Rear Swaybar bolt - JeepForum.com
post #1 of 6 Old 08-05-2013, 01:29 PM Thread Starter
wkorbust
Rear Swaybar bolt
I was stripping parts off my undercarriage to take care of some rust and POR-15 the underside and one of these parts was the Addco rear swaybar, which rust has completely eaten off the paint.
As Murphy would have it, 3 of the 4 bolts came out without any problem, but the top bolt on the driver side bracket decided it had enough and sheared off not 3 twists in to removing it. For anyone not familiar with this part, I can't use a bolt extractor because there is not enough room due to the fuel tank being right there.
Open to any suggestions. Right now the jeep is still jacked up with the rear wheels off while I figure this out. I don't have an air chisel, but have been debating on that route to get one and just knock the welded nut off the frame. Not sure if that would be easier, or harder than just dropping the fuel tank to use a bolt extractor.
wkorbust is offline
post #2 of 6 Old 08-05-2013, 09:48 PM
tnadanzig
tnadanzig's Avatar
2007 WK
I had the same problem and punched out the nut and put new bolt and regular nut on. My bolt was on the bottom so it was easy to get a wrench on.
CB Engineering
CB-engineer.com
2014 WK2 EcoDiesel - CBE Parts
2008 3.0L CRD WK LTD - GDE Tune 3.07 gears
2007 3.0L CRD WK LTD - Go Fast Parts
2005 KJ CRD - GDE Tune
tnadanzig is offline
post #3 of 6 Old 08-06-2013, 08:47 AM Thread Starter
wkorbust
What did you use to do the punching?
wkorbust is offline
post #4 of 6 Old 08-06-2013, 09:19 PM
tnadanzig
tnadanzig's Avatar
2007 WK
I used a chisel. Only required a few good hits, they are not welded on very well.
CB Engineering
CB-engineer.com
post #5 of 6 Old 08-08-2013, 07:59 PM Thread Starter
wkorbust
Mine must be welded on more thoroughly. I hit that nut from every angle I could with a punch and sledge hammer and all I got a sore shoulder and a dented nut (on the jeep!)
Round two tomorrow...
wkorbust is offline
post #6 of 6 Old 08-12-2013, 06:51 PM Thread Starter
wkorbust
Victory! Bigger chisel and even bigger hammer. I had gotten to the point where I started to consider removing the spring from the suspension to get a better angle and "pop".
Now on to the point of my project - POR15
wkorbust is offline
