-2013, 11:04 AM
WmassWK
2006 WK
R32r1- I called the recall center fri after my issues began. They said it shouldnt be a factor. Prior to doing the recall I retd the jeep to stock settings (superchips) but forgot to return to the factory tire size. After *****ing with chrysler and the dealer I pulled out the tuner. After resetting the tire size I had 4 lo again. I then reinstalled the 89 tune and appropriate tire size. All is well. ANYONE that runs a tuner should reset to factorycsettings prior to a dealer flash.
The code should be c140f transfer case sensor erratic performance... resetting the code did nothing for me. I came right back after pulling the t lever.
WmassWK is offline
post #80 of 301 Old 08-19-2013, 02:45 PM
R32R1
2006 WK
Yes, after getting my GC scanned, I was also getting the C140F code. Reset it and nothing happened. I don't have a tuner, but I'm running 31's. That shouldn't be a factor at all, other than an incorrect speedometer. My jeep still thinks its OEM tires.
I'm skeptical that replacing the T-Case motor will do anything. I ran 4LO just last week and it was fine...checked the harness and it's clean as a whistle. That code is for a sensor inside of that motor. The only way to replace the sensor is to replace the entire motor. Looking like $193/remanufactured.
Eric
R32R1 is offline
post #81 of 301 Old 08-19-2013, 03:34 PM
R32R1
2006 WK
I just ordered the T-Case motor to rule that out. I should have it within a couple of days and post back if the problem persists. ($188/ Shipped from Rock Auto- best price I found).
R32R1 is offline
post #82 of 301 Old 08-19-2013, 04:01 PM
RockinR
2006 XK Commander
Originally Posted by trax95008 View Post
Or possibly be causing some of the "service 4WD system" messages...
I took my Commander in last Tuesday. After the reprograming, a few days later I tried to shift into 4X4 Lo, and the transfer case wouldn't budge, also gave me a "service 4x4 system" message. I took it back to the dealer, and first they tried to tell me that the transfer case actuator was bad, but it had nothing to do with the recall. I had read up on the recall, so I already knew that it was in fact all about the transfer case. The dealer checked with Chrysler, and lo and behold there are things that must be disconnected before reprograming. They had to do the reprogram over with certain components disconnected. That fixed the problem. They also gave me a wash, detail, and filled up the gas tank for all of my trouble!
RockinR is offline
post #83 of 301 Old 08-19-2013, 04:04 PM
RockinR
2006 XK Commander
R32R1
Read the previous post. I had the same problem. It is caused by the dealer not following the correct proceedure during the reprogram.
RockinR is offline
post #84 of 301 Old 08-19-2013, 04:08 PM
suzieque
2008 WK
this frightens me, I want some other poor suckers to go first and get the recall, though being this time of year few folks would test 4 low until months from now and get the error!
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #85 of 301 Old 08-19-2013, 04:55 PM
RockinR
2006 XK Commander
Well I have a habit of shifting into 4 Lo every Saturday morning, rolling back a few yards, then shifting back to high. That is why I caught it fairly quickly. What frightens me is the dealer wanting to charge me $600.00 for a new T-Case actuator. If I hadn't been fairly knowledgable about the recall I would have paid for a new Actuator, and it still wouldn't have fixed it. I am pretty sure they were supposed to disconnect the final drive shift module prior to the reprogram, which they did the second time.
RockinR is offline
post #86 of 301 Old 08-19-2013, 05:00 PM
longboy
2006 WK
^ and that's exactly why I'd like to get the recall done now and have time to make sure everything is operating as intended, not when the snow flies or when I'm on a trail.
2006 5.7l WK
longboy is offline
post #87 of 301 Old 08-19-2013, 05:13 PM
Walt
2008 WK
Glad I waited. I did check the operation of 4Lo today. The transfer case on my Heep goes in-and-out without codes. We'll have that discussion when the Service Manager & I talk so we both understand the correct procedure. In fairness, the Service Manager and the technician who does this work are both top-notch, but I'll ask anyway to preclude a return trip. [My dealer makes up for all of other bad dealer service depts reported elsewhere.]
Belt & suspenders to hold up my pants.......................
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #88 of 301 Old 08-19-2013, 05:28 PM
BAH101
2008 WK
Maybe a good idea would be to video putting the Jeep in 4LO before taking it in, just to prove it works. Also, for me, I'll check the 4LO before leaving the dealer lot, after all I have read here.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #89 of 301 Old 08-19-2013, 05:46 PM
jjarvis0007
2005 WK
I'm scheduled for 8:30 tomorrow morning. I'll be bringing out the service manager and explaining the potential problem and showing him my 4 Low works. When I pulled in the dealership this morning to see if I could get it done I made sure to engage the 4 Low. It all worked. Tomorrow will be interesting for sure.
jjarvis0007 is offline
post #90 of 301 Old 08-19-2013, 05:53 PM
pinstripefan90
1994 ZJ
I'm a chrysler dodge jeep tech and all it is is a flash to the FDCM (Final Drive Control Module) and w/ the new software supposedly it will avoid the possibility of this incident occurring.
- Jake
pinstripefan90 is offline
