Rear tracbar issue - JeepForum.com
post #1 of 20 Old 04-19-2014, 01:14 PM Thread Starter
christiang26
2009 WK
Rear tracbar issue
I am having rubbing issues between the rear tracbar and the unibody, it started several days ago and I don't know why.
Anyone had any similar issues?
christiang26 is offline
post #2 of 20 Old 04-19-2014, 02:19 PM
BoraBora
2015 JK Wrangler
No but mine just started making popping noises again and the bushing has gone bad on the passenger side. Looks like the problems with the Rusty's track bar are surfacing.
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #3 of 20 Old 04-19-2014, 02:37 PM Thread Starter
christiang26
2009 WK
I installed rustys adjustable upper control arms like a month ago, so I don't think that the UCA are the issue
post #4 of 20 Old 04-19-2014, 05:11 PM
Jeepforthewin
2010 JK Wrangler
Is the mount bent at all? Never seen this issue before.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #5 of 20 Old 04-19-2014, 06:56 PM Thread Starter
christiang26
2009 WK
I checked and it doesn't look bend. the wk didn't got rear ended or nothing, it started two Fridays ago while going out to the beach.
post #6 of 20 Old 04-19-2014, 09:52 PM
BoraBora
2015 JK Wrangler
Bushing for the track bar, not the UCA. Sorry I should have made that clearer.
BoraBora is offline
post #7 of 20 Old 04-20-2014, 01:01 AM
modernblueWK
Are you lifted?
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #8 of 20 Old 04-20-2014, 05:58 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Lifted or not something is off. The passenger rear is pushed back relative to the driver rear. Either the entire axle or the trackbar mounts.
OP-
what does the bushing on the passenger side look like as well as that end of the trackbar in general?
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #9 of 20 Old 04-20-2014, 06:28 AM
sk1er18
2007 XK Commander
Looks like you need to shorten the UCA's and/or bend that metal out of the way. You've pushed the axle too far back.
-Matt
sk1er18 is offline
post #10 of 20 Old 04-20-2014, 08:27 AM Thread Starter
christiang26
2009 WK
The wk is lifted 4.5". The UCA were extended like 1/2 from oem.
post #11 of 20 Old 04-20-2014, 08:43 AM
JeepN4KC
JeepN4KC's Avatar
Sounds like the cause of the issue.
~Mike~
WK
XJ
JeepN4KC is offline
post #12 of 20 Old 04-20-2014, 01:16 PM Thread Starter
christiang26
2009 WK
I will try and bend were the tracbar is hitting, because if I return the UCA to stock length, the driveshaft will start vibrating around 140 km/h.
post #13 of 20 Old 04-20-2014, 04:32 PM Thread Starter
christiang26
2009 WK
This is how it looks on the passenger side
post #14 of 20 Old 04-20-2014, 05:22 PM
pancake
2005 WK
Not to derail, but what lift do you have? JBA springs? I like the red
05 Jeep WK Laredo 4.7L QTII | K&N CAI | Flowmaster 40 | ...lift and such in planning phase...|
pancake is offline
post #15 of 20 Old 04-20-2014, 05:25 PM Thread Starter
christiang26
2009 WK
It is a superlift with JBA springs.
