Rear Hitch mod - JeepForum.com
post #1 of 45 Old 06-03-2012, 07:37 PM Thread Starter
Static83
2014 JK Wrangler
Rear Hitch mod
I've been looking up threads on how to do this, and it looks like something I can do, however I'm wondering what to do the cutting with. I have a dremmel and a reciprocating saw. Will either of these be good choices? Can the bolts just be cut? or do you need new ones?
Any other advice would be welcome.
Static83 is offline
post #2 of 45 Old 06-03-2012, 07:41 PM
84foxgt
2007 WK
i'm assuming your trying to fit your latger spare under there. you have to use carriage bolts. you can trim the hitch with a sawzall.
2007 v6: Rough Country kit, Aries taillight gaurds, 2457517 Wrangler Silent Armors, LED interior lights, painted oe wheels Gunmetal, Topline 1.5" wheel spacers,SOLID rear diff cover,CREE backup lights,Hypertech Programmer
84foxgt is offline
post #3 of 45 Old 06-03-2012, 07:45 PM
SSF556
2008 WK
angle grinder....
Just be safe...this can happen very quickly....that is my finger after a brief encounter. Also where safety glasses.
Probably the most respected tool in my garage.
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #4 of 45 Old 06-03-2012, 07:57 PM Thread Starter
Static83
2014 JK Wrangler
Yes, I just got 5 stock rubicon wheels and tires and would like to fit the spare under there when not wheeling. I unfortunately do not have an angle grinder so will probably go with the sawzall and make it pretty with the dremel. I always wear safety glasses.
With the angle grinder, how long does it take to grind down to the welds? I may try to find a friend with one.
Static83 is offline
post #5 of 45 Old 06-04-2012, 08:02 AM
trax95008
2006 XK Commander
I think a band saw would be the preferred tool
trax95008 is offline
post #6 of 45 Old 06-04-2012, 08:41 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Originally Posted by scootr29 View Post
angle grinder....
Scott - I was wearing leather work gloves when I did my rear hitch w/ the angle grinder and zipped my left index finger. Got through the leather but only grazed the skin luckily. Agreed - awesome tool - handle with extreme caution.
I'd like to see you get a band saw under your rig and up into the hitch area.
Angle grinder with a good cut-off disc is the way to go.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #7 of 45 Old 06-04-2012, 09:47 AM Thread Starter
Static83
2014 JK Wrangler
Think I can do the angle grinder method without removing the hitch? Thats what it sounds like ur saying to me anyway.
Static83 is offline
post #8 of 45 Old 06-04-2012, 11:05 AM
JeepN4KC
JeepN4KC's Avatar
Yes - definately doable w/o removal of hitch. Get the spare out from under there. If you have ramps to back onto even better, otherwise jacksstands would do the trick under the rear axle. You don't have to elevate the back end but it helps depending on your size. If you can, do not work from your back with grider overhead. Crouch under there and work in front of your body best you can.
~Mike~
WK
XJ
JeepN4KC is offline
post #9 of 45 Old 06-04-2012, 11:15 AM Thread Starter
Static83
2014 JK Wrangler
So if I go this route, I can just grind down the hitch, and cut off the end of the bolts and be done with it? Or do the bolts need replacing?
Static83 is offline
post #10 of 45 Old 06-04-2012, 11:23 AM
SSF556
2008 WK
I replaced the bolts....
2008 CRD QT2
SSF556 is offline
post #11 of 45 Old 06-04-2012, 11:24 AM
trax95008
2006 XK Commander
The OP didn't mention leaving the hitch in place
post #12 of 45 Old 06-04-2012, 11:28 AM Thread Starter
Static83
2014 JK Wrangler
I didnt. I didnt even think it was an option at first, so I'm kind of glad he brought it up
Static83 is offline
post #13 of 45 Old 06-04-2012, 12:25 PM
fingaz
2009 WK
Now I see they make a rear hitch that is slightly lower than the factory hitch and it does not requires any cutting of the bumper. The receiver sits right below the rear bumper. Aside from the OEM one looking cleaner and is there any difference between the OEM hitch and the aftermarket one? Which one is better?
Aftermarket slightly lower hitch:
http://www.google.com/products/catal...MAE#scoring=tp
fingaz is offline
post #14 of 45 Old 06-04-2012, 12:36 PM
Budasac
2005 WK
angle grinder....
Nice one Scoot. Those grinders can get you good. I think I got ya beat though. This was from a hand held bandsaw.
I quickly learned that you should always have two hands on the saw. Respect your tools! And be safe.
Also, whoever made the comment about not working on your back under the grinder, excellent advice. I was drilling into concrete overhead once and hit some rebar. Red hot flake of metal seared itself into my eye. Not a pleasant experience.
Budasac is online now
post #15 of 45 Old 06-04-2012, 01:20 PM
SSF556
2008 WK
http://www.google.com/products/catalog?q=jeep+grand+cherokee+hitch&oe=utf-8&rls=org.mozilla:en-USfficial&client=firefox-a&um=1&ie=UTF-8&tbm=shop&cid=2224739625017692682&sa=X&ei=u_zMT_H FF9Gd6AHPqqn6Cw&ved=0CNgBEPMCMAE#scoring=tp
You lose departure angle with a lower hitch......
2008 CRD QT2
SSF556 is offline
Rear Hitch Question chriscalcaterra WK Grand Cherokee & XK Commander Forum 4 01-20-2011 08:11 AM
Got rear ended with the hitch on mrbell83 ZJ Grand Cherokee Forum 9 09-25-2008 05:14 AM
WJ rear tow hitch indept ZJ Grand Cherokee Forum 3 09-18-2007 09:37 PM
Rear Hitch question MidniteSquirrel ZJ Grand Cherokee Forum 11 02-01-2005 11:08 AM
Rear hitch question... HeavyMetal ZJ Grand Cherokee Forum 0 11-01-2004 04:14 PM
