Rear Upper Control Arms - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Rear Upper Control Arms
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEYukon Ultimate 35 axle kit for c/clip axles with Yukon ZipNitro Gear Packages Now Available at Rockridge 4wd
Unread 12-10-2014, 11:15 PM   #1
Loth
2005 WK
So Ive had my superlift on for a few weeks now. Ive had some vibration since the lift went on so i ordered the rear upper adjustable control arms from rustys to correct the pinion angle. I cant seem to find any info on installing these. It looks like the gas tank is in the way for the drivers side. Has anyone done this that can offer any advice or pictures?
Loth is offline   Reply With Quote Quick reply to this message
Unread 02-02-2015, 09:11 PM   #2
scootter82
2009 WK
Did you ever get around to installing these? I finally got mine in this last weekend and it was a pain. You do need to drop the gas tank, but if you have a couple of floor jacks, you can just lower it without disconnecting the hoses. The bushings on rusty's uca's are a very tight fit on the axle side. I used a steel rod and a small sledge hammer to bend the bracket back and it was still a super tight fit. I like the end result, though. Back end is centered, where it wasn't before, and feels more solid going over bumps.
OME HD, JBA UCA, Rear Adj TB, Catch Can, K&N CAI, Gibson CB, MM TB, Flaspaq, Full LED swap
scootter82 is offline   Reply With Quote Quick reply to this message
Unread 02-03-2015, 02:31 AM   #3
Loth
2005 WK
Ya, that was me that commented in your thread about dropping the tank.
Unread 02-03-2015, 10:27 AM   #4
scootter82
2009 WK
Oh lol. And you didn't have any fitment issues with the uca? Did you get the poly or the heim joints?
Unread 02-03-2015, 05:02 PM   #5
Loth
2005 WK
The body side are poly bushings. I didnt really have any trouble getting them in; just a few whacks from my mallet.
Unread 02-03-2015, 11:17 PM   #6
twistedlizard72
2007 WK
Did the adjustable UCA's solve your vibration issues?
Kevin K.
WANTED: Steel Armadillo Sliders/Rock rails.
twistedlizard72 is offline   Reply With Quote Quick reply to this message
Unread 02-05-2015, 12:47 AM   #7
Loth
2005 WK
Not completely but it helped a lot. I think the rest of the vibration is coming from the front driveshaft.
Unread 02-05-2015, 09:37 PM   #8
scootter82
2009 WK
Did you order the heim set? Both of my ends were poly, which is what made it a pain.
Unread 02-10-2015, 12:41 PM   #9
Loth
2005 WK
Yes one side has heim joints but I installed the poly bushings on the body side
