Rear end is hawling - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Rear end is hawling
Price match at JeepHut.com20 Ton Press Brake DIY Builder Kit @ Swag Off RoadFenders for your Jeep at Jeephut.com
Unread 08-25-2014, 02:46 PM   #1
ylimits
2008 WK
Rear end is hawling
I have a 2008 grand Cherokee with the diesel in it and I've noticed that my rear axle is starting to make a bawling noise and its starting to get worse I was wondering if this is a common problem in these jeeps or if my problem could be something else. Also can I just change the rear diff. Or do I need to swap the whole axle
ylimits is offline   Reply With Quote Quick reply to this message
Unread 08-25-2014, 03:45 PM   #2
ttusqrl
2005 WK
Try changing the diff fluid
2005 WK 5.7 ORT | Mod SL (OME struts & 990s) | JBA UCAs & Discos | Saguaro Front Bumper | Warn Zeon 10s | 285/70/17 BFG TA KO | AIRAID CAI | Gibson 3" Exhaust | DiabloSport Intune | JL Stealthbox
ttusqrl is offline   Reply With Quote Quick reply to this message
Unread 08-26-2014, 12:37 PM   #3
caulk04
2008 WK
Howling?
Pull the cover and inspect, if no obvious damage is present, just try changing the fluid. I'd go cheap with some plain old conventional oil just to try it out. No sense wasting $40+ on good fluid just for a test.
If it goes away, drain again and put good fluid in. If it keeps doing it, find a good shop to at least do new bearings all around if not a new R&P set as well.
Tint, Superchips, SRT intake tube, Gibson catback, catch can. One hardcore DD/kid hauler...yeah.
caulk04 is offline   Reply With Quote Quick reply to this message
Unread 08-26-2014, 01:06 PM   #4
BonesWK
BonesWK's Avatar
2006 WK
any play in the rear DS where it goes into the diff? Any leaks where the DS goes into the diff?
Those are symptoms of pinion bearings going
Ryan
2006 Black WK Limited 4.7 4x4 QD II
Lift/Tires/Stuff
If you want to achieve greatness, stop asking for permission
BonesWK is offline   Reply With Quote Quick reply to this message
