Rear overload spring for the rear of the WK? - JeepForum.com
post #1 of 9 Old 03-23-2009, 11:16 AM Thread Starter
suzieque
2008 WK
I had added Roadmaster overload springs to my Durango, it was a nice system kept the truck more level, than the stock leaf springs while towing. It also limited bounce when going over bumps when towing.
The Jeep Grand Cherokee doesn't use leaf springs and tends to squat more than I like when hooked up. Is there an aftermarket spring overload system compatible with the Jeep Grand Cherokee?
suzieque is offline
post #2 of 9 Old 03-23-2009, 11:56 AM
Spider-One
2008 WK
I've heard of guys using air bags, but not much else.
2008 GC CRD, OME 2" lift kit, 265/70/R17 Cooper Discoverer S/T's, 1.5" Spidertrax spacers, gutted turbo resonator
Spider-One is offline
post #3 of 9 Old 03-23-2009, 01:41 PM
JMorash
2005 WK
Coil-Rite air helper springs. Made by firestone, very durable, adds lift, imroves ride quality and such.
2005 WK 5.7L Hemi
HEMI Club Member #28
3.5 Rock crawler lift.265/65R17 Toyo AT SuperChips Flashpaq MDS delete
JMorash is offline
post #4 of 9 Old 03-23-2009, 01:56 PM Thread Starter
suzieque
2008 WK
thanks, I will check on those too!
I also found these
http://www.airliftcompany.com/online_catalog.html
I'm concerned about affecting the stock ride height and the stock ride stiffness when not towing. I liked the Roadmaster because they really didn't affect anything until a load was applied to the back.
suzieque is offline
post #5 of 9 Old 03-23-2009, 02:11 PM Thread Starter
suzieque
2008 WK
here is a website for the coil-rite
http://www.firestoneindustrial.com/riderite/rrkit/
they seem to be the same cost as the airlift product.
suzieque is offline
post #6 of 9 Old 03-24-2009, 01:10 PM
CanDieselJeep
2008 WK
I just installed a set of AirLift brand airbags in our Jeep on Saturday! Not the easiest process but anyone with some mechanical knowledge should be able to handle it. I'm a license mechanic myself! I drove it with the bags aired up to max pressure, rides a little stiff, aired them down to the recommended 5 psi. Could not notice any difference from stock. Had a set of the firestone airbags on an old chevy and thought I would try a set of these since I don't want to bag out the springs while hauling 3 quads and gear when the boys and I head out for a day of muddin! Time will tell with this set but for the cost of the kit, I hope they work out. Only cost $105 Can with tax!
CanDieselJeep is offline
post #7 of 9 Old 03-24-2009, 01:32 PM Thread Starter
suzieque
2008 WK
thanks for info candieseljeep. The instructions for the airlift brand suggested the rear springs had to be removed to install, while the firestone airbag showed leaving the rear springs in place and then installing and that sounded easier.
Did you notice any difference in quality between the airlift and the firestone airbags?
suzieque is offline
post #8 of 9 Old 03-24-2009, 02:03 PM
anywaytothetop
2006 WK
I have the Firestone airbags and love them. If you tow anything you will like them too. No problems with them for the last 2 years.
anywaytothetop is offline
post #9 of 9 Old 03-24-2009, 03:59 PM
CanDieselJeep
2008 WK
It is tough to compare because the firestones I had in my old truck were like mini tractor trailer air bags and the jeep ones go right up inside the rear springs. They are a totally diiferent design. The Firestones and airlift are virtually the same. It is very is to remove the rear springs on these units. All you really need is a good floor jack and some taller jack stands. You need to remove the springs with the airlift kit because you must drill a hole in the bottolm spring perch for the air line and nipple coming out of the bottom of the airbag.
Rear Spring Air Bag Suspension kwellzz ZJ Grand Cherokee Forum 1 08-26-2009 07:03 AM
zj bb rear spring help ibskunk ZJ Grand Cherokee Forum 9 07-29-2008 06:13 PM
Rear Coil Spring? jimbob01 ZJ Grand Cherokee Forum 3 09-09-2007 11:16 AM
zj front to rear spring 4" lift rear track bar info autobeamhotmail ZJ Grand Cherokee Forum 3 03-01-2007 03:07 PM
Rear Spring removeal john1998 ZJ Grand Cherokee Forum 14 12-31-2005 10:09 AM
