rear sway bar - JeepForum.com
post #1 of 12 Old 09-20-2017, 08:49 PM Thread Starter
nvrdone1
2007 WK
rear sway bar
on an 07 wk, do the parking brake cables go over or under the rear sway bar? thanks
nvrdone1 is offline
post #2 of 12 Old 09-21-2017, 12:02 PM
Nejeep
If its like my 06 WK they are routed under the sway bar at the differential and then go directly behind the sway bar mounts on the axles.
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #3 of 12 Old 09-21-2017, 02:15 PM
badgerwithhands
2007 WK
That's what I remember as well. Some have put them over when lifted.
07 WK Overland CRD, cargo LEDs, OME HD, MOPAR skids, rack,
future mods: tires, lights, CB, skids,
badgerwithhands is offline
post #4 of 12 Old 09-21-2017, 07:10 PM Thread Starter
nvrdone1
2007 WK
ok, thanks for the info. ive got a "moaning" noise in the rear area when I go over a speed bump. I think the cables may be rubbing on the sway bar
nvrdone1 is offline
post #5 of 12 Old 09-22-2017, 10:41 PM
azzkicker
2007 WK
I have the superlift, and I had to put them over the sway bar. It looked fine normally, but when the rear suspension flexed down, it would try to hang from the e-brake cable.
In this photo, it's on a lift and you can see the cable is under tension. I re-routed over the sway bar, and everything looks great. I'm not sure what happens if you don't have the lift.
07 WK 5.7 QD2, 4" lift, 33X10" tires, M8000s
ARB twin air,Dual AGM group 49, sliders and skids
azzkicker is offline
post #6 of 12 Old 09-23-2017, 09:20 AM Thread Starter
nvrdone1
2007 WK
ok, I guess I need to find a wk that hasn't been lifted & look at it. if the brake cable goes over the bar it may be rubbing & causing the moaning noise. thanks
nvrdone1 is offline
post #7 of 12 Old 09-23-2017, 09:43 AM
Nejeep
As previously noted, my 06 WK brake cables run under the sway bar, but FWIW it looks like one of them rubs on the differential when I looked under there. No unusual noises tho.
No lift and OEM factory shocks.
Nejeep is offline
post #8 of 12 Old 09-23-2017, 09:56 AM
underscore
2007 WK
I think that may be a completely different issue.
2007 WK CRD QDII OME MD OMG WTF BBQ
underscore is offline
post #9 of 12 Old 09-23-2017, 10:53 AM
badgerwithhands
2007 WK
Agreed
post #10 of 12 Old 09-23-2017, 05:08 PM Thread Starter
nvrdone1
2007 WK
ok, if the cables don't cure the noise, I guess I start tearing the rear interior out until the noise goes away. ive all ready replaced the spring cups / insulators and the trailing arm bushings.
nvrdone1 is offline
post #11 of 12 Old 09-23-2017, 05:36 PM
Nejeep
So is the noise coming from the interior or under carriage? Maybe have someone else drive while you sit in the back and listen.
One fairly simple test is to remove the spare tire or disconnect one end of the sway bar to see if that stops the noise. You can also remove the rear shocks fairly easily for another test.
Nejeep is offline
post #12 of 12 Old 09-23-2017, 08:55 PM Thread Starter
nvrdone1
2007 WK
good info nejeep - I will try those ideas as a next step. thanks.
nvrdone1 is offline
