recall 2005 to 2010 Grand Cherokees, 2006 to 2010 Commanders - Page 10 - JeepForum.com
post #136 of 301 Old 09-04-2013, 10:07 AM
Dusty280
2008 WK
error code P0700
Had my reflash done couple of weeks ago. Checked and it appears to shift into and out of 4 lo (only drove about 10 feet to shift in and out). However, twice in the last couple of days when starting from a stop the engine rev properly, but it was like I had no power, like the transmission was slipping. Pulled over. Shut everything off. Restarted and all was fine.
2nd time I noticed the manual shifter feature on the shifter knob would not work and I now have an error code P0700. No service 4 wheel drive message. Any ideas? thanks
Dusty280 is offline
post #137 of 301 Old 09-06-2013, 04:48 PM
jjarvis0007
2005 WK
Checked for 4lo today out of curiosity and message popped back up
I'm a little hot about it
jjarvis0007 is offline
post #138 of 301 Old 09-07-2013, 09:52 PM
R32R1
2006 WK
It revved up while driving?
R32R1 is offline
post #139 of 301 Old 09-08-2013, 04:46 PM
jjarvis0007
2005 WK
Got a appt at the dealership first thing in the morning.
post #140 of 301 Old 09-08-2013, 05:54 PM
Walt
2008 WK
Sounds like something else is going on with yours. This response only addresses the FDCM directly.
I checked 4-Lo before the N23 FDCM reflash. No DTC's
Had dealer check it after also. No DTC's.
After your post, I checked it again. No DTC's.
I always go after the small, free, and easy things first.
Think I would start by checking & cleaning the connections on the FDCM (under back seat on mine) and at the xfer case. Remove, clean, and add a small dab of dielectric grease at each terminal. Since these things run at low voltage, a little corrosion buildup can cause a high resistance fault and a weird result.
Disconnect your negative battery terminal first before pulling any connections. It will also start you fresh and DTC-free. The DTC history should remain in the PCM memory IIRC.
After that, you might want to do the same thing with xmission electrical connections that are subject to moisture and road dirt. Some other members have reported crud buildup in the shifter module (under the handle). They cleaned it and all was well. I haven't pulled mine, so this is 2nd hand info and may be worth what you paid to get it.
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #141 of 301 Old 09-08-2013, 11:02 PM
RockinR
2006 XK Commander
Originally Posted by r32r1 View Post
i'm on the phone with the recall center. Apparently this is the 'first' report of the 'service 4wd system'.
if you are experiencing 'service 4wd system':
please call this number- 1-800-853-1403
report the problem with the last 8 of your vin. Chrysler advised it's not a problem until more people report it. I wish we can do a roll-back to the previous software release
worth repeating
RockinR is offline
post #142 of 301 Old 09-08-2013, 11:10 PM
RockinR
2006 XK Commander
Originally Posted by LJS8510 View Post
If I understand you correctly this (actuator) is the actual problem? not the cracked boards or is yours just an isolated incident?
Honestly, I was given such a run around that I don't really know. I am taking it to another Jeep dealer this week to start all over. The previous dealer really torqued me off when first mentioning the actuator. He told me it would cost $600, but he would give me a deal for $300. After my insistance that it was a drive train warrenty issue, they realized it was covered. That is when I started to lose confidence
RockinR is offline
post #143 of 301 Old 09-09-2013, 08:38 AM
jjarvis0007
2005 WK
Went to pull out in traffic this morning and something started grinding. Getting a service 4wd system and service electric brake system message now.
ABS and traction control lights are on too. Amazing how all this happened after taking it to the dealer
post #144 of 301 Old 09-09-2013, 11:11 AM Thread Starter
LJS8510
LJS8510's Avatar
2015 WK
Sorry to hear that. You got me thinking again not to bring it in😁.
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #145 of 301 Old 09-09-2013, 12:46 PM
jjarvis0007
2005 WK
I wouldn't if I were you.
post #146 of 301 Old 09-09-2013, 05:47 PM
Chirpz
Chirpz's Avatar
2007 WK
I'm holding off on getting the "fix" too. Mine has no symptoms so why fix it.
A work around software solutions sounds fishy to me. Don't they optimize their software to their hardware when they design it? Seems like a work-around would leave some holes somewhere.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #147 of 301 Old 09-09-2013, 05:55 PM
jjarvis0007
2005 WK
I've got all kinds of warnings now. I'm sure it has something to do with the flash they did. Never had problems before
post #148 of 301 Old 09-09-2013, 10:06 PM
BAH101
2008 WK
I think I might just hold off to. After hearing all the issues, I wouldn't be surprised if they come out with an update on he fix.
I carry a small set of folding wheel chocks, I'll use them if I have to park on a hill (gotta fix my ebrake).
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #149 of 301 Old 09-10-2013, 07:43 AM
jjarvis0007
2005 WK
I would. Wish in would have never done mine. Now its dying when coming to a stop. Still have the service 4wd message, and service electric brake system. Not throwing any codes. Never done any of this before the recall.
post #150 of 301 Old 09-10-2013, 07:50 AM
R32R1
2006 WK
Not to play devils advocate, but mine gets close to dying sometimes too; it's not the flash. They do that and multiple people on here (way before the flash came out) have experienced this. The flash only focuses on that one module and nothing else. Anyone who is saying they saw differences, etc, is just prone to the placebo effect.
R32R1 is offline
