recall 2005 to 2010 Grand Cherokees, 2006 to 2010 Commanders - Page 13 - JeepForum.com
post #181 of 301 Old 09-26-2013, 02:57 PM
Burnerman
Burnerman's Avatar
They replaced the actuator free on my wife's gc. 3rd owner 76000mi.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #182 of 301 Old 09-26-2013, 06:46 PM
bytehoven
2014 KL Cherokee
excellent!
bytehoven is offline
post #183 of 301 Old 09-26-2013, 08:31 PM
Hemily_GC
2005 WK
So its been 4 days with out my jeep with the only update being 2 days ago when they insisted that it was giving the service 4wd code because it needed a new battery. Well that proved to not be the case. So after not hearing anything I decided to give them a ring today. The SM said that they had it down to the actuator and was waiting to hear back from his manager to see if the part was going to be covered. I simply stated that it had no problem going to 4wd low until I got it back from them and do not plan on paying for any parts that they broke.
05 WK Grand Cherokee 5.7 Hemi!!!! QD II
Hemily_GC is offline
post #184 of 301 Old 09-26-2013, 08:37 PM
jjarvis0007
2005 WK
Imagine that. Just be persistent with them. The actuators are backordered right now anyway. There's suppose to be 100 available within the next couple weeks in our state.
jjarvis0007 is offline
post #185 of 301 Old 09-26-2013, 09:35 PM
Chirpz
Chirpz's Avatar
2007 WK
Originally Posted by jjarvis0007 View Post
I just found out the 2005 only had 3yr/36,000.
So I'm getting the shaft here
YEP! My 07 has the same warranty.... lack of warranty. I bought an extended that has helped on one occasion with another issue.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #186 of 301 Old 09-26-2013, 09:47 PM
jjarvis0007
2005 WK
Don't let them fool you. I've had it in 3 times for the recall and they're finally going to fix it for me.
post #187 of 301 Old 09-26-2013, 09:58 PM
onlyone
onlyone's Avatar
2014 JK Wrangler
I had my recall done about a month ago and just tried the 4low today and sure enought "service 4wd" came on. Called the dealer, brought it in and they said it was the actuator. Then they tried to hand me a 800 bill and I laughed. I have the lifetime warranty. I didn't pay a dime. It fixed it. They claimed the flash had nothing to do with the actuator going bad. I laughed once again. I told him that the jeep has never had a problem and it's funny that I had just been in 4 low all day the day before. Berthod Motors service writers in Glenwood Springs, Co SUCK.
Thank you Jesus
2014 Wrangler Sport 1.5" spacers in front .75 rear, 1" BL 255/80/17 BFG KM2
onlyone is offline
post #188 of 301 Old 09-26-2013, 10:06 PM
Hemily_GC
2005 WK
What did they attempt to do the first 3 times, reflash it??
post #189 of 301 Old 09-27-2013, 05:28 AM
jjarvis0007
2005 WK
Yes. Then the third time the shop foreman, which I was lucky enough to know from a hunting forum, told me it was the actuator and to call and deal with Chrysler about it. The day I brought it in for the 3rd time the service manager had met me when I pulled in. He said he just got the recall done and should check his Jeep. Well low and behold his isn't working after the recall either. So they've ordered some actuators to replace what the N23 recall has messed up.
post #190 of 301 Old 10-03-2013, 03:57 AM
Ditchd
2009 WK
Can't find my original post but here goes. I suffered from the post final drive flash update woes. I did a massive amount of research and went back to the dealer who stated they'd done dozens and mine was the only one faulty!!! Hmmm.
There's no doubt that the flash upgrade, providing lo was working ok, can kill lo selection and bring up the service 4wd. It's one of those things like when you update windows and it doesn't quite work right.
My lo worked fine then a few days after the update when I went to use it , didn't and threw up the service warning with no dtcs at all.
Very importantly if you get the diagnostics done at that stage you may find components diagnosed as faulty and replacing them changes the service 4wd warning. I don't know why and I'm sure I'll take some flack but that's the way it is. However if you have the flash redone before going onto the diagnostics and it works ie clears service 4wd and lo engages , all will probably show as healthy. In my case they are because they now work. ( at the moment lol)
A re flash before doing anything else fixed it 100%.
In fairness to them , the dealer acknowledged they have done some research and the word is exactly as I stated at the beginning. The flash can produce spurious errors.
Hope this helps ��
On a slight aside I've noticed some "if it ain't broken don't fix it" comments , ie if you've got no probs don't go for the flash. Fair point but I wil say I'm pretty certain there's a couple of slight nuances within the drive upgrade. The main one is my auto box was always hesitating about going into overdrive/5th bumbling along at 30 mph. Now it goes in every time as if it's thoughts have been reprogrammed ? That's a saving of a few hundred revs if I recall and associated fuel saving. Fits in with Fiats stated objective to increase fuel economy and decrease emissions across the range. They're still tinkering with the v6crd ee me though it's meets baby, it goes into the new 300s.
Happy days ��
Ditchd is offline
post #191 of 301 Old 10-03-2013, 03:59 AM
Ditchd
2009 WK
Seems to tie in with my research/experience. Is it sorted ?
Ditchd is offline
post #192 of 301 Old 10-03-2013, 02:38 PM
jjarvis0007
2005 WK
Taking my Jeep in to the dealership first thing in the morning. They're replacing my transfer case actuator due to it failing after the recall. Got lucky there are some good guys there to take care of it for me.
post #193 of 301 Old 10-03-2013, 03:17 PM
suzieque
2008 WK
If my actuator fails, i will ask for the old one so i cut it open and see what fails.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #194 of 301 Old 10-08-2013, 05:09 PM
inhidin
2014 WK
I was following this thread for awhile of and on. I waited to get recall done - chrysler had sent me a couple of mailer reminders to complete it. I had it done in August, but up until today I never tried 4LO. Instantly after pulling my transfer case lever I got the "Service 4wd warning". MIne will be going back to the dealer tomorrow morning. I hope that I do not have to deal with the same level of incompetent dealers that so many of you have had. I will be armed with the information provided here, and I'm considering printing out all 13 pages of this thread as additional ammo. Wish me luck.
inhidin is offline
post #195 of 301 Old 10-08-2013, 06:21 PM
jjarvis0007
2005 WK
What's funny is when the service department went into the computer to put in the code to pay for my out of warranty "warranty" work. It said Faulty Transfer Case Actuator due to N23 Recall! Imagine that. If I didnt know the shop foreman I wouldn't have known that.
